Question about Defiant Locks & Locksmithing
I bought a Defiant Keyed Entry 881 996 Lock yesterday. On the package, it has, adjustable backset fits both 2 3/8 in or 2 3/4in. I have a interior door, that is 1 3/4in. Can this assembly be used, on this door? Thanks Joe
2 Suggested Answers
  • 25 Answers
SOURCE: lost keys to my Entry door lock
Visit your local Home Depot and purchase a Kwikset re-keying kit. They're inexpensive and work fine but stay alert and follow the instructions properly. This kit comes complete with proper pins as well as new keys. Good Luck!
Posted on Apr 24, 2008
Lost manual to program defiant daylight adjusting indoor digital timer
videos and text manuals.
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer ...
? 16:31
https://www.youtube.com/watch?v=yxZKNVddNU0
Jun 24, 2015 - Uploaded by Jasco Products Company
49814 Program Guide Defiant Daylight Adjusting Indoor Digital Timer. Jasco Products Company. Loading ...
Defiant Daylight Adjusting Indoor Digital Timer with Motion Sensor ...
https://www.homedepot.ca/.../p.daylight-adjusting-indoor-digital-timer-with-motion-s... Easily automate indoor or outdoor lights with the Defiant Daylight Adjusting Indoor Digital Timer. Program up to 7 on and off times per week. Auto adjusts to ...
DEFIANT 469-637 QUICK START MANUAL Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Defiant Manuals > Timer View and Download Defiant 469-637 quick start manual online. DAYLIGHT ADJUSTING INDOOR DIGITAL TIMER. 469-637 Timer pdf manual download.
[PDF]Home Depot Defiant Timer - A-1 Electric Co., Inc.
www.a-1electricco.com/technical/timers/defianttimerprogramming.pdf We appreciate the trust and confidence you have placed in Defiant through the purchase of this daylight adjusting indoor digital timer. Visit us online to see our. defiant daylight adjusting indoor digital timer Google Search
Mar 13, 2017 | Hardware & Accessories
I bought a DEFIANT KEY PAD DEADBOLT.
Usually you just take it apart and turn everything around, the keypad would be turned over and the bolt would be removed and turned to the reverse of where it was.
If it is the type below, I am thinking you would remove the deadbolt part and turn it and then there must be something inside that reverses the throw of the bolt. No instructions with it?
Defiant Electronic keypad Deadbolt Satin Nickel The Home Depot Canada
Nov 11, 2015 | Defiant Stainless Steel Ball Entry Knob...
How to install new door lock
For a residential door, you may choose either 2 3/4" (70 mm) backset or 2 3/8" (60 mm) backset. Some locks are not adjustable.
Choose the backset required for the lock. Check the thickness of the door. Standard installation height is 35-36" above the floor.
Bore a 1" diameter hole into the edge of the door and a 2 1/8" hole through the face. A drilling jig helps align these two holes. If you measure and mark the holes carefully and drill accurately, it can be done without a jig, but for about $20.00 the jig helps avoid lock alignment problems or possibly trashing a door. Follow the instructions for the jig and the lock manufacturers instructions.
Jul 09, 2014 | Ace Hardware Ace Door Lock Installation...
Programming code will not work
I work for factorylocks.com. We get programing questions all the time for Schlage FE575/595. The factory default programming code and PIN codes are on a sticker stuck to the inside of the front housing of the lock. You will need to take the lock off of the door to see this sticker. Once you have done so, reset the lock back to the factory defaults and reprogram the locks to your settings using the programming instructions you can find here http://www.youtube.com/watch?v=z8BgHP712eg
Feb 03, 2013 | Schlage FE595 Plymouth Electronic Keypad...
Schlage keyless lock lost 6 digit code and no sticker inside either
You will need to take the keypad look off of your
door and record the 6 digit programming code and the two factory
default PIN codes. You then need to perform the factory reset to
erase any codes and restore the lock back to the factory defaults.
This procedure is outlined, as well as the programming of the device, in the attached instructions.
http://www.factorylocks.com/PDFs/Programming%20Instructions.pdf
Regards,
Leslie
Factorylocks.com
877-345-6257 (877-34-LOCKS)
Jan 13, 2013 | Schlage FE595 Plymouth Electronic Keypad...
You can shake front door when locked and the door is loose not tight
It sounds like the distance between the lock in the door and the strike plate in the door frame is barely enough to meet securely. Review the lock installation sheet because it MAY be possible to adjust the "backset" for your lock. You did not mention your brand of lock. For example,
Review Steps 1 & 2 of instructions for the Powerbolt:
http://www.weiserlock.com/PDFs/instructions/Electronics/Powerbolt.pdf
Or watch this excellent installation video for the Schlage BE365, at about1:58 minutes into the video you will see how to adjust the backset:
Go to
http://consumer.schlage.com/Service-Support/Pages/InstructionsandManuals.aspx#2
Then click on "Installing your BE365 Keypad Deadbolt" video.
Many brands of lock have a similar backset adjustment, and you may have your set too short.
If yours is all ready set for the 2 3/4" backset, then you need some carpenter skills to close up the door gap.
Sep 28, 2012 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Deadbolt backset diagram
Installation requires either a 2 3/8" or 2 3/4" backset. the diagram you requested is within this installation & programming download, which includes how to adjust the lock for either backset:
http://consumer.schlage.com/Project%20Documents/P515-858.pdf
Note that this is a PDF file, so if it doesn't open for you, you need to install a PDF reader program on your computer such as Adobe Reader:
http://get.adobe.com/reader/
Apr 08, 2012 | Schlage BE365-CAM BE365CAM716 Aged Bronze...
Keyed door lock is falling out
Thanks for choosing FixYa. You may have to replace the entire lock unit. Are you talking about the outside door lock? It may just new fitted back in. I am not familiar with this type, but you will have to get to it to know for sure, which would be through the interior panel.
Jan 24, 2012 | 2004 Infiniti G35 Sport Coupe
Too long backset on new Door Knob for older home's door
You can get a variety of backsets at a GOOD door/ window company.
You may also want to look closely at the lock bolt again, because some of them come with a backset adjuster. Some of the Schlage and Kwiksets will allow you to twist the barrel and change the backset...
Apr 15, 2009 | Hardware & Accessories
Locks & Locksmithing Logo
121 people viewed this question
Top Defiant Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Defiant Lock and Locksmithing Expert? Answer questions, earn points and help others
