Question about Honda GX200-QX2 3/4" Horizontal Shaft 6.5 HP Engine
Will not take full throttle - Honda GX200-QX2 3/4" Horizontal Shaft 6.5 HP Engine
My troy built riding mower won't run full throttle it only run at about half throttle
if it runs good at half throttle, it just wont throttle up it sounds like the throttle cable has slipped. you might try to adjust it to get full throttle back .but if when you turn it up to full throttle and it dies then you have a choke, carburetor, fuel line, fuel filter or fuel tank problem. hope this gives you an idea.
Mar 29, 2016 | Troy Garden
Holden barin auto not changing down
Check the throttle linkage and cable to ensure that full throttle is reached by the throttle vale and throttle position sensor if that is OK check the detent switch to ensure that it operate4s on full throttle
Feb 16, 2016 | Holden Cars & Trucks
Where is the rpm and idle screw located on a 2005 Craftsman riding mower
place throttle control to full throttle. loosen the clamp on the throttle cable at the carb control. pull the cable tight and retighten the clamp. That is your adjustment for full throttle. The idle screw is located on an external tab on the end of the throttle shaft.
Sep 01, 2014 | Garden
Replaced head gasket now vehicle revs to full throttle when started
check your throttle postioning sensor or just see if when you replaced the gasket if you moved the throttle cable out of position
Feb 15, 2013 | 1999 Jeep Cherokee
Cub cadet lawn mower suddenly decreases power at full throttle
check the spring tension on the carb linkage
May 11, 2012 | Garden
It cuts out at full throttle.
Check the muffler and air cleaner for plugging. Try turning the H jet needle CCW about 1/2 to 3/4 turn which should make it 4-stroke at full throttle. Proper setting is for the engine to 4-stroke at full throttle, but immediately 2-stroke when cutting. (CW turning of H makes it leaner) See a Poulan servicing dealer for a rebuild kit. Be sure to check the fuel filter in the tank for plugging. Hope this helps!
Apr 07, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Only runs on full throttle
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Jun 19, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Throttle not working correctly
hey voyiager i understand your issue so my advice to just take back to where you got and explain to them more what is happend better then us telling you what to do because we dont want to give bad advice ok thanks
Sep 25, 2008 | Video Game Consoles & Games
Honda GX200-QX2 3/4" Horizontal Shaft 6.5 HP Engine Logo
22 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
