Question about Microwave Ovens
Kenwood k30css10 fan not cutting out
The cooling fan on my microwave does not stop.its on continuously
How do I turn off the cooling option on my Novamatic microwave?
The word COOL is displayed when the microwave goes into a cooling cycle. The cool cycle is a feature that ensures the operating components of the microwave (Inverter and Magnetron) are cooled after operation by running the fan inside the microwave.
The cooling function is activated whenever the microwave runs for over 3 minutes or is operated twice within a 10 minute period. The word COOL is displayed to tell you why the fan is still running. You do not have to wait for the cool cycle to complete before using the microwave again, simply enter the cooking operation you wish to perform and the cool cycle will stop and the microwave will perform the cooking operation you have just entered.
May 10, 2018 | Microwave Ovens
I have a russel hobbs CJ/AL28 microwave,the fan has stopped working .I have removed it from appliance and it works independantely .what can be wrong withit?
With a basic microwave there is a minimum of electronics and the fan starts when the oven is switched on and continues working until cooking has finished. In that case the fan is supplied from the timer and the circuit will be simple to check using a multimeter.
The more upmarket microwaves contain a great deal more electronics and the fan will continue to run after cooking has finished until the circuitry has cooled to a predetermined temperature.
In that case the the checking, fault location and rectification is probably completely beyond even most service engineers - who typically would simply replace circuit boards until the fault is cured...
Feb 04, 2018 | Microwave Ovens
Kenwood K30CSS10, combination oven has stopped working. Used to heat some food when used later, light was on, turntable was stationary. Found a broken door latch. Is that the trouble?
If you had a broken latch,that latch was not closing a switch that needs to be closed to tell the unit it is safe to run. So yes start with broken latch.
Aug 19, 2017 | Kenwood Microwave Ovens
My microwave used to continue making sounds even when item was taken out and cooking time completed. I thought this was part of the mictowave cooling down (sim to fan oven). However, this noise has now...
All microwaves do have a "transmitter" tube called a magnetron. It has to put electrical power into microwaves. To do so it gets warm or even hot. As soon as the transmitter is to hot, it must be cooled down. Most of the time it can be cooled without a fan. But as long as the thermostat indicates it is to hot, the system will cool. Even when you switched the system off. Don't unplug the microwave when it is still hot. It could damage the magnetron.
Jan 15, 2015 | Microwave Ovens
Microwave Oven K30CSS10
Possible that the board is not switching off and so it is better to power off and allow the oven to cool down and then try., If the problem persists then it might be due to fault in the PCB, possible that the drive switch is short or the logic out is on. Need to confirm with a voltage check on the board before the board can be replaced. Take care as the microwave might itself be working!!
Aug 09, 2014 | Microwave Ovens
Mmv5165bas vent fan will not stop running
Check to see if there's a relay providing power to the fan. If there is, the contacts might be sticking in the closed position. Assuming that this is an over-the-range unit, disconnecting the vent fan completely might not be a good idea as heat/steam from foods cooking on the range would more likely damage the microwave.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Apr 29, 2014 | Microwave Ovens
We have just purchased a Kenwood microwave/combination oven and are concerned there may be a problem. When the food has finished cooking and the microwave beeps it seems there is a fan or something still...
In most modern combination microwave ovens, if not all, there is a fan that comes on after use to cool the magnetron and cavity down. This is quite normal but if you still have doubts, contact Kenwood's web site and send them a question.
Hope this halps to put your mind at rest.
Nov 27, 2010 | Microwave Ovens
I have Amana Commercial microwave RFS12SW2 The fan keeps running even door is open , it wont stop.
These microwaves are designed to run the fan for a couple mins after the cook cycle to continue cooling the electrical components.
Oct 20, 2010 | Amana RFS12MPS Microwave Oven
Our Kitchen aid microwave works for a minute or so and then stops. It will not run for a while after that at all.....
Likely the cooling fan for the magnetron has failed. Then the thermal cutout on the magnetron will cut off until the magnetron cools.
Take unit for servicing. The fan should not be too expensive.
Jan 30, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave Ovens Logo
32 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
