Question about Garden
Toro 5410 problems
Low oil pressure warning light and charging light on.pressure light goes off when you touch treadle peddle
Molson02536
  • 3854 Answers
SOURCE: Low oil pressure light goes on until car warms up. Oil level is good
The oil pressure sending unit has gone bad. I sending unit is just above the oil filter and you can get to it from the top. When you face the Engine look down towards the oil filter, the oil pressure sending unit is just above that and it looks like a cylinder with two wires coming from it. If you don't see it, it's right between the exhaust manifold and oil filter.
If you go to Auto Zone or Parts Source, they'll have the oil pressure sending unit and the step by step instructions, When installing the new sensor. Do not use teflon tape or any sealant, the sensor is tapered and need's the good ground from the engine to give you right readings.
Good luck and hope this helps.
Posted on May 11, 2009
  • 508 Answers
SOURCE: Could my low oil pressure warning light be caused
no that will not effect pressure!! :)
Posted on Jul 07, 2009
honeymokey
  • 3113 Answers
SOURCE: oil pressure guage occassionly drops to 0 psi and warning light g
Get it checked with a mechanical gauge. Replace sensor.
Posted on Sep 28, 2009
  • 7353 Answers
SOURCE: BMW 318iSE (1999) engine warning light
That sounds like you bought big problems. Oil ights indicate low oil pressure= BIG BUCKS. I would have a qualified repair shop check it out, A shop that specializes in BMW. If you are lucky, maybe the oil sender is just bad. They can also check out the Ck eng light. But the oil light is priority one.
Posted on Nov 05, 2009
agent91
  • 2100 Answers
SOURCE: oil pressure low when idling. When running engine
That is normal, my truck , if it had a light , it would be on, the gauge goes to about 0 when idling and flies right back up when going, When it stops moving is when I'll get worried about it. You might try heavier oil this summer and see if that changes anything. Go with a 10w40. If you are already using this, try straight 40 one time. Hope this helps.
Posted on Mar 14, 2010
Testimonial: "Thanks for your help"
Why would the oil light stay on?
That depends on the type of oil warning light being displayed. There are 2 types of warning lights
1. Low oil pressure light which all cars have
2. low oil level light which some cars have.
Low OIL PRESSURE warning means the oil pressure is below minimum and when this happens there will be insufficient lubrication of many engine parts because sufficient oil cannot get to all parts of the engine it is required to lubricate. Until the cause is identified and rectified the warning light will remain. If you run your engine with low oil pressure you will cause expensive damage to internal engine components.
Low OIL LEVEL warning means the oil in the sump has dropped to a dangerously low level (which may be due to an oil leak or abnormal oil consumption by the engine.) This warning means the oil level needs to be topped up and the warning will stay displayed until you top up the oil. Running the engine with low oil will cause expensive engine damage.
Since it is a 2 minute job, Oil levels should be checked fortnightly as a minimum, together with radiator coolant and power steering fluid levels, if you run the car most days each week as most people do.
It is possible for a warning light to remain displayed when the cause has been dealt with because there is a problem with the sender unit. However it needs to be established with alternative checks that the problem has been fixed before investigating if there is a problem with the warning light itself.
Nov 21, 2015 | Cars & Trucks
Oil warning light goes on when low rpm
low viscosity oil; add an oil additive (honey, as we call it) if the oil is relatively new or change the oil to something thicker. sometimes this happens because of the oil pressure sensor, and we replace it if it shows signs of leakage, but generally this is because of engine wear.
Mar 08, 2013 | 2002 Mazda Tribute
Why does the oil pressure light comes on
The oil pressure warning light comes on to warn the driver the oil pressure in the engine has dropped below 10psi.
The reason could be the engine is low on oil, or there is a problem with the oil pump or other internal engine component.
The oil pressure switch could also be faulty.
Jan 27, 2013 | 2004 Chrysler PT Cruiser
2000 Ford F-150. The oil temp warning light came on and the oil pressure gauge dropped to zero. While accelerating, the pressure gauge goes back to normal and the warning light goes out. No drivability...
Make sure the oil level is correct. If the engine bearings are getting worn, the oil pump is worn or it's screen plugged, that can cause low-RPM weak oil pressure. Try running with 'high mileage' oil at your next oil change and always replace the filter. At some point, you may need to consider overhauling or replacing the engine. Good luck!
Jun 06, 2010 | 2000 Ford F150 Flareside SuperCab
Warning light
if its the ignition light,its not charging the batteryif its the oil light it means low oil pressure,caused by low oil level,oil old and thin,oil pump needs checking
Apr 06, 2010 | 1982 Yamaha XJ 650
1992 honda accord 245,000 miles oil light blinking while idling and once while I was driving the oil level is good. what could be the problem
Oil light relates to oil pressure, not oil level. If engine has not been rebuilt, it is safe to assume that it is nearing the end of its life. Low oil pressure light goes off on increased rpm´s , and hence, pressure goes up. You can extend the life a little bit by switching to heavy oils, such as 20W-50, but eventually it also wont be enough, and will start fouling the plugs. Check the oil level, because extremely low levels of oil can also produce a low pressure warning.
Feb 18, 2010 | 1992 Honda Accord
1994 mercury Topaz oil light is on and i do not need oil
Low Engine Oil Pressure
The oil light is signaling low oil pressure in the engine's lubrication system. You say that you have checked the oil level in the engine and it is ok.
The oil pressure needs to be checked with an oil pressure gauge. (It is most unlikely that the warning light is faulty).
Should the oil pressure prove to be low - as I expect it will - the cause needs to be investigated. It is likely that there is a malfunctioning or failed oil pump or the oil pressure relief valve is sticking in the fully open position.
Failure to change the engine oil, at least at intervals stated by the manufacturer, will result in severe oil degradation and reduced oil pressure. However this is usually not enough to trigger an oil pressure warning light.
If you have changed the engine oil in the last six months or so, and have not done over about 7000 miles since then, oil degradation should not be contributing to the low pressure problem.
If the oil pressure gauge check confirms low oil pressure I suspect, on further investigation, that you will find a problem with the engine's oil pump.
You will need to get your vehicle to a reputable auto service shop to have the oil pressure checked and the problem investigated. Do not drive the car in this condition (except to get it to the repairer). The engine is not receiving sufficient lubrication and you run the risk of expensive engine damage and total engine failure.
Hope all goes well with it. Cheers.
Dec 07, 2009 | 1994 Mercury Topaz
Nov 05, 2009 | 1999 BMW 318 ti
My low pressure oil light keeps coming on when i stop and i just got my oil changed. The oil is not low. What could be the problem?
That means LOW PRESSURE , not low in volume. Pressure is measured in PSI. The reason that your light comes on when you are at a stop is because your engine goes to idle at a stop and would normally have lower pressure. That doesn't mean you should get a low pressure light though.. I would have it checked by a pro right away as this could be your first warning before a serious problem.
Hopes this Helps,
RSMITH972278
P.S. PLEASE RATE ME
Oct 19, 2009 | 2003 Dodge Neon
Oil pressure guage occassionly drops to 0 psi and warning light g
Sep 28, 2009 | 1999 Chevrolet Silverado 1500
Garden Logo
15 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
