Question about Canon Pixma iP3600 InkJet Photo Printer
My printer IP3680 series power and resume button alternate blinking... How to fix it? Anybody can help.. Jarmen
  • 112 Answers
SOURCE: resume not working
Sounds like head failed replace it see below
6 times Print head not-installed error Install print head.
7 times Print head error Replace print head, as it has failed.
8 times Waste ink near-full error Replace printer, as it has failed.
Posted on Oct 23, 2009
pineworks
  • 4041 Answers
SOURCE: Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the printer should turn off, if not, press the Power button once more.
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Posted on Feb 10, 2010
  • 164 Answers
SOURCE: cannot find resume button on canon ij3000 printer
The resume button is usually the same as the cancel button
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means your out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes means that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
Posted on Mar 07, 2010
sethdileswar
  • 253 Answers
SOURCE: canon ip3300 cartridge not moving. power light
open printer cover and clean all sensor of printer
Posted on Apr 12, 2010
  • 420 Answers
SOURCE: on/off button & restore button blink green & orange; printer doesn't work
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
Posted on Sep 18, 2010
Error 5002 che cosa puo essere?
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Sep 26, 2013 | Canon PIXMA iP3600 Photo Printer
Tip
Ink absorber full!
This error is common in all the newer variants of canon printers.. Canon charges 50-80$ to fix it! But it can be fixed by following the steps below:
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
on Mar 10, 2008 | Canon PIXMA iP90 Mobile Printer
Canon printer "ink absorber almost full"
I have used my mp470 for four years after useing this fix without a problem.
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
Feb 11, 2012 | Office Equipment & Supplies
How can i fix a error like contack your service center
Please follow the instruction step by step....
1. Turn off the printer without pulling the power cords.
4. Then Press Resume button 5 times then let BOTH buttons go.
5. You will notice that the Alternate Blinking error is gone, this means that the printer is in Service Mode state.
Aug 27, 2011 | Canon Pixma iP2700 InkJet Photo Printer
A window pops p that says waste ink absorber is full How do I fix it?
Try this to reset the error.
Jun 04, 2011 | Canon i80 InkJet Printer
Howdo you fix an error message 5C00 on a Canon iP90 printer.
Please rate this solution, thanks!
Mar 07, 2011 | Canon Office Equipment & Supplies
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
I have Canon MP760 Pixma printer message coming up 'waste ink absorber is almost full' can you tell me how to fix this?
Jan 21, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Canon pixma mp-610
Try resetting the printer:
Jul 19, 2009 | Office Equipment & Supplies
Error 5100 canon ip90
You may try this to rest the 5100 error:
Dec 07, 2008 | Canon PIXMA iP90 InkJet Printer
Canon Pixma iP3600 InkJet Photo Printer Logo
113 people viewed this question
old marine
old marine
