Question about Samsung HCN473W 47" Rear Projection Television
Samsung HCN473W 47 in. Rear Projection can't turn on
Hi There! My Samsung HCN473W Rear Projection TV can't turn on. When press the power button, only the "timer" LED flash a couple of times and then off. The screen keeps black. I bought this TV just pass 3 years. This is the first time in trouble. I'm appreciate for any hints to fix it. Thank you very much! [email protected]
  • 6 more comments
  • the rocks Dec 26, 2007
    Timer light stays on ,ticking/frying sound that seems to come from the flyback section, screen stays black.
  • Tom Georgi
    Tom Georgi Dec 27, 2007
    I am having that problem, in addition to the lines through my picture. I believe the flashing timer lite is some diagnostic code. I'll pass on any information I get. Good luck.
  • colborb Jan 05, 2008
    When turning TV on the timer indicator light blinks several times then stops. The TV does not turn on. TV just under 4 yrs old
  • C.D. Perry
    C.D. Perry Feb 07, 2008
    I have the HCN473W as well.... 4 years old.... it wont turn on.. black screen.... red light flicker.... no sign of life...
    ,,any advice will be appreciated,
  • jrnation Apr 06, 2008
    I have the same t.v. and the same thing just happened to me last night. I can only power on by the remote, it makes sounds like it's turning on but only the timer light flashes and I have a black screen. I will be calling on Monday to get a repair estimate, but if it's going to be costly it won't be getting fixed. My t.v is also just under 4 years old.
  • white rhino May 04, 2008
    Yes we have the same problem.  All we have is a black screen.  When you push the on button the tv makes a noise like it wants to turn on but all you see is the red light on the timer mode flickering.  We have had our tv for just over 4 years.
  • pla7 Oct 17, 2008
    Samsung HCN473W - Same thing is happening to mine (also 4 years old). Black screen, red light flickers 9 times. Has anyone found a solution to fix this?
  • thall77 Nov 24, 2008
    Problem Solver:
  • 3 Answers
I know this is a old problem but in case anyone in the future here has this problem, the problem lies in your convergence board ,mainly the stk`s are shot ,you can buy new STK`s for around 15 to 20 dollars and then will need some one to take old ones of and resoldering the new ones on.
anywho if you have this problem unplug or remove your convergence board and then turn on tv and you will see a picture, all colours will be out of convergence but when you put the fixed board back in colours should realign, or you may have to realign a little yourself.
only reason i am posting on this old problem is because was just given this tv samsung hcn473wx/xac for free and decided to fix it and it now works well.
micheal rose
Posted on May 07, 2009
  • melissahopki Mar 21, 2011
    can you tell me where to buy new STK's for this tv?
Turn the tv off by unplugging it from the wall and wait for the timer light to go off (Might take several minutes).
Once its go off turn the TV back on..Good Luck
Posted on Apr 25, 2008
    Genius:
  • 1,694 Answers
Practice visual acuity technique,front & back. Look for CRT coolant leak on PCB.Check all fuse devices.Get professional diagnostic help.
Posted on Sep 26, 2007
SOURCE:
I replaced the bulb in my Samsung HLP5674 wx xaa TV and now it turns off by itself intermittantly. How do I fix this?
You may have not gotten the lamp door switch positioned just right when you replaced the lamp door. It's been a common issue with Samsung in recent models. It's possible to defeat the switch by using a wire jumper across the switch plug and eliminate the problem all together if you're electronically apt.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Samsung HCN473W 47" Rear Projection...
Power comes on but screen is out and no sound
Replace the STK ICs STK392-020 there is 2 of them they are big black ICs will have PN# on them.
Mats Electronics 1-800-628-1118
Oct 28, 2010 | Samsung HCN473W 47" Rear Projection...
I have samsung hcn473 tv. The screeen is covered with squiggly vertical lines. Even watching a dvd movie, its the same.
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or look like 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board is dead,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 19, 2010 | Samsung HCN473W 47" Rear Projection...
They went away along time ago now they are back why?they are colored sparkles on the tv screen/
Convergence is dead.Try Tv repair world.com to buy a whole convergence board for the replacement.The Samsung/Akai use the same convergence board.
Mar 22, 2010 | Samsung HCN473W 47" Rear Projection...
Convergence is off and wont adjust with remote control adjustment
Convergence control will disappear / inactive in TV menu when Convergence out section got failure.
Please replace convergence out board in TV to solve this problem.
Is it Samsung HC-N473W model?
Thanks.
Nov 02, 2009 | Samsung HCN473W 47" Rear Projection...
Replacement of bulb for my HLP 5674 WX/XAA
sounds like your lamp is needing to be replaced. www.alltvlamps.com will have the lamp for your set just enter the model number of your Tv to locate it.
May 20, 2008 | Samsung HCN473W 47" Rear Projection...
Bright shadows
Is this a convergence problem? Did you try adjusting the convergence? IF the bright shaddow is also colored, that might be it. See this discussion:
http://www.fixya.com/support/t543966-curved_red_lies_top_bottom_some_double
May 13, 2008 | Samsung HCN473W 47" Rear Projection...
Power problem
require your complete model number for the rear of the unit,please
Mar 19, 2008 | Samsung HCN473W 47" Rear Projection...
Samsung television problem
the deflection/ convergence board assy. comes as a complete board assy. call yor local dealer or tv tech.
Jan 09, 2008 | Samsung HCN473W 47" Rear Projection...
TV turns on but no picture.
Just had the exact same problem. A Technician from an authorized Samsung service center checked mine and said the convergence unit was gone and it does not allow the TV to turn on. He demo-ed by turning the convergence off and the TV turned on but the picture is very poor and out of focus. He also told me a need a blue tube and other parts for a total cost of ~ $800. No impressed as this TV is only 4 yrs old and is now worthless.
Aug 23, 2007 | Samsung HCN473W 47" Rear Projection...
Samsung HCN473W 47" Rear Projection Television Logo
771 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
