Question about JVC HR-S7600 S-VHS VCR
Tape get stuck when I playback after fast forward the tape
It plays normally if I rewinded the tape a bit after I fast forward the tape (not in playback mode) When I opened the cover, I noticed that the left wheel kept spinning for a while after I stopped the fast forward. Can I fix it by replacing the brake tape for the left wheel? Any help will be much appreciated.
  • Skyver Sep 26, 2007
    I also tried to examine another mechanical problem, but the braking parts are all covered by the tape when I tested it.
    I hope it can be fixed by replacing the braking pad.
    Thanks for your advice.
    Novelist:
    Champion:
  • 254 Answers
Yes, that is a possibility. Also check the mechanism which activates the brakes- is something sticking or broken? A dried or sticky grease can cause the brake mech. to hang up. A broken or cracked lever or slide piece could be your problem too. Late VCRs of the last 10+ years are rather breakable, unlike the older ones which were often built like tanks, comparatively speaking.
Posted on Sep 26, 2007
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
VHS tape is running at high speed when insert it to VCR. no playback..buttons doesnot work.
Check if the fast forward button is more inside than the rest of the buttons. May be its stuck in the ff position. After all they were just micro switches below the plastic buttons strip. The specific ff micro switch may be stuck, if I were you I would try some switch cleaning spray to loosen it. But be prepared that the control ic is busted.
Jun 21, 2014 | Panasonic Televison & Video
TV is on channel. VHS player has tape for playback loaded. Player is on but when PLAY is pressed 5 seconds later it turns off by itself. Model number is DVP3200V/37. Can anyone help, please.
Dirty magnetic head. Run a commercial tape head cleaner through it. You can get one at the box stores. Also, put your tape in a tape rewinder and rewind and fast forward the tape for about 30 seconds. Sometimes the tape ribbon gets wound too tight or is loose. If these fail, then you have to open the unit up and clean the magnetic head manually with some isopropyl alcohol and cotton q-tips. Also, look for capacitors on the power inboard chip that look burned and replace them.
Feb 04, 2010 | Philips VR621CAT VHS/S-VHS playback VCR
Camcorder wont playback recording
Dear Lauren,
You didnt write camera model and make. any how, you need Head Cleaning Cassette for your camera to clean its video heads. Video heads are dirty/ clogged so camera doesnt show picture in playback. Please dont touch video heads physicaly because it may broken easily. always use video head cleaning cassette.
Apr 20, 2008 | Sony Handycam DCR-TRV250E Digital...
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Dec 23, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
Sep 17, 2007 | Onkyo TARW255 Single Dual Cassette Deck
Will not playback tapes
a sony cleaning cassette may clear the gunk from your friend ' s possibly ? bad tapes ( do not rewind it - or the gunk will be redeposited ) ; if still no video , get an estimate to have your heads and guides cleaned . . . professionally ;
Jul 02, 2007 | Sony Handycam CCDTRV118 Camcorder
JVC HR-S7600 S-VHS VCR Logo
178 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
