Question about Garmin echoMAP 50s with Transducer
Echomap 50s will not recognize legacy transducer (GSD-20). 6 pin to 8 pin adapter has been installed. Message "transducer disconnected. Sonar turned off".
3 Suggested Answers
  • 64 Answers
SOURCE: could you please let me know witch transducer to
Here are your options:
In-hull Mount Transducer (200/50 kHz, 12/45 deg)
010-10327-00
Thru-hull Mount Transducer with Depth and Temperature
010-10194-01
Bronze, Thru-hull Mount Transducer with Depth and Temperature
010-10182-01
Transom Mount with Depth, Temperature and Speed
010-10192-01
Transom Mount with Depth and Temperature (200/50 kHz, 10/40 deg)
010-10272-00
Thru-hull Mount Transducer with Depth (200 kHz, 12 deg)
010-10107-00
It all depends on the type of boat and how you are going to be using the fishfinder. Here is my email: kevin@sun-me.net if you want to discuss your uses further and if you want to purchase a transducer.
Posted on Jun 14, 2010
Testimonial: "thank very much for info it was spoton"
SOURCE: Sonar is working erratically. Loses
I have a very similar problem. Unfortunately my boating season is over until next May. I found I was at software rev 2.30 and should be at 3.40 Some of the software updates were to resolve sounder problems.
Posted on Oct 20, 2011
Hello... Have a garmin 50s and it keeps telling me sonar shut off no transducer available??? Worked fine until this past week??? Any ideas on the problem and fix? Thanks....Scott
Yea, your transducer died. check to make sure it's plugged in, if it still is, replace it. you know if it's working by a little click when you hold the puck
Jul 30, 2014 | GPS
Unit cutting on and off
how do you have it wired to power up on a acc.switch or straight off the battery best bet is off the battery most times when you wire it off a acc switch you have that problem
Jul 25, 2013 | Garmin echoMAP 50s with Transducer
Garmin echomap 50 keeps cutting in and out
Loose or corroded wiring and or connections.
My GSD 21 is mated to a Garmin 3210. Bought both componants new. Every single year since new it works 2-3 trips. Then just doesn't come on. Have to send it back to garmin who so far have waranted...
The GSD 22 is discontinued. I would not buy any electronics that are discontinued, because there has to be a reason.
If I were in your shoes I would be looking a full change to either the brand leaders, Raymarine or Humminbird. I have had Humminbird since 2007 with a 798SI and since 2014 with a 998SI HD. 100% reliable for GPS and depth. Boat used twice a week May to October. The 998 has features to set a chart course and I do that when coming from Toronto to Port Credit. Humminbird also do full chart plotters, but in Georgian Bay, I wouldn't have thought necessary unless you use an auto-pilot. Uses Blue Chart maps.
You aren't the only one to have problems. Read the link below.
I did find this thought and there are others in the thread
http://www.thehulltruth.com/marine-electronics-forum/146766-installer-i-stumped-garmin-problem.html
Make certain that the transducer(s) cable is separated from any engine power cables. When those wires cross or are bundled together, the highly sensitive sonar signal gets polluted with high amp noise bleeding off the engine wires, and you're lucky to get any signal.
To test if this is the problem, shut your engines off and see if you get a good sonar view. Then start the engines and see if the same sonar quality is displayed. If it degrades, you've got the current bleeding problem.
I had this problem when I installed the new gear (Furuno 585, Airmar b60) and ended up re-routing the transducer cable using some "wire hangers" to keep the transducer cable away from the others. Now I get a firm fix on the bottom at all speeds and the only time the display gets lost is when I reverse the starboard engine, from air bubbles under the thru-hull.
GSD 21 with 3210 problems - Google Search
Mar 21, 2017 | Garmin Gsd 21 Sounder Blackbox Fishfinder...
I have a Garmin 182c with a garmin GSD20 sounder unit ,if my transducer wire is cut or nicked would it cause the unit to unit to read " sonar turned off" ?
If you nicked it good enough yes it can. If the receiver doesn't detect the transducer, a digital message on the display will indicate this.
Mar 18, 2011 | Garmin GPS
Can i install 2 x52 units on bow and stern with
Yes you can...you would have to install a rotary switch between the displays and the transducer. You would also have to make sure to turn both displays off before switching the switch.
May 15, 2010 | Lowrance X52 Sonar Fishfinder Without...
Sonar inop at most times . onec in a while it works fine
(1) bad transducer. (2) bad ground from unit to battery. The cable next to the battery will have no effect.
Sep 05, 2009 | Lowrance Lms 522c Sonar Gps Chartplotter...
Garmin echoMAP 50s with Transducer Logo
75 people viewed this question
Top Garmin Boating Experts
Mohamed Ismail
Mohamed Ismail
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
