Question about GE RCA 4-Line Speakerphone
I get a message Ac OFF
Does the visual message Ac OFF mean that even though I'm plugged into a live electric socket, the phone or the plug connector is malfunctioning and the phone is relying on the battery only (DC vs AC)?
    Brigadier General:
  • 6,966 Answers
Hi, Your assumption is correct. The phone is not sensing any external AC power. If you are sure that the AC cord/adapter is plug in to the mains, then it is either: 1. the walloutlet or where the ACplug/adapters is connected does not have any power; or 2. The adapter itself is defective. Hope this b e of some help/idea. Pls post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 26, 2007
SOURCE:
What does power down pc and plug in cabkes for gpus mean, even though they are already plugged in bad card?
Added a new graphics card? Today, high-end gaming graphic cards (GPUs) need separate power from the computer's power supply; they take more power than the motherboard can give them through the connector under the card. Your power supply should have separate connectors that match what's on the new video board.
Shut your computer down, pull the plug, open it up, and connect the power supply to the card, and then you'll be fine.
Sep 11, 2014 | Dell Alienware Area51 Alx Gaming Desktop...
Sony FD mavica will not run on charged battery, will run plugged in to charger
You either have:
1) a false positive on your battery, meaning that they aren't really charged even though they say they are (especially common the older a battery gets), or
2) the battery connection is faulty/dirty, while the AC adapter is fine. If the AC adapter uses the battery port, then the battery is your problem.
Nov 09, 2012 | Cameras
My Dell Latitude D160 won't respond at all. I have to constantly push the power on button to even get it to come on and when it does, the battery light is on red and I think it says low critical power...
I'm confused too... it sounds like the power adapter is not (electrically) connecting to the laptop or the adapter is not delivering proper voltage/amps to the laptop.
You shoud 1. make sure that the AC plug is properly in the AC socket, 2. that the AC cord is (mechanically) connected to the adapter, and 3. that the adapter is (mechanically) connected to the laptop.
I cannot tell you how many laptops I have seen where the (internal) power connector breaks as a result of (typically) mis-handling, dropping, etc. Try (gently) wiggling the adapter connector and look for the LED changing colors.
You could also test the voltage output of the adapter with a standard Volt meter...
Sep 13, 2011 | Dell Latitude D610 Notebook
So my Hp Pavilion A200N Desktop Pc does not want to turn on! Just the other day it was up and running. What is wrong with it??!
Dunno yet.
I suggest you perform the diagnostic test to see if the problem is the Power On switch, (Located inside the plastic Power On button assembly), or the Power Supply.
(Hopefully your power company wasn't doing any work on your line, or a brownout occurred. Also hope there were no lightning storms present, and the computer was plugged in. Surge protector? With lightning strikes you need a surge protector that costs around $300. The ones that are usually purchased will not provide adequate protection. No matter what they state. {$12 to $60)
The method is to use a jumper wire on the ATX main power cable connector.
The jumper wire connects to the green Soft Power On wire, and ANY black ground wire.
If the computer comes on, (Power Supply actually), you have a bad Power On switch.
A generic replacement Power On switch runs about $5,
http://www.directron.com/atxswitch.html
If the computer does NOT come on you have a bad Power Supply.
(Not hard to replace yourself at all)
I would like to start by showing you an illustration and photo of your motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07813&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&site=null&lang=en&product=329403&key=null
Scroll the page down towards the bottom.
There is a square shape represented in the middle of the illustration, with the bold letter/numbers - Intel 845GL in it, and Memory Controller Hub (MCH) under that.
Below this is the ATX main power connector. (ATX Power Connector)
It is white in color (Photo), and has 20 socket holes.
Two rows of 10 socket holes.
This is a closer look at an average 20-pin ATX main power cable, and it's connector. (Plus the above mentioned connector on the motherboard),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The photo to the far Left shows the 20-pin ATX main power connector on the motherboard. (Female connector)
The photo in the Middle shows the Front of the connector, on the power supply's 20-pin ATX main power cable. (Male connector) Plugs into the connector on the motherboard.
