Question about Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour
Water fountain will not stop running after letting go of push bar
    New Friend:
Defective button?
Posted on Mar 22, 2017
What is a drinking fountain?
A drinking fountain, also called a water fountain or a bubbler, is a fountain designed to provide drinking water. It consists of a basin with either continuously running water or a tap. The drinker bends down to the stream of water and swallows water directly from the stream. Modern indoor drinking fountains may incorporate filters to remove impurities from the water and chillers to lower its temperature. Drinking fountains are usually found in public places, like schools, rest areas, libraries, and grocery stores. Many jurisdictions require drinking fountains to be wheelchair accessible (by sticking out horizontally from the wall), and to include an additional unit of a lower height for children and short adults.
Jul 03, 2013 | Water Dispensing & Filtration
GroundFOS water pump won't stop running after replacing PVC pipes
you may have to blead air from the water lines. air pokets will not let your pump regulaet. as your pump feeds water into the filter and all your house hold pluming it must reach a set presher. if ther is air trapt in the sistem it can not build enouph back presher to force the pumps PSI regulaeter switch to ingaidge. air is lighter then water ther for thes to difrent forces pushing against one another couses a flucksuaition and can not regulaet. blead all lines from the pump to all outlets"fosets,spikets and filltering sistem. let pump run while going to all outlets one at a time opening and closeing "cold side first" them to releave the air from the lines. donot forget eny outside fosets this should solve the problem. thank you for leting me help you today .
Feb 17, 2013 | Grundfos MQ3-45 1 HP Pressure Booster...
My fountain stoped working...
If it is the kind of fountain that you can open up and clean etc, you should do that. If it is a pet dish there is a good chance that the small pump inside that pushes water from the bottom to the top has gotten clogged up with pet hair. You should try opening it up, finding the pump, and if there is a build up of pet hair, clean it out and see if that fixes it. You should also be able to watch the pump working after cleaning it out to see whether it is still pumping or whether there may be another issue like a clogged filter elsewhere.
In the meantime, turn off the fountain and unplug it, as having the pump running but not able to **** in water will burn it out.
Jun 20, 2012 | Petmate The Cat Mate Pet Fountain -...
Fountain pump motor runs but no pressure to push water
You can try to force prime with a garden hose. Put the hose in ether side suction or discharge.
Jul 07, 2010 | Little Giant Submersible Fountain Pump
I bought a pump for my fountain 4 months ago, it stopped working
This sounds like you should check your suction pipeing again and with fish be sure to get a screen for it. Then also check the impeller on the pump to be sure nothing inside it. You will need to open the pump to do this. If it has been working their is probally nothing wrong with the pump itself.
Dec 14, 2009 | Aqua Garden
Water pressure is low on the elkay fountain
if you mean the amount of water that comes out of the bubbler head....you can adjust that by accessing the push button cartridge and turning it to adjust how far it is pushed.
Oct 18, 2009 | Elkay EZS8-L Single-Level Wall Mount Water...
Battery icon flashing
Your Stator shorted out and is charging to hi, 17-18 volts. Turn your key off, put your brake on (on the left handle bar) lock in place. Push your override (yellow button on left handle bar) wait about 5-10 seconds, now turn on your key and start the bike. Keep pushing the overide button once v2.1 goes away and you'll get into the voltage of the bike. rev it up to 4 or 5000 rpm, what is the charge, my guess it is around 17 or 18 volts. rebuild your stator
Sep 05, 2009 | Polaris ATV
My Maytag side by side refrigerator's water dispenser won't stop
Below is a picture of the fountain parts. I believe the controls inside the fountain are defective and will need replaced. Temporarily disconnect the control valve to the Fountain control plug this will allow the ice maker to continue to work. Let me know if you need more help and assistance to solve this problem. Below is a link to my site, email and a photo of the parts. Thank You, Sea Breeze appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://www.servicematters.com/maytag_library/docs/16010154.pdf
May 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water fountaian will not work
The curcuit should be simple. The pump is the heart or this system it draws water to the pump(if it can't then the hose is plugged, or damaged) or the pump is bad. If the pump is working then it should be pushing water to its destination. if the water comes out the pump but wont or cant push the water to its destination then the impeller is bad.
Apr 26, 2009 | Beckett Water Gardening Beckett 7124110...
Elkay Water Cooler ADA Wall Hung 8 Gallons Per Hour Logo
462 people viewed this question
Top Elkay Plumbing Experts
jdthefixer
Steve Wood Plumbing...
Level 1 Expert
Are you an Elkay Plumbing Expert? Answer questions, earn points and help others
