Question about Daewoo Refrigerators
Daewoo frg1830 fridge not cold loud freezer fan
Trifect7
  • 57 Answers
SOURCE: refridgerator not very cold
It could be some many things, to save time let me give you this check list:
Do what you feel qualified to do.
If you found this helpful please Vote. Good Luck!
Posted on Mar 04, 2008
SOURCE: Hotpoint Mistral Frost Free Fridge freezer - fridge not getting cold
We have just had to call out an engineer to get our 1 1/2 year old Hotpoint Graphite Frost Free Fridge Freezer repaired. The fridge had almost entitely stopped cooling even when on high. I was amazed at how easily the problem was sorted. The engineer removed all the basktes from the freezer to access the screws on the inside backpanel of the freezer. Once this panel was removed it was clear that the so called Frost Free doesn't really mean what it says. The ice need to be melted with a bit of simple care. It is obvious that with a bit of care it is easliy a diy job BUT PLEASE BE CAREFUL AND READ THE NEXT PART BEFORE YOU BEGIN TO REMOVE THE ICE> The ice forms around variouys pipes etc and he usecd a screwdriver to help release the ice quicker than waiting for it to defrost and he also used a simple hairdryer to help speed up the process. He had a ntowel and a basin to take care of the water. Next time I would have no problem doing this myself but I would need to leave it a little while to defrost and NOT USE A SCREWDRIVER as I am sure somehow I would puncture a pipe or the wall of the freezer itself and I am quite used to doing the odd bit of DIY. On a difficulkty scale of 1 to 10 with 10 being difficult I would rate the job as about a 3. Hope this helps anyone who reads this about £70.
Posted on Dec 27, 2008
SolutionGuy
  • 331 Answers
SOURCE: Frost in frostless freezer, fan not blowing into warm fridge
There are 2 things that cause these to not defrost. Kinda like the "Achilles heel" of GE fridges. The first one is the Defrost heater itself. And the second is the evaporator thermister (GE calls it a "sensor"). They are both very easy to replace. The part numbers are; WR51X10101 (heater) and WR55X10025 (sensor). If you don't have a local appliance parts retailer, just plug those numbers into a search engine. I highly recommend getting both parts because if the sensor hasn't failed yet, it will. The same goes for the heater...
Now for the fun stuff... Turn the temp knobs all the way counter clockwise to kill power to the fridge. Unload all the food from the freezer and remove all the shelves and the basket. Remove the screws that are holding the evap panel (the flat panel on the back wall, it's about 2 1/2 ft tall). Remove the panel to expose the evaporator. You'll see the heater at the very bottom of the evap connected by 2 screws, remove these and pull the heater out. Your new heater comes with instructions on how to install it.
After you have done that, look at the top of the evap. On the left, you'll see a little white sensor clipped to one of the evap tubes (shiny little clip), that has 2 wires feeding it. Remember which tube it's clipped to then unclip the sensor and pull it toward you. Snip the wires right at the base of the old sensor and completely remove it (leave the wires in there). Now separate those 2 wires and strip about 3/8" of insulation off. At this point, you are ready to follow the instructions that came with your new "sensor". Oh! and if it's all frosted up on the evap? Take this time (before you re-install the panel) to use a blow dryer and melt it away. All that'll be left to do is rebuild it.
There ya go! Job completion time= ~45 minutes. Easy breezy, right?
If this has been helpful, please don't forget to rate my solution. Thanks!
SG
Posted on Apr 05, 2009
  • 28 Answers
SOURCE: Hi i have a hotpoint mistral plus fridge freezer,
hi is this the frost free version ??? if it is which i think it is it could be a fault with temp module{frost free have electronic modules to control the system rather than a old fashioned bog standard thermostat inside the fridge} the fans should be controlled by the module in case of frost free models it could be the module which is playing up
Posted on Jul 23, 2009
projdoc
  • 2237 Answers
SOURCE: My Daewoo FRS2021IAL has a warm fridge
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Posted on Aug 27, 2009
My daewoo fridge freezer is freezing food I the fridge on every shelf
Turn down the cold control there can be 1 or 2 if 2 one is main electronic the other just a baffle that controls how much cold air in freezer is allowed into fridge that is be pushed by the fan located in freezer. Cold is only made in freezer then does a circular tour as it leaves cold in freezer moves top 2 bottom then as its warmed it enters freezer to do it all over again . Adjust baffle and or control in this unit it may show 0 or off but there seems to be a lot of movement available before it does turn fridge off. Ive had on a few occasions had how the shelf's are arranged deflect the or mess with the cold airs intended route.
