Question about Bell Sports Bell iFlux Bike Light
I have this brand new iFlux bike light, it only flashes for a few minutes and it dies down. I have to take out batteries, put it back in again to turn it back on. Any trick?
I just replaced battery and alternater but the battery died hile driving and once i jump the car it ill run for thirty seconds then die.
you've had the misfortune of getting a bad rebuilt alternator-sorry-they should give you another one -I hope its not hard to replace-Denny
Nov 05, 2013 | 2004 Chevrolet Impala
Battery light wash flashing.car then died while driving
More than likely it is the alternator not putting out enough to run the car.
May 22, 2013 | BMW X3 Series Cars & Trucks
My bike has sat for one year. I bought a new battery one year ago and drove it from my old apartment to my current one. The bike has not been started for one year. I got a used gas tank on ebay and...
Ok mate few things to consider here, if the bike has been non started and stationary for a year there is a very good chance that one of the following or all of the following has occurred.
Your battery is dead (they don't like just sitting - doesn't matter new or old, if left for extensive time they will die) Your gear / motor oil would be useless - oil can not just sit in bottom of bike for a year it would be glue
Your carbi would be blocked or partially blocked from fuel gum or varnish in jets
If you like this bike I highly recommend oil and filter change, New spark plug (put about 10 drops of oil down the spark plug hole before you put new spark plug back in to lube the piston) clean air filter (or fit new one) Remove carbi and compressed air clean all jets especially the pilot jet and circuit and stick in a new battery
Once all done for the fist start I would find a nice safe hill and push start it. in my experience under this circumstances if you rely on the electric starter you may find you burn it out trying to start so give at least few minutes running motor to flush everything through before trying to electric start would be your best bet
When you get it going I would dump the oil and oil filter again after 2 hours ride time to confirm all the old expired oil is flushed out - just to be safe
good luck regards Jamie
May 28, 2011 | Suzuki Boulevard C50T Motorcycles
1998 VT 1100 C Shadow Spirit: brand new battery;died after a few hours of ridein...
Could be, replace or have it tested. My old bike a 1998 VT1100CT had a problem with the starter being weak, like the battery was dying. Turned out to be the battery ground wire bolt, going to the back of the starter. It just had a little rust on it, and the bolt broke when I went to remove it. But once replaced the bike starts great, we replaced the battery, took apart the starter tested everything. All for a slightly rusted bolt not making a good ground... Check your Regulator, and any corrosion around the connections!
May 17, 2010 | 1998 Honda VT 1100 C Shadow Spirit
My 08 gsxr 600 died while I was riding it, I got a new battery and it started up fine, but when I got home I shut it down, then tried to start it up again and it wouldn't start. All the lights are on and...
I would check your connections and grounds. I would check the voltage of the battery with the bike off and then compare it to the voltage when the bike is running to see if the battery is charging. Your may have enough voltage to run lights but not enough amperage to crank. Is the new battery full of acid? silly question but I have seen this happen before, the guy puts the wrong amount in it.
Check your fuses too. I would verify that its charging before trying to chase down any current draws of shorts.
Mar 08, 2010 | 2008 Suzuki GSX-R 600
1990 FZR 600 - Battery problems? drainage?
this is yours jarnater or regulater problem same problem to me i have fzrr 400 but i install a new regulater and then i solve my problem
Feb 18, 2010 | 1990 Yamaha FZR 600
Battery light on; then the instrument cluster goes
may be a bad alt check voltage while running should be about 14 volts
Jan 20, 2010 | 2003 Ford Focus
Bike would die out during ride
sounds like you may have an overheating problem
check temp. and cooling fan
Apr 16, 2009 | 2002 Yamaha YZF-R6
Bell Sports Bell iFlux Bike Light Logo
75 people viewed this question
Top Bell Sports Cycling Experts
Eric Hidle
Level 1 Expert
Tom Chichester
Donald Ayers-Marsh
Are you a Bell Sports Cycling Expert? Answer questions, earn points and help others