The photo to the far right shows the 20-pin ATX main power cable plugged into the motherboard.
(into the 20-pin ATX main power connector on the motherboard)
The photo to the far Right shows the BACK of the connector that you will be using.
The jumper wire is placed down into two socket holes into the Back of the connector.
One end of the jumper wire goes down into the socket hole with the Green wire.
The green wire is the Soft Power On wire. (Abbreviated as PS_ON)
The other end of the jumper wire goes down into a socket hole with ANY Black wire.
ALL Black wires are ground wires.
The jumper wire goes down into the socket hole RIGHT NEXT TO THE EXISTING WIRE that is present.
Goes right beside the wire already in the socket hole.
Every wire going down into that connector ends in a metal terminal.
The metal terminal is pretty far down into the socket hole.
For this reason, you must ensure that the ends of the jumper wire are touching the metal terminals, down in the socket holes.
A paper clip is usually used for the jumper wire. It is nice and thin, conducts electricity, and is stiff.
The paper clip is straightened out, then bent into a U-shape.
The middle of the U is wrapped with a few wraps of black plastic electrical tape.
This area is for your fingers.
Computer laying on it's side on a table, computer case open, computer plugged into power:
The jumper wire is inserted into the two socket holes mentioned above.
IF the computer comes on you have a bad Power On switch.
If it does NOT you have a bad Power Supply.
About the voltage you will be addressing.
1) One wrap of black plastic electrical tape will insulate you from 600 Volts DC.
2) The voltage you will be addressing is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
3) There may be a spark. Cautioning you in advance. You may wish to wear a rubber dishwashing glove on the hand with the jumper wire.
(Sometimes there is no spark. Just cautioning you in advance so you don't freak out)
[Your computer Power Supply converts AC electricity from your home, or business, into DC electricity. (100 Volts AC, 120 Volts AC, or 220 Volts AC. Depends on what country you live in )
DC electricity is what is used by the hardware components inside the computer.
There is 3.3 Volts present, 5 Volts present, and 12 Volts present.
Only if you stick your hands inside an open computer power supply, (and plugged in), would you get shocked ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Jun 07, 2011 | HP Pavilion A200n (DF209A#ABA) PC Desktop
Help! I have a yamaha psr 9000 keyboard - i've had it for almost 9 years and my dog has chewed the ac power cable. Is it still possible to get a new one to fit it? If, so where can i buy on line? I...
Your main's power cord is easy to found at most of the electronic shops. It's the typical "figure of 8" connector, available also for some laptop's power supplies. You can also order one one line from this link. Note that since I don't know where are you from, the plug for the wall-socket may differ from the one on the provided link, but it's easy to use an adapter for your local area electricity. For example if you leave in Europe you can order the power cord from this link that is fitting on the european electricity standards. In case you can use screwdriver and cutting tools you can also change just the plug for the wall socket (in case that the dog's chew is near this plug) with very low cost.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Apr 12, 2011 | Yamaha Music
I cannot get my acer aspire 4315 to AC power up. new batteries are ok. i have changed the power jack but no difference. please help
Check the light on the AC adaptor when plugged in to the laptop. If it is flashing, it indicates that the power is being "spat back". That is, not completing the circuit. Means that you have a fault in the charging circuit. I'd check for burning around the contacts where the DC port was soldered onto the board / or if the plug type, check the socket on the mobo is not damaged and is firmly soldered on.
