An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
you should have mentioned that in your original posting. im not a mind reader.
HOw am i suppose to know that. you typed (FULL LIGHT FLASHES). how am i suppose to read your mind?????
I responded to what you typed. that is the way things are here. you type your problem and the expert provides a solution. simple.
You typed (FULL LIGHT FLASHES) and, i addressed the issue.
I DO NOT USE THE CONTAINER. I HAVE A PUMP TO EMPTY THE WATER.
THE ABOVE DOES NOT APPLY TO MY PROBLEM....
Is this the warning light or all lights?
