Question about Jacuzzi Home
I have a jetted tub that the air switch does not work properly on. It will turn on, then you have to disconnect the line to let air out of the tube for the button to come back out. It will then shut the motor off when you push. Otherwise the button stays in. Its like there is a vacuum is building up in the tube. Getting tired of disconecting and purging line every time wife takes bath.
  • Jacuzzi Master
  • 717 Answers
This actually sounds like you have some calcium built up on the inside of the air button.
Take the trim ring off the air button and pull out the center button.
Get some soft emery cloth and run it around the outside of the center button and well as the inside of the button body then reinstall.
That should solve your problem with a sticking air button.
US Parts Center
Posted on Nov 15, 2013
PartsCenter
  • 125 Answers
SOURCE: kohler whirlpool will not shut off and sounds like about to blow
Sounds as if you may need a new switch to turn the tub on/off. You can find one on our site www.uspartscenter.com
Posted on Mar 04, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 15188 Answers
SOURCE: I have a whirlpool bath in my master bath in my
the air switch should be connected to a switch by the motor the air switch is ur on off and should run from the button to another switch by motor the air switches were put in so there was not live wiring by the tub surface ,the the tub button/switch is like a bellows and pushes air into tube to turn switch on/off
Posted on Mar 05, 2010
SOURCE: Jetted bath tub has stopped working. Motor hums
I had this same problem on my tub, which uses a GE motor. I looked at the motor, and on one end (the end opposite where the water comes out) there is a hole in the middle. In that hole is the head of the shaft, which has a regular screw tip. Turning this turns the motor. I filled the tub, inserted a slotted regular screwdriver and turned it about 10 times clockwise, then 10 times counterclockwise. You should see the whole motor turn. Doing this loosened it up, and then it started.
Once it started, all kinds or residue came out, which was probably why it had stopped working. I hadn't used it for a while.
After getting it running I'm going to run some cleaning solution through it, and make sure I run it more often to prevent this in the future.
I'm not a professional, just a guy trying to fix his own tub. So take my advise with that grain of salt.
Posted on Nov 24, 2010
uspartscente
  • 717 Answers
SOURCE: Our "whirlpool" tub jets do
sounds like it may be either the air button or the air switch (on motor).
pull the pump and plug into an outlet. take a straw and blow into the air switch where the air tubing was connected. If the pump comes on then you know the button. If the pump doesn't come on then you will need to replace the air switch on the back of the motor.
Posted on Feb 08, 2011
Aqua Glass whirlpool, Indulgence collection, pump turns on and works briefly, then jets stop.
First of all, what you have is a WOW pump that has an E-switch for a control.
There is a knob on the top lip of your tub that you turn a 1/4 turn to turn this pump on/off.
There is a small circuit board inside the box on top of the motor. This is likely the source of your problem.
Here is your biggest problem. That little circuit board is not made anymore. We have the e-switch but you will be better off changing out the pump (which you have to do anyway) with a new WOW pump with an air switch and change the switch on the top lip of the tub to an air button which will turn the pump on/off.
Rod
US Parts Center
Apr 13, 2014 | Whirlpool Safety Bath Walk In Bathtub -...
Hytec Kohler Model LM34520 air jet swtich not working. 4 years old and last use, the push button stopped working. Cannot see connection detail at switch/button end but disconnected at motor and and can...
The problem you are experiencing tells me that the air switch in the motor most likely the problem.
This is a latching air switch that operates when the button on the side of the tub is pushed.
The replacement TBS-339 air switch is around $21
Rod
US Parts Center
Jan 06, 2013 | Jacuzzi Home
Feb 07, 2011 | Home
I haven't used the tub in a while and now when I push the jet button nothing happens. No noise, nothing. Fuse breakers are all fine.
Hi, Dayne here,
If your tub has an air switch, it could be the push button, but more likely the air switch. Disconnect the tubing from the button and give it a light puff of air. If it turns on the pump. it is the button. If not, listen and veiw the air switch as you give it a light puff again. If the switch contactors close, the switch is probably good, and it unfortunately may be the pump. Remove and have it tested after looking for a reset or manual over ride by the air switch.
Thank you.
Dec 12, 2010 | American Standard Home
I have a kohler jetted tub and i am having a problem with the air switch. sometimes it works, sometimes it doesnt. sometimes i will have to hit it several times before it works. sometimes it shuts off then...
First, disconnect the air hosing from the back of the pump. Reconnect a new vinyl hose to the back of the pump, and blow into the other end. If your pump turns on/off by doing this, see 'A," if not, see "B."
A. The electronic switch in the pump is good, and there is a problem with the air switch or vinyl tubing. The vinyl tubing could be kinked or the air bellows has failed.
B. The electronic switch in the pump is bad, the capacitor is bad, or some other electronic part of the pump is bad. Buying a capacitor or an electronic switch is of course a cheaper fix than to replace the entire pump.
Hope that helps.
don@crownbath.com
Dec 13, 2009 | Kohler 1107-R-0 ProFlex Bath Tub with...
We have water in the button to turn the jets on so now they won't work. How do we get the water out?
The button is likely an "air switch" which uses a push button to send a puff of air down a tube to activate the switch at the other end. Since 99.9% of jetted tub makers no longer can use an electrical switch mounted at the surface of the tub, due to the possibility of contact with water (shock hazard).
The best way to clear the tube of any water is to remove the access panel (if you have one) on the tub, otherwise, you'll have to gain access from an adjoining room via a wall, etc. You can try to suction the wate from the tube, if you can remove the push button from the tub. I would try using a turkey baster or eye dropper to extract the water from the tube, but as I stated, the best way is to gain access to the inside of the tub components and remove the switch tube that way. It is possible that the push bulb switch has become disconnected from the actual switch mechanism and you'll need to reattach it anyway.
Check your owners manual to see where the switch is located, in case you need to get at the controls via cutting through an adjoining wall. This is why the manufacturer's all say these types of tubs should always be installed to allow access to the inside components for servicing, in case repairs are needed. Just an FYI, it is easier to repair and replace a small piece of drywall 16" by 16" than to have to repair tile work, etc. Of course, it all depends on what you're good at!
You might also want to contact Kohler to talk with one of their customer service people and see what they recommend you try. 1-800-456-4537
Hope you find this helpful and best regards!
Aug 06, 2009 | Kohler Archer 6ft Heated Whirlpool with...
Hot tub jets stopped working
yes my jacuzzi uses air on the suction side to make bubbles. you must have clogged it. how long is tube can you slide a rod in there to check if its blocked?
Apr 16, 2009 | Maax Calla 6042 Bathtub - 101058-000
Home Logo
148 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
armylifer
Level 1 Expert
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
