How to load a swingline 113 - Office Equipment & Supplies
How do I load staples in model 520e
Hello, Go to this website for a manual or call cust. support on this website. Swingline Manuals Swingline
Oct 23, 2014 | Swingline 520E Electronic Stapler Black
900XDN-C SWINGLINE HIGH CAPACITY HEAVY DUTY STAPLER OPERATIONS MANUAL
auto parts store sells a pick with straight on one end and 90 degree on other end.
This should be slender enough to pull staples out.
Mar 27, 2013 | Tools & Hardware - Others
How to load a swingline optima 40 desk stapler
pull the top away from the center section this should open the unit
Aug 09, 2012 | Swingline Office Equipment & Supplies
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a swingline model #690 - after loading with new staples, it does not staple. It is plugged in and makes a sound like it's stapling but does not release a staple.
1. Make sure you have the correct staples for the machine. The type appears to be:
Swingline 50050 Cartridge Staples, Chisel Point, 1/2"" Crown, 3/16"" Leg, 5000 Per Box High-quality Swingline cartridge
2. Check the cartridge to make sure there are no visible jams.
3. Contact the manufacturer at http://www.acco.com/swingline/, or
Repair Service/Technical Support:
Phone: 800.790.7787
Apr 18, 2011 | Swingline Portable Electric Stapler
Instructions on how to load a swingline heavy duty stapler.
You pull up and back on the stapler head. Then pull out the spring that keeps the staples loaded. Be careful as the spring is very strong. Then put in the staples and put the spring back in behind the staples.
Aug 13, 2010 | Swingline Heavy Duty Stapler 30 160 Sheet...
44 people viewed this question
k24674
jasbo
jasbo
