Question about Sharp MX-3501N All-In-One Printer
Sharp MX-3100N error cause 0435 - Sharp MX-3501N All-In-One Printer
nikeananth
  • 267 Answers
SOURCE: What is error code 5000 for sharp mx-3100n
HI,
this will help you out...
http://www.afoffice.com/sharperrorcodes.htm
thank you,
vijay(vote for me)
Posted on Sep 24, 2009
Testimonial: "Many thanks"
  • 3 Answers
SOURCE: Sharp MX 3100n showing code H5-01 , what is it,how
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Posted on Feb 20, 2010
  • 120 Answers
SOURCE: Our sharp MX-3100n printer is
Apparently your machine is set to stop when the supply counters trigger a maintenance code. You can type # * C * and go into Sim 26-38 and bypass this.
VC means your cyan developer has reached its' rated life of 60,000 copies and needs to be changed. Your yellow and magenta developer which are usually changed at the same time as the cyan have also reached their end of life (VM, VY) and so all 3 will need to be changed (not black, your VK code will come up at 100,000).
You will need the color developer kit and the seals and filter. Sim 24 resets the counters and sim 25 resets the toner-developer mix ratio (this is MANDATORY or your new developer will be ruined, you must run the copier with a door open and only close it when you are ready to set the mix).
There's also various color calibrations after this you can get from a service manual. DO NOT run old developer through your machine, it will eventually lose its' magnetic properties and be carried through the copier sandblasting everything in its' path.
Posted on Feb 24, 2011
SOURCE: Sharp MX-3100n multifunction I can Copy,
Turn printer off and on again. Check that all cables are plugged in and that router is working properly.
Posted on Apr 13, 2011
  • 24 Answers
SOURCE: SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Posted on Aug 31, 2011
My sharp color copier Mx 3100n is indicating F2-73 after using 88-1 how do I restore it
Hello Tijjani,
The error code that you are experiencing is as follows;
F2 73 IMPROPER TONER CARTRIDGE DETECTION (YELLOW)
You need to replace the yellow cartridge with the proper part # Item Number: MX 31NTYA, MX31NTYA.
Good Luck!
Rich Lilja
Jan 08, 2017 | SHARP MX-3100N
Sharp mx 3100n
Sounds like PJL = Printer Job Language Set source Color Convert. whatever that means !!!!
Sounds basic but have you checked the Manual ? http://www.manualsprinter.com/sharp-mx-3100n
Go through sending test prints and go from there.
Aug 25, 2014 | Office Equipment & Supplies
What does error code dc on sharp 3100n mean?
image cartridge cyan need to be replaced
Jul 04, 2014 | SHARP MX-3100N
Sharp mx- 3100n error codes dk
black image unit need to be replaced
Jul 03, 2014 | Sharp MX-3501N All-In-One Printer
Anything try
Which windows platform.
Jan 28, 2014 | SHARP MX-3100N
Erro na sharp mx 3100n U2-80
On the control Panel, press the keys #*C* (pound, star,clear,star)to enter test mode. Enter number 16 and press the copy button. On the touch screen press "execute" and "yes". Press CA to reboot. The error code should clear.
Aug 03, 2012 | Sharp MX-2700N Color Copier
I have a sharp MX-3100N copier and need to fix the error C4-02
Your PTC unit needs to be replaced. Which is the Primary Transfer Charge unit.
Oct 31, 2011 | Sharp MX-3501N All-In-One Printer
Aug 28, 2011 | SHARP MX-3100N
Sharp MX-3501N All-In-One Printer Logo
79 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
