Question about Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector
Dlp nview projector help
I have a d450 projector and when i turn it on, after about 5 seconds the lamp turns off but the projector stays on??? Anyone know what would be causing this?
  • Anonymous Oct 18, 2007
    anyone????
  • Mitchzac Jan 01, 2008
    I have the same problem...did anyone find a solution... i feel like its the lamp but i could be wrong...J
  • 3 Answers
The unit is reading hot then turns light off. blow out any dirt you can see, and re try. If that does not help then you have an internal component problem.
Posted on Jan 13, 2008
SOURCE:
BenQ
Check the bulb and/or bulb fan for proper operation.
Aug 03, 2017 | BenQ MP523 DLP Projector
How do I reset lamp hrs on benq 6210
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
Feb 14, 2011 | BenQ PB6210-DLP PROJECTOR XGA Multimedia...
Hi there. I've got a benq mp721 which i've just changed the lamp on. the problem is: how do i reset the lamp timer?
Turn On projector, press EXIT and Up Arrow buttons on projector for 5-6 seconds, lamp hours display will appear, press Auto on projector or its remote to reset lamp hours to zero, wait 5-6 seconds to display will get disappear itself.
Thanks.
Jan 20, 2011 | BenQ MP721 DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
Projector shuts off
try reseting the lamp timer and then replace the lamp if it works
May 05, 2010 | Planar PR3010 DLP Projector
Unlock Sharp XR-10X-L Notevision Proj. says keylock function on
According to pg. 45 in the owner's manual, you turn Keylock function ON by holding down the ENTER key on the projector for about 5 seconds while the projector is being turned on.
To take the Keylock off-- Hold down the ENTER key on the projector for about 5 seconds. If the projector is in standby mode, you can release the keylock by holding down ENTER and STANDBY/ON keys simultaneously for about 5 seconds.
Apr 27, 2010 | Sharp XR-11XC DLP Projector
Projector turns on but does not stay on - turns itself off after apx 30 seconds
are any of the leds blinking? how many times? what color? this will tell you the problem. do the fans stay on when the lamp goes out, or do they shut off too? if the fans stay on, it could be the lamp, the ballast, or it's overheating. if you have a dlp projector, it could be the colorwheel. if the fans go out too, it's the power supply. you might need to send it in to an infocus service center. try av solutions in ny. they're really good. www.avsolutionsny.com
Dec 07, 2009 | ASK Proxima Office Equipment & Supplies
Projector will come on but lamp will go out
still too warm. it need to cool down more. could also be a ballast issue. if the caps are drying out, a boost of power could overload it and it'll shut down.
Aug 06, 2009 | Nview Z215 10.4" LCD Panel with Video(16.7...
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Projector won't turn on after I replaced the lamp
re insert the lamp and check your connection. if that does not work then replace lamp or have lamp checked.
Dec 03, 2007 | Nview Z215 10.4" LCD Panel with Video(16.7...
Nview Z215 10.4" LCD Panel with Video(16.7 Million) Z215 Multimedia Projector Logo
Top Nview Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Marvin
Marvin
Are you a Nview Office Equipment and Supply Expert? Answer questions, earn points and help others