After that, (if not already done) check the output voltage of the adaptor with a multimeter, might be a simple failure of the ac adaptor, even though it looks ok
Mar 20, 2011 | Acer Aspire 4315 Notebook
My xbox 360 picher will not show on the tv how can i fix it and the conteroler will not stop blincking
Try this first
Same procedures for an xbox
The AV Multi Out plug that is included with the Wii will allow you to connect the console to most TVs or VRCs. First, look at the back of your television AND your VCR and see if you have colored holes label "Input". Though most TVs have them, almost all VCRs do as well. If you are unable to find a set of yellow, red, and white AV inputs on the back of your TV, try looking on the sides, top, and bottom of the TV. Look for any hidden panels or doors as well. Connecting to a Television Audio/Video (AV) inputs are typically located on the back of the TV, but occassionally are on the sides, top, or bottom. Look for inputs marked Audio and Video IN. Do NOT connect your system to anything marked OUT. Don't see these inputs on your TV? Click here. Insert the AV Multi Out plug on the Wii AV Cable into the AV Multi Out connector on the back of the console Insert the DC plug on the Wii AC Adapter cord into the DC Input connector on the back of the Wii console. Insert the AC plug into a 120V AC wall outlet CAUTION: To prevent electric shock, match the wide blade of the plug to the wide slot and insert fully into the outlet. Plug the transformer into the wall outlet. The Sensor Bar can be placed either above or below your TV screen. Decide which option best fits you and click the image below for additional set up help, including mounting the Sensor Bar and proper alignment.
then try
Lets focus on the external portion of the TV set first (95 percent of all TV problems are related to things EXTERNAL To the tv itself) Check the physical CONNECTION of all cables by removing each wire bare or RCA and reinstalling it (Each power cable as well), once you have removed one cable, check it for fraying, and if it is already bare, splice a new fresh connection for it. 5. Check to make sure there are NO OTHER uneeded radios, system nearby. these systems, when powered on, will cause electromagnetic interference and prevent more than just severe tv interference SURGE PROTECTOR Surge protectors account for more than 75 percent of electric faults to stereo equipment. Lets start with your AC Wall outlet. It is standard in america that 220 Volts from out of these outlets. This implies that each device will be using 220 Volts (From within that grid zone). If anything including an alarm clock is plugged into any AC outlet socket in the vicinity of the stereo equipment/TV, it will cause electric outage, and prevent electronics from even turning on! Your TV needs dedicated electric power. If your TV is located in the living room then unplug everything else in the living room. Lets plug the TV set into a Dedicated socket. Check all light switches to ensure that power is on for that outlet. Check the TV cable for Fraying both on the ac wall end and where it plugs into the TV. Check all GFCI outlets to ensure that all red reset buttons are pushed in, check the circuit breakers for proper connection and they are turned on. Now, lets try the TV set without it connected to any cable services, vcr, dvd, stereo system, etc. Please respond if we have found a solution.
Jan 20, 2011 | Microsoft Xbox 360 Wireless Controller
Worked fine yesterday, today zilch !!
One computer I fixed had its internal power regulation confused. With the AC adapter plugged in, holding the power switch down for twelve seconds, then pressing it again, switched it back on. This sort of problem can come from a variety of causes, though. There is an internal power distribution chip which could have received a static electric shock or power surge and gotten cooked. The RAM could have gone bad. The socket where the adapter plugs into the computer could have been cracked loose. Check the power switch and then RAM first, and write more if that doesn't fix it.
Jan 05, 2009 | Toshiba Satellite M105-S3041Notebook
LINE IN USE
The line coming from the wall is plugged directly into the "L" socket (without anything in between)? Is anything plugged into the other (extension phone) socket? Usually, this message only appears if a "live" device is plugged into the extension phone socket. For instance, if you have an answering machine plugged into both a wall socket and the extension phone socket on the JX200.
I just looked at the "Easy Setup Instructions" posted on Canon's web site, and in Step 3, the words are correct, but the diagram in the square box is backward. Let me know if you are still having problems.
Jun 03, 2008 | Canon FAX-JX200
Mag Innovision LT582s 15 in flat monitor
Well, Most montiors have a standered adapter Which you can get from almost any good online store, maby say what the socket looks like most are 3 pin sockets..
Sep 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
GE RCA 4-Line Speakerphone Logo
313 people viewed this question
Top GE Lands Phones Experts
martin hogg
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
