Question about Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
Vertical line on optoma projector - Optoma EP719 XGA DLP PROJECTOR 2000L 2500:1 CONT DVI-D WITH HDCP Multimedia Projector
  • 8 more comments
  • Anonymous Dec 09, 2007
    sax
  • Sameer Shrivastava Feb 22, 2008
    optoma hd70
  • Anonymous May 22, 2008
    mhm
  • Hector_Miami
    Hector_Miami Dec 14, 2008
    I have the same problem (white vertical line about 2-in from left side) ... after only 3 uses in 11 months of ownership ...
    ... problem occurred 1st with VGA-input, tried using S-Video Input which had no problems...for about 2 more uses... then, SAME problem.
    ... at this point, both VGA inputs and S-Video input have the same white line.
    sounds like something in the input board(s).
    Does anyone have a solution ?? Kindly advise...thanks!
  • Anonymous Dec 21, 2008
    I have DV10 model and its have the same issue. Strange enough its start and disappear on its own, so I guess its not a permanet damage on bulb.
    dv10 model
  • gammagraphic Dec 21, 2008
    I get 3 vertical lines on the right side of the screen everytime I turn it on. Tapping the projector on top a couple of times use to fix it but not anymore...
  • Timothy Mott Jan 12, 2009
    I had the same problem occur after I had owned this projector for just a month. Tapping it on the side made it get even worse, which makes me suspect a bad internal connection.  There are several multi-pin connectors inside the unit.
    I sent it in for repair after the first failure and it came back and after using it a month it did it again.  I took the case off and looked at it and put it back together and it worked fine.  Now it is doing it again.
    Guess I will try it again.
  • Anonymous Jan 21, 2009
    same thing happens with my hd70 -- vertical lines at startup that don't go away. i just bought it on ebay. hmph.
  • giantsolutio Mar 09, 2009
    I can't seem to get the cover off. I'm afraid I'll break the tabs. It seems to be attached right under the center of the cover. What's the trick?
    New Friend:
I just got done fixing this problem. A vertical white bar was at the left 3rd or so of the display. I open up the projector (which required taking a steak knife to the center screw column since there's a unique, tiny screw that has to be removed), removed the shielding, and ensured that all the connectors were snug. Many of them were crooked and not seated in their sockets. I also removed and reattached all the ribbon cables, including the one that goes to the color wheel. The vertical bar is gone now. I have let it run for about an hour now with no failure.
Posted on Dec 06, 2013
    Problem Solver:
I have the same problem. Read another blog and they suggested that the tilt of the color wheel could be a problem. I have not had the opportunity to test it, but it may be right as the last time it was used it was okay until the "picture" was elevated (read: the machine was tipped up further). This would be an easy fix if this is the answer... just wanted to pass it on...
Posted on May 22, 2008
It's either pins that need to be reseated, or the Vertical display IC has gone bad. Open up the case, and make sure all connections are secure inside. If you are certain that they are all snug and nothing is loose on the board, then your problem is a faulty display IC. Replacing surface mount components is not for the faint of heart.
Posted on Jan 12, 2009
I don't have a solution but I bet the connector on the projector has a bad pin.
Posted on May 01, 2008
3 Suggested Answers
projdoc
  • 2237 Answers
SOURCE: vertical lines on optoma projector
use "frequency" to make an adjustment. then make sure your resolution matches.
Posted on Nov 16, 2009
SOURCE: optoma dv10 projector has a
contact optima in california. i had to after circuitcity failed to honor my extended warranty... surprise huh ??? anyway i talked to a factory rep. about the white vertical bar and he stated the unit has to come in..period. i said , so you know about this problem, he said yep, and the unit has to come in.. if your unit is under 2 years old they will warranty the repair, you have to pay the shipping to them, but they sent me a replacement unit next day air.. absolutely awesome customer service.. just google " optima projectors factory support" you will get an e-mail address. they e-mailed back immediately with a 800 number and we went from their..they were great and totally stood behind their product..
Posted on Jan 27, 2009
Seeing vertical lines on the picture
do the lines follow the same vertical pixel width from top to bottom or do they cross pixels? first try going into the menu and select auto-adjust. it just might be out of sync. you can adjust the resolution as well. if nothing changes, you might have a bad dmd (digital micromirror device). if that's the case and the projector is pretty old, replace the projector.
Mar 02, 2014 | Optoma HD20 DLP Projector
Vertical lines on optoma projector
Nov 13, 2009 | Optoma H30 Multimedia Projector
Optoma projector Ex350 connect to xbox360
buy a new projector i recommend sanyo projector specially model XT35... cause your projector is not compatible to your xbox.
Oct 06, 2009 | Optoma EP716 Multimedia Projector
Vertical lines showing. it is an Optoma HD70
If the lines present in the menu when displayed this indicates device mounting troubles. Possibly loose in socket. If you change aspect of displayed image do the lines move, if they do, its an electronics problem, if they are constant, and nothing is displayed in the lines. Tighten device in socket, or seek professional service.
Jul 07, 2009 | Televison & Video
VERTICAL WHITE LINES
I just read a post that said tap on the top and the line will go away. I tried it on mine and it worked! I had to tap it fairly hard. I just kept tapping harder and harder on the plastic in front of the buttons and voila! The vertical white line disappeared!
Oct 07, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
Help me please Optoma HD72 DLP
In the menu you can change the phase of the signal or the tracking. In Menu - Setup
Jul 05, 2008 | Optoma HD72 Multimedia Projector
My projector has vertical lines on display; what are possible causes of lines. Projector was dropped, I reinstalled lamp, lines went away for a while, now they are back.
Hi there
This is a common problem on a faulty Mainboard of a Projector.
Not much you can do about it except repair or replace the Mainboard
Apr 09, 2008 | Optoma EzPro 739 Multimedia Projector
Vertical line
Hi there
The only way of fixing this is replacing or repairing the Mainboard.
This is a common Mainboard failure on Projectors
Nov 07, 2007 | Optoma H30 Multimedia Projector
Vertical white line
My EP719 had the same problem. Did it once, briefly, soon after I bought it, then not again until recently, when the line came back more frequently and wider.
The projector was 20 days past warranty, and the company would not honor. So much for customer satisfaction and loyalty. Last piece of Optoma equipment I will ever buy!
Anyway, I found a web item on another model of Optoma projector with the same problem. The solution this guy tried was -- I kid you not -- rapping on the thing. With nothing to lose, I tried this on mine. Tapped lightly on the top and noticed a change in the width of the line. Hmmm ... it was sensitive to this.
Tapped harder. The line got narrower. Rapped pretty hard -- thump! -- and the line disappeared.
Since then I have been running the projector for hours, turning it on and off, letting it cool down, starting it up again. And the line seems to be gone. It may come back, of course, so this gonzo fix may not be permament. But if it works while I'm using it at a presentation, think of the amusement it will cause!
Oct 08, 2007 | Optoma EP719 XGA DLP PROJECTOR 2000L...
1,981 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
