Question about Frigidaire FEF336BC Electric Kitchen Range
I have a pfef 375 range and the elements (oven) will not heat up, checked both and power seems to be going to both.Would both elements burn out at same time?
aborcass
  • 2651 Answers
SOURCE: Oven not heating up
can you see the bottom element?? if so usually , its obvious when the element goes bad, youll see the damage.TURN OFF POWER. 2 screws remove elemnet from the front 2 wires, plug in aa new one and your good
Posted on Mar 01, 2008
BNewberry
  • 93 Answers
SOURCE: Frigidaire Smooth Top Range/Oven stopped working
Computer is cooked. Sorry to tell you.
I am a factory servicer for Electrolux / Frigidaire
I replace tons of those clock controls. They shouldn't be $160 though
Any questions about these stoves send me and email.
I will be glad to help you out.
Thanks
Posted on May 23, 2008
  • 112 Answers
Hello all with this oven not working problem!!! I had this happen and I found exactly what causes this to fail. The circuits operate in the following manner... The oven is controlled by a double pole single throw heavy relay (wired as a single pole single throw or simple off/on relay) that supplies power to 2 other relays.. The oven relay is a double pole double throw relay (6 contacts 12 volt coil, ) it is normally open circuit, that is when the main relay turns on the power goes to the oven relay but no further. The other sie of the oven relay is wired to a second relay connected to the broil element that is normally open circuit with the other side of the DPDT relay going to Leg 2 120 volts. So in normal off mode the broiler is connected to the one side of the relay, common is connected to Leg 2 and the other side of the relay is connected to the other side of the oven relay.
SO when you call for the Bake Oven element, the power goes through the main relay to the oven relay, the oven relay clicks and now connects the oven relay to the set of contacts on the broiler relay that is connected to Leg 2- now the oven turns on. When you ask for broil the oven relay turns off and the broiler relay tirns on connecting the broiler to leg 2 (bypassing the oven relay.
I know its long winded but basically to operate the oven the power goes through 3 relays where the broiler only uses 2 of the relays (not the oven relay) Kinda dumb way to do it I suppose BUT the idea is to never have a situation where the oven and broiler can be on at the same time.
Heres what happened with my oven.. the broiler relay failed (broke internally) and the common contact shorted across both of the other terminals momentarily turning on BOTH elements, the sudden inrush of current literally exploded the output contact on the main relay and vaporizing the lead, trace and solder joint.
It was a mess... badly burned.. I found a new relay (omron) to replace the main relay.. but the other 2 were Omrons that I could not find replacements for (12 volt coils is the issue) So I did find some potter brumfield relays that were rated 10 amps per pole so I wired these externally from the timer board (ran wires to them) (doubled up so each relay was using both sides in parallel so it can handle 20 amps) The elements only use about 8 amps each anyways this worked great and since the new relays are on spade terminals with quick disconnects, are easy to swap out of they fry again (doubtful) Its a forgone conclusion these timers are ready to fry at any time and I can almost guarantee the WILL blow.. the relays arent very heavy duty at all... I would not buy another of these.. pretty weak control.. expecially these small relays.
Good luck in your repair.. a new timer was 300 my repair was 50 and WILL NOT fail like theirs did.
Cheers
Dave
Posted on Dec 28, 2008
localwonder
  • 6784 Answers
SOURCE: Both heating elements in the oven not working. I did inspect the h. elements found no burn. thankyou help
Ok, you can confirm element failuer by testing for continuity with a Ohm meter. A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
Another reason, why the elements would not start, might be a defective infinite switch (located behind the control panel, with the burner knob on its shaft). Replace the switch if found defective.
If the elements show continuity, you will need to replace the entire control board(clock, EOC)..
Posted on Jun 01, 2009
  • 35 Answers
SOURCE: Oven Element and Broil both do not heat
you should have 220v between the two terminals of the elements, either the switch is broken or a contact is burned or a feed wire is broken to the switch, check wire diagram and carefully analyze the system while it is "hot" ie... energized
Posted on Sep 17, 2009
The preheat light flashes on my he range and oven does not heat. I have had the sensor checked and its working. What else could it be?
Most likely the heating element is bad. Disconnect the oven from power. You can open the bottom of your oven to expose the heating element and see if there are any signs of burns or melting. If you can, remove the heating element and use a volt/ohm meter to check "continuity" across the element ... it should be a dead short. While performing this inspection, confirm that the wires and connectors leading to the heating element are intact and connected.
Oct 28, 2014 | GE 30" Self-Cleaning Freestanding Electric...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
Element in oven sparked at corner and now will not heat
The heating element burned through -- it needs replacing. Turn off power to oven, remove two screws on heating element mount, pull heating element from wall of oven, remove two screws connecting electric leads to heating element. To install new element, reverse steps. Make sure screws connecting heating element to wires are very tight -- otherwise they will arc.
Charlie
Jan 08, 2011 | Maytag MER5552BAW / MER5552BAQ /...
Oven slow to heat
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
May 10, 2010 | DCS RDS-364GD-SS Dual Fuel Kitchen Range
Oven not coming on/heating up although top plates are working
If the burners are heating up but seem to take along time to get up to heat and your oven doesn't seem to be working you may have only 115 volts of power going to the range rather than the full 240 volts that are needed to power up the bake/broil oven elements.Check circuit breaker(s),check range receptacle behind the range for 240 volts,check for full power at the terminal block on the back of the range where the cord connects to the range.Good luck!
Nov 22, 2009 | Smeg Ovens
Fisher Paykel electric oven doesn't heat in Bake mode
Electric Oven: Repairs and Maintenance Electricranges and ovens are generally easy to repair, because there's not muchto go wrong and there's not much you can do. Most repairs are actuallyreplacements, a matter of unplugging the old part and plugging in thenew. Most of the malfunctions that affect electric ranges involvefaulty heating elements.
