Question about Casio FX-115ES Scientific Calculator
Decimal setting floating on casio fx115ES - Casio FX-115ES Scientific Calculator
4 Suggested Answers
  • 7993 Answers
SOURCE: cant get answers in decimal format
To make sure that results are always in decimal format, put a decimal mark (point) at the end of one integer.
ex: 1./2 or 1/2. or 1./2. display as 0.5, so does 1. + 1/2
To convert from decimal to fraction and from fraction to decimal press a b/c
To convert from proper to improper fractions use [SHIFT][d/c]
Hope it helps.
Posted on Oct 04, 2009
  • 7993 Answers
SOURCE: how to calculate the standard deviaition on the
I assume you know the theory. I will show you the key strokes for 1-Var statistics and 2-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to Referable you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
- To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Posted on Apr 05, 2010
  • 7993 Answers
SOURCE: how do i remove MATH deplay on my Casio FX115ES
Press [SHIFT][MODE] to enter (SetUp). Select [2:LineIO] and you will be rid of the MATH Input/Output. You will lose some nifty features, like the stacked fractions, the radicals, but that is your choice.
Cheers.
Posted on Dec 10, 2011
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
May 21, 2016 | Sharp EL-1701C Calculator
Turn Scientific notation off
Press SHIFT then MODE then press either 6 to specify a fixed decimal notation or 8 to specify floating decimal notation.
Sep 16, 2011 | Casio FX-115ES Scientific Calculator
In the bottom of the screen where the answer goes it says 0x10 to the 0 power and i want to know hot to get rid of it
If you want to set the calculator to display a fixed number of decimal digits, press SHIFT MODE 6 then the number of digits to the right of the decimal point. If you want a floating decimal display, press SHIFT MODE 8 then 1 or 2 to select NORM1 or NORM2 mode. Either way, if the magnitude of a number is too small or too large to display normally, the calculator will switch to scientific notation. This is all on page E-8 of the manual.
Mar 16, 2011 | Casio fx-300ES Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
Cant get answers in decimal format, I would like to set up my casio fx83es so that the answer is in decimal format all the time.
Hope it helps.
Oct 04, 2009 | Casio fx-300ES Calculator
I dnt kno how to get the decimals off and the calculator only gives 1 decimal place
dude i just found it out press mode CLR at the top 3 times then press the # 3 at the botton
it should say (norm 1~2?) when it does press the # 2 and there you go!!!!!!!
Jan 11, 2009 | Casio FX-300MS Calculator
Weather casio FX-115ES can solve 5*5 matrix
According to the manual for the Casio FX115ES, the largest matrix it solves is a 3x3.
Sep 06, 2008 | Casio FX-115ES Scientific Calculator
How do I get decimal answers
I had the same problem. To change the output to decimals, do the following:
Go to Math mode, then SHIFT, MODE (set-up), 2 (lineIO). This will cause answers to show in decimal format. I hope this helps.
I was able to find a manual at: http://www.generalmanual.com/Calculators/Casio-FX-300ES-Scientific-Financial-Calculator.htm
Nov 06, 2007 | Casio fx-300ES Calculator
Casio FX-115ES Scientific Calculator Logo
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
