Question about Samsung 46" Class 1080p 120Hz LED HDTV UN46EH6000
Samsung 46" LED UN46EH6000 screen is black but the backlight flickers no picture no sound, completely unresponsive have to unplug it to turn it back off
  • 192 Answers
SOURCE: LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Posted on Jun 03, 2007
  • 31 Answers
SOURCE: SAMSUNG 46 LCD 1080p series 5 - LE46A557P2FXXU - black screen
the x or y board may be bad in the set. i would say it is the main board.
Posted on Aug 14, 2008
  • 98 Answers
SOURCE: Samsung LNR408DX/XAA Powers on with sound but no picture
I think you need to exchange the Main Board.
Posted on Feb 06, 2009
  • 5097 Answers
SOURCE: I have a 46 inch Samsung plasma HP R4252 picture went black
Probably the power supply that drives the video has gone bad. Samsung recommends the TV go to a service center. If you have some skill and are willing to try, open up the back of the TV, remove the shielding and look at the boards to identify any obvious damage. Leaking or bulging capacitors, soot, scorch marks are the obvious. (Other parts can have bad solder or tiny cracks that are hard to spot.)
http://www.shopjimmy.com/catalogsearch/result/index/q/HP-R4252 has reclaimed parts for this TV. These are parts from TVs that were damaged in shipping and were only run during quality control tests. They list several power supplies for the model so check what part number is actually installed (there is usually a label on the board).
I hope this helps.
Posted on Aug 02, 2010
RyanFanMan
  • 342 Answers
SOURCE: Samsung 46 " lcd backlight dims and brightens by
there is a light sensor that is for the backlight thatg if you refer to your manual you can find out how to turn it off
Posted on Mar 10, 2011
Which part causes backlight flickering / dimming?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 02, 2016 | Samsung UN46FH6030 46" Class 1080p LED...
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
My samsung ln46c630k1fxza 46 inch t v that has no picture or backlights, i replaced the t-con board, that didnt fix the problem. can you tell me how to fix the problem?
Samsung LED TV Model UN46D6400UFxza has sound but ...
? 2:16
https://www.youtube.com/watch?v=s2hLKzdyDWU
Oct 21, 2013 - Uploaded by Clif Venom
Samsung LED TV Model UN46D6400UFxza has sound but no picture ... LCD & LED TV Repair - No Image ...Missing: ln46c630k1fxza
Samsung LCD TV screen went black (audio on, no picture)
Dec 20, 2015 | Samsung Televison & Video
Samsung 46" LED - Screen goes to black every 15 sec and then comes back shortly. Do I need to replace tcon or main or is there something else possibly wrong?
Hi Todd,
Screen goes black means back lights go off. The power supply may not be responsible for this problem. Please check back light on command from main board. Good luck.
Jan 11, 2015 | Samsung " 46"" Class - LED - 1080p - 120Hz...
How to i fix vertical lines on my led samsung tv
Here are a few responses from people with your set and this problem: https://www.youtube.com/watch?v=k8CjoegQolY
Jan 02, 2015 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
Samsung 46 LED get sound no picture
it sounds like your back light inverter has gone. if its a led it could be built in on the power board. so check for bulging or leaking capacitors on the power board.
Jun 24, 2014 | Samsung LN-T4665F 46 in. LCD Television
Samsung 46" Class 1080p 120Hz LED HDTV UN46EH6000 Logo
138 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
