Question about Ricoh Office Equipment & Supplies
Ap2610n error sc546 - Ricoh Office Equipment & Supplies
Error code sc546
546 is an unstable fusing temperature:
-Fusing thermistor defective
-Power supply board defective
-Defective connection of fusing unit
Feb 27, 2014 | Ricoh Aficio 1035 Copier
Error code sc546
sc546 is a fuser ready temp problem.
it requires a reset procedure: enter SP mode.touch Copy SP..touch SP DIRECT then press 7807# on the keypad then execute...turn power off and then back on
Jan 29, 2014 | Ricoh Aficio 1027 All-In-One Laser Printer
How do I clear error sc546 on a Ricoh Aficio 2035
replace thermostat in heating section or u yuor tirmistor is directly touching the heat roller
Feb 13, 2012 | Ricoh Aficio 2022 Black and White Copier
How do I clear error SC546 on a Ricoh Aficio 2045
SC546 A Fusing ready temperature unstable The fusing temperature is fluctuating. Thermistor connection loose Fusing unit connector loose you have to go into service mode and reset it
Apr 27, 2010 | Ricoh Aficio 450 Copier
Sc546 error
The ROD was engulfed with powder not allowing to rotate. When removed everything was normal- SC546
Jan 07, 2010 | Ricoh Aficio AP400N Laser Printer
Fix a SC 998 error on Ricoh AP2610N
you will need a service tech to come out and troubleshoot the SC998 error code as that is typically firmware software related beyond the scope of users without the benefit of ricoh training and experience.
Jul 09, 2009 | Office Equipment & Supplies
RICOH LASER AP2610N - error - SC 998
Normal 0 Could have a corrupt driver.
Disconnectthe printer or at least be sure it is turned off. I'd doboth and when the CD software program asks you to connect the printerto the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 30, 2009 | Office Equipment & Supplies
Fault SC546
SC-546 is "Warm-up" error, suggests that the fuser is NOT reaching 160' within standard warmup time.
You might be able to take out the fuser, remove fuser cover, remove carbon buildup from thermistor.
I had to change our fuser at 180,000 copies (service is at 120,000)
Jan 12, 2009 | Ricoh Aficio 1022 All-In-One Laser Printer
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
