Question about Biostar P4M80-M4 Motherboard
Computer powering up
My motherboard is a 848A PC Chips motherboard. Have done all I could, new cpu, new videocard, powersuppy checked out fine, new hard drive,and cd/dvd reader but nothing will come up on the monitor. Monitor was checked. The power supply will run and cpu fan will run but nothing will show on monitor. I have already reset the CMOS and returned to normal mode with no results. Help.
  • strings491 Nov 09, 2007
    new power supply, still no power???
    Novelist:
    Scholar:
  • 167 Answers
It looks like your mother board is old one. If so clean it with IPA solution (Iso propyl alcohol). Replace the processor.Then try again. You can also try changing your Video card. That can cause problems if not seated properly. If nothing works get your motherboard serviced.
Posted on Sep 27, 2007
Cpu fan running but no display
1.try with a other Monitor.
2.check all cabels so they are seated tight.
3.check the videocard to be seated tight.
4.are the videocard get the right power.
5.the videocard can be brooken.
Jun 05, 2013 | Jetway Computers & Internet
Shut down during boot
Sounds like a cpu overheat situation. Check the cpu temps in the bios and compare the temps with the maximum operating temp of your particular cpu. It might need better/or/new cpu thermal paste applied to your cpu, and also check that your cpu fan is running and locked down tight (and not loose)
Nov 22, 2011 | PC Chips P23G Motherboard
My 4 pin power connector on my PC Chips m960g motherboard. When I disconnect it then CPU runs, but when it's plugged in the CPU runs for 2 seconds then shuts off. Can I fix some how or do I need a new MB....
if you buy a new mother board your motherboard might be needed to reformat sometimes, this is because of the drivers that are installed already in your hard disk...if you are able to login to your computer then go to control panel and remove old drivers and install new drivers... in this case you will be needed to format your hard drive...
Jul 16, 2010 | PC Chips : M960G...
No display assus motherboard PSN73-AM ASUS MOTHERBOARD
When the PC starts up, do you get a BIOS display at all? Try fitting a graphics card into the board instead of using the built in port, if that works check the BIOS settings to see if the built in adapter has been disabled,
Mar 26, 2010 | ASUS P5N73-AM Motherboard
I have a gateway 831gm. it has an Intel (Augsburg) 915G Motherboard and a Pentium 4 630 cpu 800MHz fsb & 2MB L2 cache. i've been looking for a cpu upgrade and saw that the Pentium E5200 Dual Core has...
If both motherboards are LGA775 socket, then the next concern is whether or not the case is capable of having the new motherboard installed into it. Disconnect all power cables to all dv drives or cd drives and hard drives. Disconnect all ribbons from drives to the mother board. If you can get to all of the screws that hold the motherboard into the case, you get away without removing drives. Once you've got the motherboard then you can disconnect the power cable from the motherboard. Remove the memory chips, disconnect the sound cable from the old motherboard. install the memory chips onto the new mobo, Connect the power cable to the new mobo, then install the new mobo into the case. Replace the ribbons from the drives to the mobo, replace the power cables to the drives and reinstall the sound cable to the cd or dv drive. You should be done now.
Dec 13, 2009 | Gateway 831GM PC Desktop
Pc keeps beeping 3 times and nothing on the moniter
remove the RAM(MEMORY CHIPS) from *********** board and reinsert.if the problem is same replace the chips,get new chips.mostly cleaning the golden lines on the chip with pencil/school rubber solves the problem.
No beep is usually a power problem that can be related to the power supply, motherboard or both. Always check your battery power before thinking there is a bigger problem.
Step3
One beep is a normal POST. That means everything is fine. Two, Three, or Four short beeps are normally about the memory of the machine. If there is a problem with one of your memory chips you should get beeps of different combinations in this area. If you get two or three short beeps, one or both of your memory chips could be in trouble.
Step4
Five beeps point toward motherboard or CPU problems. Make sure your memory and video card are seated properly. Try removing them and putting them back in, only if you are comfortable with computers. Six, seven and eight beeps. Eight beeps indicate problems with your video card. Six or Seven are CPU, or a bad chip on the motherboard. Nine beeps mean the BIOS is bad. Replace the motherboard. Ten beeps means the problem is in the CMOS. All chips need to be replaced.
thanks.
Jul 11, 2009 | Asrock 775i65G Motherboard
Boots to press f8
I haven't encounter this one, but you may want to check whether your CPU extra power is plugged in. Also, seclude the problem by checking if it is the power supply or the video card that is causing the problem. Remove the videocard and use the old one and check if it passes through. How much power can your power supply give and what model is your videocard?
Sep 18, 2008 | EliteGroup P4M800PRO-M Motherboard
P4VM890 + new videocard! No boot up!
welcome to fixya
Well i never did it that way but ok
your going to have to reboot the computer with the reboot disk ,,
once thats done turn off computer and install the video card and then also insert the drivers disk that came with the video card
this should work has for me and i have done 100s of video cards
Although if you bought a good video card and still have a 400w power supply your going to run into trouble make sure you have a 500w power suplpy or better to run a good video card ,,,,,
i hope this helps you out have a good day:)
Jul 19, 2008 | Asrock P4VM890 Motherboard
No signal
have you tried different video card? try to use the onboard videocard of your motherboard and securely tighten the vga/hdmi cable.
Jun 11, 2008 | PC Chips Computers & Internet
No beep,No Display on my monitor,only CPU heatsink fan is moving
how to fixed your motherboard no display and no beep, 1st you must clean your memory using eraser and brush for painting if not display again try to clean your video card if have a video card using again the eraser and painting brush if not display again try to pull out the bass in the cdrom and floppy disk. if not display you must replace the memory and video card., if not display try to change your motherboard. The beep put speaker in the motherboard.. gudluck guys
Sep 10, 2006 | Asrock P4I45GV R5 Motherboard
Biostar P4M80-M4 Motherboard Logo
65 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
