Question about Husqvarna Forest & Garden 125l 18" Gas Trimmer
Husqvarna 125l trimmer, shaft makes a whining sound
  • 22 Answers
SOURCE: WILL NOT START
This could help
http://www.fixya.com/support/t2241903-husqvarna_324ldx_4_cycle_string_trimmer
Posted on May 24, 2009
panilling9
  • 284 Answers
SOURCE: What are the factory settings for the
find L on your carbruetor and turn it clockwise 1/4 turn to see what difference it makes
it should begin to idle by itself?
zama carb. 1 turn out from closed
walbro 1and 1/4 from closed settings are only preliminary
Posted on Jun 14, 2009
  • 28 Answers
SOURCE: I have a husqvarna 125L gas trimmer and dies after
Could be clogged gas cap. Take the cap off and see if you can blow air through it. If no air passes, the trimmer will become vapor locked and wont be able to get enough gas.
Posted on Jun 23, 2009
  • 110 Answers
SOURCE: How to adjust the timing on a husqvarna 125L
You can't - it's fixed.
Posted on Oct 06, 2009
dontbother10
  • 2220 Answers
SOURCE: hi im after the fuel mixture for a 125L husqvarna
From you manual:
Two-stroke oil
For great results and performance use HUSQVARNA two--stroke oil, which is specially formulated for our two-stroke engines. Mixture 1:50 (2%). To maximize the life of your trimmer, you may choose to use a high quality synthetic oil formulated for two-stroke engines. Mixture 1:50 (2%). Never use two--stroke oil intended for water-cooled outboard engines, sometimes referred to as outboard oil. Never use oil intended for four-stroke engines.
WARNING! Always ensure there is adequate ventilation when handling fuel.
1 gallon of premium fuel to 2.6 ounces 2-cycle oil. 2.6 ounce pre-measured containers are available at most chainsaw outlets.
You can find your manual here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Posted on Jan 25, 2010
Is there a brush cutting attachment for a Husqvarna 125L?
Do you have the straight shaft version? Brush cutting blades are available from your local mower shop
Aug 23, 2013 | Husqvarna 28cc Gas Line Trimmer
Is there a brush cutter kit for a 125L Husqvarna grass trimmer?
Brushcutter kits should fit this model however it is quite a small engin within the range so may not be advised and it could put extra load on the engine and drive shafts
Nov 29, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
My Husqvarna 125L trimmer makes a terrible grinding sound and vibration along the shaft. What is this?
Could be a damaged bearing in the gear head, could be a bent drive shaft or outer drive tube, clutch drum may have worn the
engine housing and spinning off centre.
Nov 20, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
How do I stop the shaft rotation on my model 125L weed trimmer?
If its 'running on' then you either have your idle set up too high or stretch clutch springs.
Jul 13, 2011 | Husqvarna Forest & Garden 125l 18" Gas...
My husqvarna 125L weed eater will only run with the choke on why ?
sometimes it's caused by too much air in the mixture---check for leaks around gasket where carb meets head--also, check the jets--make sure they are not clogged
May 08, 2010 | Husqvarna Forest & Garden 125l 18" Gas...
How to replace accessories from a husqvarna power motor
Straight from Husky, the pole saw runs about $200...or if you have the straight shaft, you can get just the head for $185:
http://www.husqvarna.com/us/homeowner/products/trimmers/popular-accessories/
May 05, 2010 | Husqvarna 28cc Gas Line Trimmer
Husqvarna Forest & Garden 125l 18" Gas Trimmer Logo
29 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