Mar 16, 2017 | Daewoo Refrigerators
Why doesn't it freeze or make ice?
The freezer fan motor is running slow, replace this part, this is a common fault
Ian
Aug 14, 2015 | Daewoo Refrigerators
Daewoo side by side fridge freezer FRS-U201CW-N186. Freezer is not self defrosting and fridge isn't maintaining a cold temperature
start with locating and cycling the defrost timer switch, generally found in the refrigerator side. The timer controls a heating element designed to melt off ice build up on the interior freezer coils. if the timer is bad, ice will build up, blocking air flow to the refrigerator section (making it not cool) and eventually build up enough so that the internal fan actually hits ice, making unusual noises. most timers can be manually driven with a flat head screwdriver, do it with the power connected, when you reach the defrost cycle you will hear the fans and compressor shut off, and you should be able to feel warmth on the back panel in the freezer after a few minutes.
if you find the timer isn't working properly, it is not difficult to replace, take your time, take pictures as you go along so reassembly is easier, and of course have the frige unplugged when you do it.
Sep 14, 2014 | Refrigerators
My Samsung RS21DPSM is not freezing, the fridge is working and the fan in the fridge is not loud. The freezer is not freezing.
Check the condenser fan in the compressor department. The fan motor is know to fail. The refrigerator and freezer temps will be cool but not cold. I would start there.
Apr 02, 2014 | Freezers
Daewoo fridge freezer frsu201a1 not getting cold
ive just defrosted my freezer, at what setting should I put it back onto and should i leave it at his setting? the settings are 1 to 5 thanks
Dec 18, 2012 | Refrigerators
DAEWOO FRSU20IAI FRIDGE FREEZER NOT FREEZING AT THE TOP BUT FREEZING AT THE BOTTOM AND FRIDGE IS NOT COOLING
I'V JUST HAD THE SAME PROBLEM AND IT WAS THE
EVAPORATOR FAN MOTOR . TOOK ME A WHILE TO FIND OUT BUT GOT IT SORTED . EASY FIX THOUGH .I FOUND OUT IF THE COMPRESSOR IS RUNNING THE EVAPORATOR FAN MOTOR SOULD BE RUNNING ALSO, OPEN THE FREEZER DOOR AND HOLD THE LIGHT SWITCH IN YOU SHOULD THEN SEE THE FAN SPIN . IF ITS NOT ITS BROKE. BEWEAR THOUGH AS MINE SPUN AFTER SWITCHING THE SUPPLY OFF FOR 24 HOURS BUT AS SOON AS THE FREEEZER WAS COLD IT STOPPED ALL TOGETHER AGAIN . MOTOR MUST OF BEEN BREAKING DOWN AT A CERTAIN TEMP!
Nov 03, 2011 | Daewoo Refrigerators
The freezer compartment of my daewoo FRN-U20DA is not cold enough and the ice is melting. The fan does not come on and there is no fault indicated on the display panel.
when the fan is not working. you cannot expect an ice cause the fan is to drive the cold to become an ice and to maintain the coldness.
Jun 23, 2010 | Freezers
Aug 26, 2009 | Daewoo Refrigerators
Daewoo Fridge Freezer not getting cold
Possible problems are a bad evaporator fan motor or a defrost problem. If the back panel in the freezer is frosted up then it is a defrost problem. If no frost listen for the fan in the freezer. If you don't hear it then it may be the problem. Not circulating the cold air.
Oct 04, 2007 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Refrigerators Logo
Top Daewoo Refrigerators Experts
jasbo
jasbo
john h
John Tripp
John Tripp
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
