Question about Epson ACULASER CX11NF All-In-One Printer
Worn k dev unit - Epson ACULASER CX11NF All-In-One Printer
2 Suggested Answers
tigertail
  • 163 Answers
SOURCE: printer shows worn dev unit what is this please
The dev unit (developer) is the part that the ink toner cartridge fits into, one for each colour (K-black, C-cyan, Y-yellow, M-magenta). Two things wear out on dev units, the bearings at each end of the developer roller or the roller itself. The roller is made of metal and is magnetised so a thin film of toner sticks to it, the magnet is recharged by electrical "rubbing" contacts inside the printer as the drum rotates. Gradually the contacts rub away and so the roller loses its magnetism, this will be noticed by an increasing amount of toner being spilled inside the printer. The roller bearings speak for themselves, gradually the roller will become more & more difficult to turn smoothly and so the toner will not be evenly distributed. The only way to fix this is to replace the worn dev units although cleaning the contacts will help to preserve their life.
Posted on Jul 08, 2009
Error code F-26-1
Is the devoper unit turning? Wipe the mag roller clean & power up, is the roller covered again by dev/toner, if not, it's the dev motor that's failed. Have you checked the toner recycle unit at the back? These get blocked , so no toner gets into the dev unit, is the m/c noisy, check the drum recycle unit isn't blocked.....is the toner bottle turning....
Oct 28, 2013 | Office Equipment & Supplies
Toshiba error cf20
things to check...Revolver Motor No Good ( if it's got a gold coloured gear it's the old type, new type has a dark grey gear ) this has been the biggest cause of CF20 i've had. Revolver Backlash ( does it rock backwards & forwards slightly when operated by hand? ) , this can be adjusted with the screws on the revolver motor. but make sure to not end up with the revolver too tight. Teeth missing on Revolver unit. ( it only takes one or 2 missing ) Colour Dev ( s ) worn Colour Dev drive gear / clutch worn ( or bushings very tight ) Colour ATS U/S Solenoid Dirty for Colour ATS ( inside ) Spring for Colour ATS return Stretched / Incorrectly fitted / Damaged I tend to check the Motor 1st, the list could go on, but these i find to be the most common causes.
Jul 22, 2013 | Office Equipment & Supplies
When ever we try to print or copy it always jams at the exit feeder, and always has huge black smears all over the far end of the page.
Hi this issue is going to be an issue with the exit sensor and fuser unit will cause black smears check the fuser unit rollers if worn replace the fuser unit assembly
Feb 16, 2011 | Sharp SF 2040 Copier
Printer shows worn dev unit what is this please
Jul 08, 2009 | Epson Aculaser C1100 Printer
Afficio 450 or gestetner 3245 calibration
Dev. Change Process
1. Check that Dev. unit has the lastest seals.
2. replace dev. material.
3. Dump dev.
4. add new dev. material.
5. Hand rotate the dev. unit 10 times.
6. reinstall the dev. unit into machine.
7. cover the toner inlet opening with a piece of paper
8. insert PCU unit.
9. turn the machine on.
10. When machine reaches ready -- enter SP modes and perform SP-2801 (2 times)
11. open the right cover of the machine. Cheat the right cover switch. Examine the drum as it rotates. Afew bands of toner and the ID pattern will be developed on the drum. The drum should be clean -- a slight dusting on the drum is OK.
12. Perform SP-3001 -- ID sensor initial setting.
13. ** Important** remove the PCU unit. Empty the toner from the PCU by sliding the shutter on the bottom of the PCU to the side and tapping the PCU.
14. reinstall the PCU.
15. Run test copies.
Pls rate -- thank you
Mar 02, 2009 | Ricoh Aficio 450 Copier
Error Messages
The false Jam at MP E is a common error caused a manufacturing error/problem. You can download a solution to this problem HERE.
The K dev unit error can only be removed by replacing the dev and completing the service mode adjustments. A service manual will help you with this issue. Get one HERE.
Jun 06, 2008 | Epson Aculaser C1100 Printer
Worn K Dev Unit - can I get service for the CX11NF in the Greater Vancouver BC area?
If Epson have provided you with a new Dev unit ( black plastic thing with a roller and black powder in it), get a service manual so you can install it. It is VERY straight forward and if you can use a screw driver and have opposable thumbs, you should be able to do it about 20 minutes.
Try this place for a manual
May 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson aculaser1100
Replace the yellow Dev unit. This will most likely eliminate this problem. They have a life span and I am replacing then on machines less than a year old on occasion.
Sep 21, 2007 | Epson Aculaser C1100 Printer
Epson ACULASER CX11NF All-In-One Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
