Question about Yamaha CDRHD1500 CD Player
Wont record cd tohard disc drive - Yamaha CDRHD1500 CD Player
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 58 Answers
Inspect all connections correctly.Refer to it's owner's manual, due to unfamiliarity of Yamaha systems.
Posted on Oct 18, 2013
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Jan 28, 2010 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
The player wont record. All other functions fine including playback and finalising.
You mean it records silence? if it finalises then it does recognise and burn to the disc- so the laser/drive seems to be ok..
If silence, bear in mind there are analogue, optical and coax digital inputs to chose from for record source
Don't forget too these units need the special CD-R audio discs not CD-Rs to record to.
Oct 19, 2009 | Marantz DR-700 CD Player
It wont finalize disc just says disc error
Sounds like a duff (dirty or scratched) disc. Try another one.
Jul 08, 2009 | Philips CDR770 CD Recorder
Recording problem
try using + AND minus blank discs maybe it wont accept cd minus r CD - R Discs so try CD + - R DISCS
May 28, 2009 | JVC XL-R5010 4-Disc CD Recorder
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
CD Burning gets stuck
Try this: : Decreasing the burn speed If the drive is not recognizing the disc at all, skip to Step 4. Decrease the CD writer's burn speed by half to increase the likelihood of a successful burn. Decreasing the burn speed is a quick, easy way of increasing successful disc burning sessions, at the expense of taking more time to create a disc. The following steps are for Windows XP only. For Windows 98 and Me, decrease the write speed from within the software that you are using to write discs (RecordNow, Easy CD Creator)
  1. Click Start , and then My Computer .
  2. Right-click the drive icon, and select Properties .
  3. Select the Recording tab and reduce the Current Write Speed by half (for example, from 16x to 8x).
  4. Click OK and close the My Computer window. Try burning a CD. If the drive fails to create the CD, go to the next step.
Step 4: Setting up disc recording in Windows XP If the computer does not have Windows XP, skip to Step 6. If you are using Windows XP, use the following steps to ensure that native burning is enabled:
  1. Place a blank disc into the drive. NOTE: If the error <drive letter> is not accessible. Incorrect function. " opens, close it and continue using these steps to correct this problem.
  2. Click Start , and then My Computer .
  3. Right-click the writable drive icon, and select Properties .
  4. If a Recording tab is shown, select the Recording tab, select Enable CD recording on this drive , and then click OK . Try burning a disc again. Continue to the next Step if you are unable to burn a disc. If a recording tab is not shown, continue using these steps. Figure 2: Enable CD recording on this drive c00368150.gif
  5. Look for a Recording tab: If the Recording tab is not shown, Windows XP has not detected the drive as a recordable device. Use the following sub steps to enable the Recording tab:
    1. Click Start , Run , and type regedit in the Open field.
    2. Backup the registry: Select My Computer from the list, click File , Export , type a name that you will remember, and click Save .
    3. Click OK , and browse to the following registry key: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning\Drives
    4. Click the Volume key that matches the CD/DVD drive that is capable of writing discs. If only one drive is installed, one volume key is listed. If you have more than one drive, examine the data values (by double-clicking them in the right pane) to find the correct drive.
    5. With the volume key selected in the left pane, double-click the Drive Type value in the right-pane. Figure 3: Drive Type registry value (CDRW) c01367502.jpg
    6. Type the number 1 in the Value Data field if the drive is capable of recording to CDRW discs (including CD-R discs). Type a 2 if the drive cannot write to CDRW discs but can burn CD-R discs. NOTE: A value of 3 indicates that the drive is only capable of reading discs. Changing this value to a 1 or 2 enables Windows to view the drive as a recordable drive.
    7. Click OK , and close Registry Editor.
Jun 20, 2008 | Dell Dimension 4700 PC Desktop
How do you burn a cd on the travelmate 290 ?
Windows XP CD Copy Windows XP has CD-Recordable (CD-R) disc burning support for most CD writers.
8b118c9.gif First set your CD-recording options:
  • Open "My Computer"
  • Right-click your CD-R drive and select "Properties". See figure BK-1.
  • Select the "Recording" tab (if this tab isn't available, your device doesn't support CD burning).
  • Check the box to "Enable CD recording on this drive".
  • Select the drive to hold the temporary files (before the system burns a CD-R disc, the system writes the files to be recorded to an intermediary area - this area must have enough free space to hold an entire CD's content).
  • Select the CD recording speed (Fastest, 4X, 2X, and 1X).
