Question about Edison 40 Pint Dehumidifier
Do i need to add water, to my mcgraw-edison automatic dehumidifer?
Our model JA2M193N Edison dehumidifier runs but doesn't produce water, the coils get cold, but the fan doesn't come on. What do we need to do to fix it?
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 14, 2011 | Edison 40 Pint Dehumidifier
My Edison Dehumidifier does not draw any water. Everything is working great. Model: HDHE405, Type: D40, S/N 14393261 HM
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Aug 22, 2010 | Edison 40 Pint Dehumidifier
Runs, but no dehumidification. 6 months old.
If the room tempature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defost over night.
Only specially made dehumidifers work below a room temo of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 30, 2009 | Haier Dehumidifiers
White powder coming from dehumidifer.
Commercially available cool mist humidifiers sonicate water in order to create a fine mist. In other words, intense vibration liberates millions of tiny droplets of water from the reservoir. This water contains all of the salts of the original tap water. Consequently, over time, you will begin noticing that a fine white powder covers EVERYTHING in the room. This is the same stuff that is trapped in the reservoir of a warm mist humidifier.
its harmful but very annoying !
please rate me
May 29, 2009 | Maytag M7DH65B2A Dehumidifier
LG dehumidifer want i to empty into a sink is there a means of doing this
not sure what the rest of the sentence was/is but here are a few ideas
'a pump' to push the water from the floor into a sink a few feet above.....NO...unless it is sitting on a counter beside
-if you wish to have automatic emptying....then find a floor drain and a short piece of hose to drain through the plug
-if you need more help....just ask
-hope this helps you to fix-ya
Sep 06, 2008 | LG LHD45EL Dehumidifier
Edison 40 Dehumidifier
Old post, but in case someone stumbles in here like i did, I need to point out that if an A/C needs to be recharged, then there has to be a leak somewhere, there is no use on recharging unless you find the place where is leaking.
Jun 01, 2007 | Edison 40 Pint Dehumidifier
No water in tank
have you turned them off, waited a long time, and restarted? if yes, but still problem, both have developed freon leaks. the coils may have "frozen over", verified by looking at them-do they appear frosty? caused by humidistats that are not functioning properly (starting to corrode)...try turning down the stats to allow motors to rest (and frost to melt)
May 27, 2007 | LG DH404E Dehumidifier
Edison 40 Pint Dehumidifier Logo
57 people viewed this question
Top Edison Dehumidifiers Experts
jasbo
jasbo
Gil Shultz
Daryl Gleaton
Are you an Edison Dehumidifier Expert? Answer questions, earn points and help others
