code p 300 is random misfires and p 0305 is misfire on no 5 cylinder
problem with fuel pressure and/or injectors
code p 1391 is intermittent loss of signal from crank/ cam positions sensors
The ignition coil is causing the misfire. That is causing rich mixture which could case the oxygen sensor issue. You need to work from the ignition issue to the sensor. The reason is if you replace the cat and the engine is running rich it will heat the cat up to the point that the car might catch fire. Oxygen sensors are also prone to fail after about 60 thousand miles.
02856,02817,02881,02892. Try these codes. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
trouble code 0305 is for cylinder misfire.misfire code for cylinder #5 which is what a P0305 code represents. There will have leaking valve cover gaskets allowing oil to contact the boots of the ignition wires and short the high voltage to ground causing the misfire.in this case check whether plug wires, sparkplugs and valve cover gaskets are in good shape .this will help you to determine the cause of your check engine light on.This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
I know this is no help, but I am haveing the exact same problem and I searched and cant find anything about how to fix the problem..I wish I knew what caused it at least
