Question about Toshiba E-Studio 2540c Copiers
Clean the slit glass and main charger - Toshiba E-Studio 2540c Copiers
Why does adf cause line in center of printed documents?
Does this happen when when you place a document on the big glass? when you use the doc feeder you are using the small slit glass clean the slit glass if the problem goes away when using the big glass or when you print, then you know the bottom part of the machine is doing ok and its the scanner section which is the big glass area and the slit glass. you may have to to look at the glass at different angles to see the mark.
Jan 21, 2016 | Epson WorkForce WF-3620 Wireless Color...
Some white band appear on my toshiba digital 352 copier, any solution plz.....?
Make sure no stain on the main charger, t/s block unit or laser unit slit glass...
Apr 12, 2015 | Toshiba Office Equipment & Supplies
Black line vertical while scan and photocopy a document
You need to clean the glass with alcohol or a good cleaner. There is toner or something on the glass where the line is occurring.
Feb 20, 2015 | Samsung SCX Office Equipment & Supplies
There are lines appears in the paper if i took the photo from feeder ricoh 2045
Does this happen when copying off of the glass? No? Clean the slit glass on the left. Still does it? Turn off the copier, remove the slit glass and the original glass. Gently slide the mirror carriage to the right. Carefully wipe the mirrors with a microfiber cloth and with a can air blow around the exposure lamp area. Reassemble and test. The most common problem is gunk on that slit glass which is easily remedied using a microfiber cloth.
Nov 20, 2014 | Ricoh Office Equipment & Supplies
How to check exposure lamp on ricoh sc101?
Clean the true white on the slit glass housing. Check for a dirty scanner mirror or that the scanner mirror is out of position. Also, check if the scanner is blocked or if the dirty white plate underneath the glass is obstructed. Try cleaning the glass with water. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
Jul 15, 2014 | Ricoh Aficio 1013 All-In-One Laser Printer
Why there is black mark in the back page of copied page in Ricoh FT-4822
Does the black mark only appear when you copy through the doc feeder? if so there is a slit of glass alongside the main glass, clean thisa thoughly with glass cleaner and retest. if the black mark is still there contact me.
Jun 26, 2014 | Minolta Di3510f Bizhub Copier
Black cq when using document feeder
clean the slit glass its the small maybe two inch wide glass to the left of the main glass clean it good use windex or alcohol that will get rid of you problem have a great day
Apr 18, 2014 | Kyocera KM-1505 Copier
Cc 2550 when making copies using document
You need to clean or change the charger unit, if you open front cover you will see green unit going inside the drum, you can take it out and clean or if it is too bad change it.
Good luck
Aug 21, 2013 | Copystar Cs2550 Copier
Clean slit glass
the slit glass is dirty. clean it. see if there is a secondary slit glass (depends on the adf). you can turn off the message in service mode.
Apr 17, 2013 | Kyocera Task Alfa / Copystar 400ci / 500ci...
Sends blank fax
Dirty scan glass
Clean slit of glass extremly well, it is a small slit rectangler section of glass before copy glass on the scanner.
Glue, Liquid paper are common finds on the glass in this area, While you have the lid up, clean white reference area (on lid directly on top of scan glass when lid is closed)
Feb 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
Toshiba E-Studio 2540c Copiers Logo
94 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