  • Select whether to eject the media after recording.
  • Click OK.
Perform the following steps to record to a CD-R:
  • Insert a blank CD-R disc into your CD burner.
  • Copy or drag the files or folders to be recorded to the CD-R drive, or right-click on the files or folders and select Send To, Writable CD.
  • After you have copied all the files, select the CD-R drive from "My Computer" and you'll see the waiting files as "Files to add to the CD."
  • Right-click the CD-R drive, and select Write to CD.
  • Enter a name for the CD-R disc, and click Next.
  • The files will be written to the CD-R disc.
  • After the system writes all the files, it will eject the CD-R disc (if you chose that option above).
  • Click Finish.
Jun 06, 2008 | Acer Computers & Internet
DVD+RW
dot.gif Unable to read a CD-R or other recordable disc. Question: Unable to read a CD-R or other recordable disc.
Answer: Unfortunately this can be a difficult question to answer because of the amount of potential reasons for this issue to occur. Below is a listing of several steps and recommendations that can be taken to help identify the cause of the issue and/or resolve this issue.
Drivers Verify you have the latest drivers installed for the CD-R or recordable drive. There are numerous driver related issues that may cause a CD-R drive or other recordable to stop reading a CD-R disc. If you are running Microsoft Windows verify your drive is properly detected and listed in Device Manager with no conflicts or errors.
If Windows Device Manager detects an error on the drive or if it has other drives listed in Device Manager with errors on them remove the device from Device Manager and reboot the computer to let Windows re-initialize the drive.
If Windows shows no errors, the above steps did not resolve the issue, or you are running a different operating system check with the drive manufacturer for updated drivers. A listing of disc drivers can be found here.
CD-R disk Not all CD-R disks are compatible with all types and speeds of CD-R drives or other recordable drives (especially earlier CD-R drives). Verify the manufacturer gives 100% guarantee for supporting all drives and disc speeds, for example, TDK discs often give a 100% guarantee.
Pre-mastering/Mastering Software Pre-mastering software can sometimes produce incorrect tracks due to bugs. An incorrect ISO image could be generated, or incorrect sub header codes could be recorded in the case of Mode 2 discs. A good way to check whether the incompatibility problems lie with the originating software or with one of the other causes listed above is to test the same disc on several CD-ROM drives. If one drive is capable of reading the disc back correctly, chances are that the problem was not in the mastering, but is one or more of the other factors listed.
Disc is a recordable disc that the drive or player does not support Verify the drive supports the recordable media you are attempting to read. Below are some situations to watch out for.
  • Old CD-ROM or early DVD drive - Some early CD-ROM drives and Gen 1 DVD drives (some of the first DVD drives released) do not support CD-R discs and/or CD-RW discs. Not only does this apply to computers but also home entertainment DVD players.
  • CD-RW in CD-R or CD-ROM drive - CD-R drives are incapable of reading CD-RW drives. If you are using a CD-RW disc verify the drive is a CD-ROM or CD-R drive is capable of reading the disc.
  • DVD recordable discs - If you have a DVD recordable disc and are unable to get it to read verify that the DVD drive is not a Gen 1 DVD drive and/or that it supports reading the DVD recordable media you are using. Additionally a standard CD-ROM, CD-R, CD-RW, etc drive is not able to read DVD discs.
Disc was created incorrectly Make sure you're creating the disc properly. For example, a common mistake users make when creating audio CD's that they can listen to in their computer, car, or home stereo is burning the MP3 files or other files directly to the CD as a Data disc and not an Audio disc. All this will do is burn the data files to the disc and not create an audio disc. This may allow you to listen to the audio files in the computer but will not allow you to listen to the music in the majority of other CD players unless they support MP3 format.
Disc or DVD contains media content not supported by the player Not all home entertainment DVD players are capable of supporting and playing all the different formats movie files and audio files are stored in. Make sure the format or codec of the movie or audio file you're saving to the CD or DVD is supported by the DVD player. If you're computer is capable of playing the files off the DVD but your home entertainment DVD player is not able to play the file it's likely you're encountering this issue.
Bad disc If after reading through the above recommendations you still continue to have the same issue it's possible that the disc is a bad disc. Try re-burning the disc and if possible try a different type of recordable disc.
Computer DVD Support
Click on the above link should get ya back up and going/Good Luck....Please dont for get to Vote.Thank you.
Dec 15, 2007 | HP Pavilion zd8000 Notebook
Yamaha CDRHD1500 CD Player Logo
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