Caution: Beforedoing any work on an electric range or oven, make sure it's unplugged,or turn off the power to the unit by removing one or more fuses ortripping one or more breakers at the main entrance panel or at aseparate panel. If the range is fused at a separate panel, this panelmay be located adjacent to the main panel or in a basement, crawlspace, or other location. If there is a grounding wire to the range,disconnect it. Make sure the power to the unit is off.
Servicing Fuses
Ifthe range or oven is receiving power but doesn't work, the unit mayhave its own fuse or circuit breaker assembly. This assembly is usuallylocated under the cooktop of the range. In some units, lift the top ofthe range to gain access to the fuse assembly; or lift the elements,remove the drip pans, and look on the sides of the cabinets. Inside theoven, look to the back to spot the fuse assembly.
Ifthe unit has this additional fuse or breaker system, components such asthe oven light, the range heating elements, the timer, and aself-cleaning feature may be separately fused.
If thesecomponents or features fail to work, don't overlook the possibilitythat the fuses have blown. To replace a blown fuse, unscrew the oldfuse and install a new one of the same type and electrical rating. Ifthe unit has circuit breakers, push the breaker or reset button, whichis usually located on the control panel.
Replacing Range Heating Elements
Whena range heating element burns out, it's easy to replace. But before youdisassemble the range to check or replace an element, make sure therange is receiving power. Here's what you can do:
Step 1:Check the power cord, the plug, and the outlet. Then look for blownfuses or tripped circuit breakers at the main entrance panel or at aseparate panel.
Step 2:Check the fusing system inside the range. If the circuit is broken,restore it. If the range is receiving power, go on to check the element.
Step 3:When the element is cool, remove it. In most ranges, each top heatingelement is connected to a terminal block in the side of the elementwell. To remove the terminal block, lift the element and remove themetal drip pan that rests below it. The element is held by tworetaining screws or is push-fit into the terminal block. To remove ascrew-type element, remove the screws holding the wires. To remove apush-type element, pull the element straight out of its connection.
©2006 Publications International, Ltd.
To remove a range heating element, remove the screws holding the terminal
wires, or pull the element straight out of its connection.Step 4:Test the element with a volt-ohm-milliammeter (VOM) set to the RX1scale. Disconnect one of the electrical leads to the element and clipone probe of the VOM to each element terminal. If the element isfunctioning properly, the meter will read between 40 and 125 ohms; ifthe meter reads extremely high, the element is faulty and should bereplaced.
To test a range element without using a VOM, remove aworking element from its terminal block and connect it to themalfunctioning element terminal. Don't let the test element overlap theedges of the element well; keep the element inside the well, even if itdoesn't fit perfectly. Turn on the power to the range. If the workingelement heats, the suspected element is bad and should be replaced. Ifthe working element doesn't heat, the terminal block wiring or theswitch that controls the element may be faulty. Call a professionalservice person.
Step 5:Replace a burned-out range element with a new one made specifically forthe range. Take the old element to the appliance-parts store; ifpossible, take the make and model information, too. This data willprobably be on a metal tag attached to the back service panel of therange. To install the new element, connect it the same way the old onewas connected.
Replacing Oven and Broiler Heating Elements
Electric oven and broiler elements are often even easier to test and replace than range elements. Here's how:
Step 1:If the oven element doesn't work, first check to see if the range isreceiving power. Don't overlook the fusing system inside the range.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale.
Step 4:Remove the screws or plugs that connect the element to the power.Remove the retaining shield, which is usually held by two screws, andremove the element from the brackets that hold it in the oven. Theelement is usually held in these brackets by screws.
To remove an oven or broiler heating element, remove the screws or pull
the plugs that connect it. Remove a retaining shield and lift out the element.
Step 5:Clip the probes of the VOM to each element terminal. If the element isin working order, the meter will read from 15 to 30 ohms. If the meterreads higher than 30 ohms, the element is faulty and should bereplaced. If the element tests all right but doesn't work, the problemmay be at the terminals. Make sure the terminals are clean and tight atthe element connections.
Oven and broiler elements cannot betested without a VOM. If you don't have a VOM, take the element to aprofessional service person for testing. The problem is usually amalfunctioning element; however, you aren't risking much by replacingthe element without a professional test.
Step 6:Take the burned out element with you to the appliance-parts store tomake sure you get the right replacement part; if possible, take themake and model information, too.
To install the new element,place it in the same position as the old one. Connect it the same waythe old one was connected, using the same screws to hold it in place.Just about all the other components of an electric range or oven(including its door gasket, oven controls, and timer) are virtually thesame as the components used on gas ranges.
Most problems withgas and electric ovens or ranges are easier to fix than you think. Thekey is knowing how the various parts work and when to replace them.
Have a look at these websites to find parts and details :
http://www.appliancepartspros.com/appliance_range_oven.aspx
http://www.gallawa.com/microtech/dataselect.html
Mar 20, 2009 | Fisher and Paykel AeroTech Double - OD302M...
Maytag Stainless Steel & Black Electric Oven won't heat over 140 degrees
on a 220 volts stoves when the electrissity drops to 120 volts thats what it does.so oven element wires most be check for power, if it's getting 220 replace the element.
Sep 16, 2008 | Maytag MER5755QAS CleanDesign Electric...
Preheat issue with a new kenmore electric range
times quoted seem about right and don't suppose your old oven was much different. element ratings don't vary much for same size ovens
Jun 07, 2007 | Kenmore 96212 / 96214 / 96219 Electric...
Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Sep 07, 2006 | KitchenAid KERC507 Electric Kitchen Range
Frigidaire FEF336BC Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
