Phaser 8550 error code 04,020.41:37829 - Office Equipment & Supplies
  • 2072 Answers
SOURCE: Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Posted on Apr 22, 2008
  • 2072 Answers
SOURCE: xerox phaser 8550 error :
That is a wiper or media gearbox fault.
The wiper may not be moving up and down wiping the print head properly or the media gear box may be mistimed.
Posted on Jul 06, 2008
  • 81 Answers
SOURCE: phaser 8550 error 19,004.40
The printhead was installed in another machine and the codes do not match. You need to manually sync them. Here is the procedure:
Manually synchronize the Printhead and Electronics Module codes.
NOTE: The Printhead and Electronics Module codes should synchronize automatically when a new printhead is installed. If a 19,004.40 error occurs, it is possible that the replacement printhead was previously installed in a different printer. After manually synchronizing the Printhead and Electronics Module codes, be sure to test the new printhead for print quality defects.
To manually synchronize the codes;
1). Power OFF the printer.
2). Disconnect the printer from external devices (A/C power can remain connected).
3). Locate the "Factory Only" port on the electronics module (located between the PS and PE lights (Figure 1).
4). Use a Hard Disk Drive (HDD) jumper (Figure 2) to short the top two pins.
NOTE - If a HDD jumper is not available, use another conductive item, such as a screwdriver, to short the pins. Use caution to avoid contacting the surrounding frame, as this may permanently damage the Electronics Module.
5). With pins shorted, power ON the printer.
6). When printer reaches the mechanical initialization stage of the power on sequence, power the machine back OFF.
7). Remove the HDD jumper.
8). Code should now be synchronized. Power ON machine and verify the 19,004.40 error does not re-occur.
NOTE - If error persists after this procedure, attempt the procedure again, and be sure to allow the printer to complete its BIST and POST test before powering OFF in step 6.
Posted on Jul 23, 2008
  • 2072 Answers
SOURCE: XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Posted on Oct 29, 2008
  • 7 Answers
SOURCE: Magenta Ink cartridge is stuck in Xerox Phaser 8550/8560
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc fault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
How to clear error ending in 3433
Phaser 8500/8550 Support - Xerox Support and Drivers
www.support.xerox.com/support/phaser-8500-8550/.../enus.html
XeroxProduct support for Phaser 8500/8550. ... Phaser 8500/8550 Support & Drivers. Customer Technical Support. Fast Track to the Expert > 1-800-835-6100 U.S. & ...
Jul 28, 2015 | Xerox PHASER 8550 COLOR Printer
Hi i have phaser 8560, it gives me a error 09,038,46:62248, plese who can solve me the problem.
Hi there
The onlty thing I can find close to this is.
Acording to the manual its a ink loader error like your loading the wrong type of ink like the puzzles pieces arent matching and hitting the sensor flags right. Yours by the 8 is referring to the black ink. Anyway go to troubleshooting on the control panel. then to service tools. when in service tools press and hold the up arrow while still pressing the up arrow press the down arrow. the display should say hidden menus. go to diagnostic mode press enter go to funtion menu. then go to clear ISC fault and enter. ISC=ink stick count fault. I hope that helps. Just to let you know Ive had nothing but problems with third party ink and once its in the system its hard to get out so I would watch what im doing with my expensive equipment
Feb 18, 2010 | Xerox Phaser 8500/DN Printer
Getting this error code on 8550 Phaser: 37,006,42:26076 Have been having problems with the fan
Hi outonalimbwi:
Here is your problem.
37,006.42: PEST - Drum disconnect. The drum heater is not drawing the expected power from the supply.
Troubleshooting Procedure
Step Questions and Actions Yes No
1 1.
Run the appropriate diagnostic test:
37,002.47 = Left Jetstack Heater
37,003.48
= Right Jetstack Heater
37,004.40
, 37,005.41 = Reservoir Heaters
37,006.42
= Drum Heater
37,008.44
= Preheat Heater
37,009.45
= (8500/8550) All ink melters
= (8400) Ink Melt 1
37,010.46
= (8500/8550) Ink Melt 1
= (8400) Ink Melt 2
37,011.47
= (8500/8550)Ink Melt 2
= (8400) Ink Melt 3
37,012.48
= (8500/8550)Ink Melt 3
= (8400) Ink Melt 4
37,013.48
= (8500/8550)Ink Melt 4
2.
Did the test pass?
Go to Step 3. Go to Step 2.
2 1. Check the wiring running from the component to the printhead.
2. Is the wiring damaged or not working properly?
Replace the wiring harness.
Replace in the following order:
■ Drum assembly
■ Preheater
■ Printhead
■ Ink loader
Aug 11, 2009 | Xerox Phaser 8500N Printer
Phaser 8550 . what does printer error code 09,005.40:78005 mean?
9,0XX.xx Errors - Ink Loader Faults. Try switching the ink loader.
Jul 08, 2009 | Xerox Phaser 8550/DP Thermal Printer
Printer Phaser 8400 : error 07,010.43:116034
If your printer is networked, if can fix its self by accessing this site
http://www.phasersmart.com/
May 18, 2009 | Xerox Phaser 8400 Laser Printer
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Phaser 8550 cyan doesn't print
If you go to the Xerox.com site and click support and drivers. enter phaser 8550 and there is a printhead update you need to get, You have to fill out a form.
That may be your problem since there is no fault code.
Apr 13, 2008 | Xerox Phaser 8550DX Laser Printer
Error code 09,038,46:21303
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Apr 09, 2008 | Xerox Phaser 8500/DN Printer
Error code for 8550
Call Xerox, they have a problem with this code and the ink loader needs to be updated.
It has to do with the yellow sicks loading properly
Oct 31, 2007 | Xerox Phaser 8550DX Laser Printer
k24674
