Any idea of where I can get a Celcus CWM 1206 user's manual? I can't find it anywhere on the net and can't work out the different settings on the macchine - at some point it didn't spin and the water wasn't draining but I don't know if it is because of the setting... I can't even find a manufacturer website - Do they exist???? please help!! :)
  • 209 Answers
SOURCE: wont drain
I am a retired engineer of 20 years and the problem is the pump, remove plug from wall,drain the machine by hand first, remove the bottom back of the machine and test the 2 connectors on the pump for a circuit with a multimeter assuming you have the ability, an open circuit means a new pump is wanted, it may also be blocked / remove and clean out all bottom pipes and check inside pump for rotating impeller movement, it must be free to spin, if readings on meter are fine, build up and try again, work with safety, water and electric don't mix, also it may be that a wire has come off, check that first sorry,
Posted on Sep 09, 2007
jsrock516
  • 5911 Answers
SOURCE: drain and spin cycle
Okay...the problem may be that you have something caught in the drain pump preventing the impeller from turning. Or, the pump itself may have stopped working. If you experience a problem where the washer does not drain or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
Please read ALL instruction before attempting.
1. Unplug the washer while servicing inside the unit.
2. Remove the lower kick panel under the door by removing the screws at the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
3. Locate the drain pump. It will be located under the wash tub (it is the only pump this washer has).
4. The pump can be removed and the housing taken apart to clean out the impeller trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and place them under the pump. Remove one of the drain lines and allow water to drain. If the tub is still standing in water (as you stated) bail as much from the tub before removing the drain lines from the pump (if you are using the towel method for collecting water).
6. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
7. Clean out the pump thoroughly and reinstall the housing cover. Make sure the cover is snug, but do not over tighten.
8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
9. With the bottom panel still off, plug the washer back in and select a wash cycle. Allow the tub to begin filling and check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping.
10. If there are no leaks, you can stop the wash cycle at any time and select a drain cycle. If the drain pump works normal, reinstall panel and tighten screws.
11. If your pump still does not run, more than likely, the impeller motor is damaged and the entire pump must be replaced. The motors typically are the part that fails on this pump. Follow the previously mentioned procedures for removing water from the wash tub.
NOTES:
a. Your pump is item #916709 at repairclinic.com. Or part number 134051100 at searspartsdirect.com. Just type in your model number in the search menu and a parts index with pricing is made available to you. the pump is listed as an "askoll pump" under the "Tub" header at the Sears website. HINT: Sears has it a little bit cheaper.
b. It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
I hope this information is helpful. If you have any questions/concerns, please post back with your comments. Good Luck.
Posted on Feb 28, 2008
  • 148 Answers
SOURCE: washer wont drain water
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
Posted on Jul 13, 2008
prawinmv22
  • 106 Answers
SOURCE: it will not drain or spin
Hi. this is a failed timer device. simply replacing the timer control module will eliminate these issues you are having.
rate me
Posted on Jun 12, 2009
  • 4 Answers
SOURCE: Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Posted on Aug 06, 2009
Celcus TV has aerial in to point in the wall. The chennels recently started going blurry and when I went to retune it's now saying it can't find any channels at all.
having no idea what you are plugging it into at wall My antenna is outdoors on a tower and it has to point toward the city where the stations transmit from .
May 11, 2016 | Celcus Televison & Video
My celcus cwm 1005 wont tack the washing powder
if the machine wont take in the powder
then the machine has no cold water supply
so this is caused by a few things
1} there is no cold water turned on to the machine
or there is a heavy pressure drop in your cold water supply too your home
2} the inlet filter is blocked solid the filter lives at the machine end of the cold water inlet hose... and you use a flat nose pliers to remove it for cleaning
3} the cold water inlet valve has failed
so it never opens so cant wash the soap from the drawer too the drum
i would get a tech too look at it
check the filter and also replace the valve if needed
Feb 08, 2015 | Washing Machines
I lost user manual for Celcus 32
I'm looking for manual for the remote control that comes with the celcus 32882 32 inch purchased second hand can anyone help please
Jan 07, 2012 | Televison & Video
I am trying to get hold of a manual for a celcus cwm 1005 washing machine, can you help?
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Sep 01, 2011 | Washing Machines
I need a manuel for a celcus cwm 1005 washing machine
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
John C.
Apr 23, 2011 | Washing Machines
Would like a owners manual for my WD-1290RD can't seem to find one on the net anywhere.
Here's a link to a site with your manual, it's free. If you need a different manual for a different country, just use the search bar on the site to locate one.
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1290RD-_E
Hope this helps, and best regards!
Jul 31, 2009 | LG Washing Machines
Owners manual
I have created a PDF manual for you I own this model. email me at hddrummer1@charter.net and I will send it to you or anyone else in need of the user manual.
Apr 29, 2007 | iLO 3200 32 in. LCD Television
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
