Question about Garden
Sumo chainsaw plastic primer has come out
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: how to replace the fuel primer bulb and fuel lines
I just did a primer bulb not too long ago, but I don't remember what equipment it was on. They are generally easy to replace. First, remove anything that is retaining the bulb assembly, such as cover plate. On my Homelite chainsaw, I simply pried it out with a small screwdriver.
The replacement part itself has two barbed stubs that the two fuel line hoses push onto.
Make sure that you keep the fuel line tubes above the fuel level at all times to prevent leakage.
Posted on Dec 05, 2010
Sumo chainsaw
are you sure you have the fuel lines on properly.
Sep 27, 2013 | Garden
Primer bubble
The primer bubble just pulls fuel from the carb and dumps it back to the tank, to replace it diss connect the two hoses, there are then two small plastic legs on the back, press them both in and the primer will just pop out.
Feb 26, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
How to replace the fuel primer bulb and fuel lines in McCulloch 3516 chainsaw? the fuel primer bulb broke and the plastic lines have crumbled. i need to know how to run the lines from the fuel tank to...
Dec 05, 2010 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
I am replacing a primer bulb in a chainsaw and the lines are gone so i need to find out which line goes where
Leave both primer ports open, then attach the fuel line that feeds the carburetor from the fuel filter to one of the primer ports--pump the primer and if you guessed correctly, it should pump fuel into the primer bulb. That is the primer port that goes to the carburetor output connection. The other primer port connects to a short line that goes back into the fuel tank with no filter. Return the original feed line back to the upper carburetor port. Connect the open primer port to a short line that connects to the carburetor lower port. Be sure to use original rubber lines, not plastic. Hope this helps!
Jun 22, 2010 | Garden
Changed fuel lines
No the primer bulb is connected via the carb generally by a clear plastic line without a filter if it isn't mounted directly to the side of the carb that is.
Apr 12, 2010 | Garden
Primer Bulb cracked Need new one?
remove carburetter air filter cover,two 'torx' screws on top.primer bulb is retained in case by 2 plastic 'ears' push ear[s] in& bulb slides out of case.make note/label 2 fuel lines attached; one 'stem' on primer is longer than the other.replacements can be found @ lawnmower/small engine repair shops.
Oct 10, 2009 | Garden
After removing filter carburator is exposed
Replace entire primer bulb assembly. You might replace hose going to it as well. Extended sunlight kills plastics.
Jun 29, 2009 | Garden
Need parts diag to repair has damaged primer clear
The parent company and what maunuals are available can be found Here:
TalonTools.com.au
http://www.talontools.com.au/html/about_talon.html
These are Chinese chainsaws. I wasn't able to find ANY exploded parts lists. GL
Lou
May 07, 2009 | Garden
Garden Logo
557 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
