Question about Ovens
Need a manual for. A neb Italian design so I can figure out the control for the oven
2 Suggested Answers
SOURCE: i need a manual for a neb verona ss fe2623exx oven
I have a manual for this oven which I can copy and email to get the grill to work you need to in this order.
Switch oven temp to max
then set function to grill
then set grill temp to what ever.
If you dont do it in that order the grill wont come on for some raeson.
Posted on May 06, 2010
Tip
One other comment about the F7 message having delt with this stupid oven for...
Do you have the dreaded F7 message pulsating from your oven? The original purpose of the F7 message is to signal a stuck START key, which is a rare occurrence. The more common cause is a type of short circuit that occurs in the touch panel near the cable slot. The fix that I will describe addresses this type of fault. It will not fix a stuck START key. It will not fix a faulty Electronic Range Control (ERC). If you are getting other errors, such as F1, the fix may still do the job. F0 is usually a shorted off key. Cleaning the ribbon cable connector is a myth. What you accomplish is to temporarily disrupt the short circuit occurring near the slot in the touch panel. With time the short circuit grows back. It happens more often when the humidity is high. So here is my solution to the F7 problem. The most important step is first turn off the power to the oven at your circuit breaker panel. You will need to open the touch panel. There are typically three small screws on the bottom edge of the touch panel. It is advisable to have an assistant to hold up the panel while you work on it. Pull the panel outward at the bottom to gain access. There are many wires attached to the panel. Do not allow the panel to dangle by the wires. When the panel is open, you will see a flat ribbon cable connecting the ERC to the touch panel. See photo # 1. The principle of the fix is to apply additional insulation in and around the ribbon cable at the slot where it exits the touch panel. There are three basic styles of touch panels. Here is how the fix is applied for each style. 1. Plastic touch panel with a two-segment ribbon cable. Apply a slip of paper or file card material between the two segments of ribbon cable in the area of the slot. Work the paper down as far as it will penetrate. Typically it will only go in about 1/8?. See photo # 2. 2. Metal touch panel with a two-segment ribbon cable. Apply the extra insulation as per style 1. In addition, apply extra insulation on both sides of the ribbon cable and the edges of the slot. See photos #3 & #4. 3. Metal touch panel with a one-segment ribbon cable. Apply the extra insulation on both sides of the ribbon cable and the edges of the slot. If your style is different from the above three styles, the fix will not work for your situation. Don?t be concerned about using paper for the insulation. It will not get hot enough to burn. You will probably find a set of instructions printed on paper in the top of the oven when you open the touch panel. If the fix doesn?t work for your situation, you will need to replace either the touch panel or the ERC. Here is how to determine which one is faulty. 1. Turn the power off. 2. Remove the ribbon cable connector from the ERC. 3. Turn the power back on. If the F7 does not appear after a few minutes, the problem is in the touch panel and it must be replaced. If the F7 returns after a few minutes, the problem is with the ERC and it must be replaced or repaired. Check www.cgiltd.com for information regarding repairing ERCs. Good Luck. May the ?fix? be with you.
on May 08, 2010 | Jenn-Air JJW8530C Expressions Collection...
Help - Knob positions on New World Debut single oven
Don't know how long ago you posted this but I have the same issues! The left hand dial deals with function and the fan oven setting is 2nd one. The grill setting is the furthest one round...I think. The right hand dial is temperature. 180 is at about half past. 200 is at about 40 mins past if you get my drift. All this I have kind of figured out through trial and error... Now I've just got to figure out how to change the light bulbs....
Aug 22, 2012 | Ovens
Please can anyone help? We are in a rented property and we have an NEB Venezia SS electric oven with gas hob and all the writing on the knobs has been erased over the years. The hob works fine we need to...
Look up the oven on the web the knobs vari in calabration figures so I have never worked on this model, try a search engine you may find a showroom near you pop in and have a look.
hope this has been helpful
John
May 31, 2011 | Ovens
I bought a used built in WhirlPool oven model FSSM6 but I don't know how to use it because there is no manual and the digital list is not in English; it looks like Italian or German to me, but it's...
Dear! vicky_toth
I am also strugelling to find a manual for my FSSM6 oven.
If you still have it could you share it with me too? sarkanyk@yahoo.com
Thank you,
Reka
May 10, 2011 | Ovens
I have a Whirlpool RBD305PDQ8. The display is blank, but will beep when pushing the buttons. If I attempt to start the oven, it will not turn the oven on and will have a series of beeps. Do I need to...
Up there in the controls is a bullet fuse like this:
Designed to kill power to the controls if it gets too hot in there so the controls won't be harmed. That could be it but I don't know if it would beep if the fuse is blown, that could be a bad control. Use this manual to help you diagnose:
Whirlpool double oven repair manual
Jan 26, 2011 | Whirlpool RBD305PD Electric Double Oven
After light cleaning-Electrolux Ew30ES65 upper oven won't heat now! The bottom oven works fine, the lights are all on, the convection fan works in the upper over but the heating elements don't heat now....
I had the same issue with my EW30EW55GS. This is the second time! The dirst time, the technician replaced all the circuit boards (took a month to get the parts). I figured, I would try a light cleaning again. SAME THING! Again, I'm without an oven for no telling how long. The oven looks great, but don't be fooled - it's a piece of junk!
Apr 04, 2010 | Electrolux ICON Designer E30SO75ESS Oven
I have a NEB oven (.06) and need to check the bottom element to see if it's' working or not. Do you know how I can access this element as I can see no way to do so from inside the oven?
You do not access it from inside.
It is usually a case of removing a side panel to access the element, possibly the top cover as well.
Hope this helps you.
Dec 18, 2009 | Ovens
I need a manual for a neb verona ss fe2623exx oven
Feb 26, 2009 | Verona Ovens
Ovens Logo
18 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
