Question about Senco PC1010 1/2 HP 1 Gallon Mini Air Compressor
Pc1010 senco My compressor only goes to 50 lbs. I just replaced pressure switch and all parts attached. What do I look for.
3 Suggested Answers
SOURCE: My Senco PC1010 compressor keeps on running, it
Mine was doing the same thing. The pressure regulator had failed. I just removed it until I get around to getting a replacement.
Posted on Oct 04, 2009
leroywolff
  • 42 Answers
SOURCE: Where can I buy a new pressure regulator for my
Normally these pressure switches are universal... Granger's is a good place to get parts like this.
Posted on Nov 05, 2010
How to clean the air filter on my senco PC1010
just unscrew or lift off the cap.
dust out and replace
Sep 27, 2016 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
I have a SENCO PC1005 compressor with a Condor MDR 21-EA/11 pressure switch. When the tank reaches full Pressure (120psi) and the switch cuts out the small in line valve that comes out of the bottom of...
I would talk to senco, they can probably provide you with a parts diagram or a tech service rep to guide you through the problem. I agree that the problem is probably that valve, but I couldnt tell you what its called.
Jul 17, 2011 | Air Tools & Compressors
Senco air compressor pumps up..when it reaches full pressure it shuts off and then something under the electronic box opens and discharges all of the air.
That is the safety relief valve which means it has gone bad or you need to turn back the high pressure setting about 5 t0 10 psi. When this happens again there should be a small pin in the middle of it that has a metal ring through it. When it goes off push on that pin and if the air coming out stops or shuts off then you need to turn back the psi if not the valve needs replaced.
May 09, 2011 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Where can I buy a new pressure regulator for my Senco PC1010 Compressor?
Oct 29, 2010 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
Wont air up tank pressure. motor runs & tank pressures to about 25lbs
below the pressure switch is a unloader valve which has a tendency to leak, undo that line and block it off, if this works you probabaly can leave it blocked off.
Dec 02, 2009 | Senco PC1010 1/2 HP 1 Gallon Mini Air...
My Senco PC1010 Air Compressor just quit and won't power on, any idea what could be wrong?
on a compressor by the motor or on the pressure switch there will be a overload switch which may have tripped out push this back in and try it it is a black button pocking out the motor or switch buddy get back to me if this doesnt work budd
Sep 12, 2009 | Senco FP18 FinishPro 18 - Gauge Brad...
SENCO SHF 50 floor nailer won't consistently sink cleats
Some Senco tools reqire oil.  there is oil specially designed for tools.
Aug 01, 2009 | Senco SHF50 2" Hardwood Flooring Nailer...
Once compressor reaches 125 lbs. pressure, the relief valve opens and releases pressure. the motor then tries to engage but cannot come to full speed because of back pressure I am trying to find and...
Generally, the safety/relief is set to 140 to 160psi. The pressure setting is stamped on the side of the valve. Replace the valve if it will not hold stamped pressure(cost about $6 at Lowes Lumber).The pressure switch is usually set at the factory to 120 - 130 psi. The unloader part of the pressure switch will not release backpressure unless it reaches set cut-off. The 1/4 inch line attached to the pressure switch connects to air discharge tube at the intank checkvalve (brass valve). The safety valve should very rarely release pressure, only when pressure switch malfunctions and allows pressure to reach up to 160psi. The tank will hold over 300psi so dont worry about the 160psi safety. I am not sure about your exact model number or brand, however most small compressors work the same and share similar parts. For manuals to other similar compessors to to www.dewalt.com. Here you will find manuals to dewalt and porter cable compressors. I prefer to use generic replacement parts from www.grainger.com or from Lowes Lumber. These parts will cost less than factory replacement. If you need to replace the pressure switch, use SquareD brand from grainger. Watch fitting sizes and pressure range. Good Luck on your repair.
Apr 03, 2009 | Northern Industrial 2 Hp Twin Tank...
Senco PC1010 1/2 HP 1 Gallon Mini Air Compressor Logo
54 people viewed this question
Top Senco Plumbing Experts
Paul Carew
Tom Chichester
Are you a Senco Plumbing Expert? Answer questions, earn points and help others
