Question about Canon IMAGERUNNER 3530 Copier
Canon ir 2830 light printing in machine what problem tell me
SOURCE: canon ir 3300 xerox machine display board not working
dispaly and pad is not working who to open it tell me the codes
Posted on May 26, 2009
redzventures
  • 149 Answers
SOURCE: I have an IR-3300 Model xerox machine. It was
The two problems may not be related. Adding toner should not under most circumstances cause copies to become light, unless the toner you are using is of a poor quality - I hope it is a Canon cartridge or quality generic. It sounds as though your fixing film or drum unit may need replacing, or perhaps you need to perform a install procedure. As the 'install - toner - start' option is free, try it first:
First press the head key and then the number '2' and '8' keys at the same time then press the head key again. This will take you into service mode - select 'copier' then 'install' then 'toner' then 'start'. This will run throught a cycle that takes a little while, I think about 599 seconds (sorry for been so accurate but unhelpful but that's what I remember from the display - never converted into minutes but you're welcome to).
But if you are having blurry or even dirty or light copies it may be the fixing film. When the copies are printed, immediately check if you can rub off the toner at all by rubbing the print with your fingers - if so this indicates that the fixing unit is not hot enough or there is not enough pressure - check that the fuser is in properly and that the jam release lever is not engaged.
Lastly, it could be your drum unit that is faulty or worn. Totest this you will need to try and stop the machine in the middle of printing before it reaches the fuser - open the front cover and latch down the transport bed with the green handle - remove the paper gently so as not to disturb the ink in any way and observe the image quality - if it is displaying the exact same symptoms then it is not your fuser and is probably the drum unit or dodgy toner - most likely the drum. However, if the image is fine, then it most definetely is your fuser film (and or perhaps the cleaning roller that cleans the film).
Good luck
Posted on Jul 31, 2009
SOURCE: Describe your canon ir 400 xerox machine error
i have duplexing problem
Posted on Jan 11, 2010
canontech
  • 1219 Answers
SOURCE: copy darkness problem canon image runner 2830
Did you try to clean beneath the copy glass?
On digital machines, when the copy glass or optics are dirty, copy becomes verry light.
How many copies do you have? pres 123 button.
It also could be that you need to change the toner station, by the book it goes 300000 copies.
But I bet on dirty copy glass and dirty scanner assy.Clean the glass with glass cleaner and polish it with dry cloth.
Posted on Jul 25, 2010
Testimonial: "so thanks"
SOURCE: how to set ip address
I need fax facility of my canon ir2830 network machine. pl let me know how to setup for fax in my canon ir2830
Posted on Jan 30, 2011
The copier Ir 2570 its Opc drum in which copier is Equiverant to
The drum for Canon Ir 2570 is also equivalent to this machines: Like Canon IR 2230
Like Canon IR 2270
Like Canon IR 2530
Like Canon IR 2570
L ike Canon IR 3530
Like Canon IR 3570
Like Canon IR 2830
Like Canon IR 2870
Like Canon IR 4530
Like Canon IR 4570
Like Canon IR 3030
Like Canon IR 3025
Like Canon IR 3035
Like Canon IR 4035
Like Canon NPG 25
Like Canon NPG 26
Jul 30, 2017 | The Office Equipment & Supplies
What is a mining of shine E000805-0000 on xerox machin canon ir 2830
I don't have the service manual for this model but on many canon copy machine E805 is a fixing fan error.
Nov 21, 2014 | Office Equipment & Supplies
Error code 0001-0002 canon 2830
Error code 0001 0002 ane par kya kare
Oct 09, 2014 | Canon Ir 2830 Digital Copier
Error codes ir2830 E00020-000
sir mere machine ka page counter reset karna h
Nov 04, 2013 | Canon Ir 2830 Digital Copier
Canon ir 2830 coding out to E000007-0000 - what can correct this can I do it myself
CANON IR 2830 ERROR CODE e0007-0000 SIR PLEASE SOLUTION MY ERROR CODE
MOB.9636327398
EMAIL-M.KCOMPUTER31@GMAIL.COM
Mar 14, 2011 | Office Equipment & Supplies
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
How to set ip address in canon ir 2830 i want network scan in this machine and send me complete information about net work scan
Dec 31, 2010 | Canon imageRUNNER 400S Copier
Canon ir 2830 error code e 490
SIR CONON IR 2830 COMPUTER SE ATTACH HO SAKATI HE
Sep 03, 2010 | Canon IMAGERUNNER 3530 Copier
Canon IR 2830 how do I install drum assy? How do I put in a drum unit for the IR 2830.
A.Removing thr drum unit.
Opem the front cover,shift down the developing assembly lockimg lever to unlock the developing assy.Slide out the left cover,holding the grips,pull out the drum unit.When removing the drum unit be sure to hold the two grips and take care not to scratch or soil it.
B.Cleaning the photosensitive drum.
If the surface of OPC drum is soiled wipe it with a flannel cloth coated with toner.Do not use paper,lintfree or otherwise.
Nov 22, 2009 | Office Equipment & Supplies
Canon ir 2018 ERROR CODE E246
check print controller pcb connection, ram & EEPROM
Feb 26, 2009 | Canon iR 2016i Black and White Copier
52 people viewed this question
old marine
old marine
