Onkyo tx-sr805 shutting down - Audio Players & Recorders
simplemitch
  • 752 Answers
SOURCE: Onkyo TX-DS474 Receiver shuts down after Standby mode.
It's going into a protect mode. The amp is probably shorted out. Disconnect the spkrs and turn it on. If it still shuts off, it's the amp, if not, it's the spkrs.
Posted on Sep 15, 2007
SOURCE: Onkyo 805 sub hook up problem
I made the same mistake when i hooked my REL sub up to the back of the 805.
The problem is there are 2 connectors on the back of the amp that are labeled as sub out. Look very closely, you will see that there are 2 grouped RCA outs. The RCA out group you are looking for differentiated by groups of "little white dots" all the way to the far right on the back of the amp. Hope this helps.
Posted on Jun 09, 2008
  • 899 Answers
SOURCE: where can I buy circuit boards for Onkyo Receiver TX-SR805.
have you checked these out , also you can contact the seller for other parts.
check it out !
http://shop.ebay.com/items/_W0QQ_nkwZonkyoQ20partsQQ_armrsZ1QQ_fromZQQ_mdoZQQ_sopZ12
Posted on Mar 15, 2009
artiedc
  • 35 Answers
SOURCE: Onkyo TX-SR705 shuts down suddenly
Onkyo receivers have a safety circuit in them to protect the Amplifier from blowing up:
If you listen closely when it shuts down ( after a loud scene ) there is likely a loud 'Relay Click'..
If this is what is happening you might be able to verify it by turning the volume all the way 'off' and waiting for the circuit ro reset ( releasing the safety relays & returning power to the internal Amplifier ) : you should hear another click, yhen you can bring the volume back up carefully and there will be sound again.
This safety circuit trips when then Onkyo receiver detects an 'Over Current' condition on the
' Power Supply ' that feeds the internal 'Audio Amplifier'..
Generally caused by:
1.
Improper load presented to the Amp outputs ( FL, LR, RL, RR, SUB, CENTER )
If you can ( one at a time ) turn off the SUB, Center, Fronts and Rears: trying to re-create the failure each time while you have one part of your system disabled or having their level turned way down..
You can isolate where the problem is coming from.
- any or all of these speakers being the wrong Impedence ( I.E. 4 Ohms instead of 8 Ohms )
Unless the receiver manual or the sticker near the 'speaker connetor' specifies a range or another value, you should assume 8 Ohms. Your speakers should say on the back of them.
- any of the speakers being connected in parallel ( 2 speakers to a single one speaker output ) .. Two 8 Ohm speakers connected in parallel make a 4 Ohm load to the amplifier.
- If the Suwoofer is Passive ( Not having its own power cord and amplifer ) it has a
Passive Crossover : this crossover can have its own power rating or limitation.. If it is constructed with capacitors that have too low of a working voltage, then they can saturate and the crossover itself can present a load to the amplifier that will case this 'Over Current Shut-Down'..
You user manual should detail this.
Ed
Posted on Apr 09, 2009
smarthome2
  • 1114 Answers
SOURCE: I turn my Onkyo TX-SR600 receiver on. After a few
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire2_bing.gif. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers2_bing.gif) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
Posted on Apr 11, 2010
Onkyo TX-SR805 Receiver power-on button not working, only the led red light indicator appears. Tried to reset by holding/press vcr/dvr & standby/on button, no result. Please help me solve this problem
Hello, Sorry, if the receiver does not turn on we can't do any troubleshooting. I suggest having your receiver serviced or traded in. Thank you, Onkyo USA
Feb 26, 2017 | Onkyo Audio Players & Recorders
Display Panel Problem.... my Onkyo TX-SR805 AV receiver works properly except No Display on the front panel. I follow the instruction troubleshooting on the manual by resetting the unit but to no...
I follow the instruction troubleshooting on the manual by resetting the unit but to no avail. It's beyond warranty period.
please help, thank you
Sep 27, 2010 | Audio Players & Recorders
The receiver thinks there are headphones connected
Onkyo directed me to return the unit to a service center. Apparently this is a known issue and after reading web postings I believe it. There were dozens of similar cases with a variety of Onkyo recievers. I was able to remove the ribon connector from the headphones and discovered it is not a shorted headphone detector. We will see what the service center does. I'm not looking forward to paying for shipping a 66 lb receiver.
Aug 04, 2009 | Onkyo TX-SR804 7.1 Channels Receiver
Need help hooking up a KRK powered subwoofer to an Onkyo 7.1 receiver
a single male rca spliting into 2 male rca's ....a signal splitter
Oct 30, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo TX SR805
Yes that would be your receiver. sending it back was the right choice. Good job :] i wish u luck if they send another one.
Aug 13, 2008 | Onkyo TX-SR605 Receiver
Zone 2 on Onkyo TX SR805 inoperable
HI pull down the flap on your amp and you will see buttons for zone 2 settings,press zone2 then level up this should work.
hope this helps .
CABLE GUY.
Aug 03, 2008 | Onkyo TX-SR803 Receiver
Fm tuner not workin in south africa
The unit will not outside the us.We have a different scan freq.
Mar 02, 2008 | Onkyo TX-SR800 Receiver
16 people viewed this question
 Grubhead
Grubhead
