Question about Regal Ware Coffee Makers & Espresso Machines
Sona coffee percolator instructions - Regal Ware Coffee Makers & Espresso Machines
SOURCE: How to make coffee with 101-cup percolator urn (Regalware)?
Simply fill with COLD water to the number of cups desired.
Place the stem and basket in the pot and put one 8 oz cup of coffee for every 20 cups of water into the basket...when doing 100 cups I add an extra 12 oz of coffee for a good coffee flavor.
Place the perforated lid on the coffee basket that is in the pot (if there is a lid--some do not have a lid). Put the cover for the coffee pot in place.
Plug in.
Turn on if there is a switch.
Give these large pots about 1 minute per cup, brewing time...that is a little over an hour usually to brew 100 cups. The coffee maker will percolate with the water coming up through the stem and over the coffee as the water heats. Usually there is an indicator light that comes on when it is finished.
If holding the coffee for awhile, it tastes best if you remove the stem and basket and it will maintain the heat without doing more "perking" and becoming stronger or bitter.
Be sure to wash it out and dry it well, leaving the lid loose or upside down for storage so that the pot doesn't become pitted. Blessings, Louise
Posted on Jan 15, 2009
  • 33 Answers
SOURCE: General Electric Electric Coffee Percolator
sure thing Fred
Try this
to order all of your part needs
http://www.abtecparts.com/Westbend_Percolators_51000.htm
Please don’t forget to rate me.
eric
Posted on Feb 16, 2009
clyde2j2
  • 137 Answers
SOURCE: Regal Ware coffee maker 58001R not brewing
I'm afraid the heating element is burned out.
Posted on Feb 24, 2009
  • 13 Answers
SOURCE: i need a user instructions for my dualit coffee
http://www.dualit.com/news/docs/Percolator%20Manual%20GB.pdf
Is this your percolator? This one was the only one I could find, I hope it helps.
Posted on Aug 27, 2009
rickead1
  • 1998 Answers
SOURCE: need a new lead for russell hobbs coffee percolator--CP2 044/495
Hello, Click this link or copy and paste it to your browser http://www.russellhobbs.co.uk/contact_us.html if you scroll down the bottom it provides there phone number as well for customer support for Russel Hobbs in which they can help you to obtain the power wire for your unit. If you have any further questions message me back.
Thank you
Rick
Posted on Nov 19, 2011
How to brew coffee
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
Aug 04, 2014 | Faberware FCP280 Coffee Maker
Tip
How to disassemble & brew coffee using a Corning Ware P-146 or P-149 Coffee pot
Click on the photo below to read the original manufacturer's instructions on how to take apart & brew coffee using either the Corning Ware P-146 or P-149 coffee percolator. These early models are unique due to the outer pot lid threading directly onto the stainless steel coffee basket.
on Apr 09, 2015 | Home
How hot should the coffee be in a Farberware percolator
It should be about 180 degrees. The percolator should perc about one minute for each cup of coffee. If it stops too soon and the water is not hot, then the thermostat is bad. The thermostat can be replaced.
Feb 06, 2014 | Faberware FCP280 Coffee Maker
Farberware millenium coffee percolator does not heat
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
Mar 04, 2013 | Farberware Coffee Makers & Espresso...
What is a coffee percolator?
A percolator is a type of pot used to brew coffee. They are not used very much nowadays, since the introduction of other methods such as the drip, French press and espresso machines.
Feb 07, 2013 | Wine & Spirits
Maui outlets for Farberware percolator do not carry filters? Why?
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine.
enjoy your coffee
kolbrun
Jul 03, 2012 | Farberware FCP280 Stainless Steel...
I need a user instructions for my dualit coffee percolator
Aug 25, 2009 | Coffee Makers & Espresso Machines
Basic instructions on use of Russell Hobbs Type CP1 coffee perco
We too have a CP1, we need to find parts for a full restoration, after 50 years of service (it too was a wedding present to my parents in 1967) mum left it on, it boiled dry. I've messaged Russell Hobbs, but in case they can't help, anyone know a vintage parts source?
Jan 16, 2009 | Russell Hobbs RHCM3333 Coffee Maker
Farberware 4 and 12 cup percolators stopped making good coffee
I thoroughly cleaned my 4-cup percolator by brewing a couple of pots of plain white vinegar and scrubbing the build-up from the bottom of the pot (and running a couple of plain water brews through the pot after all the cleaning). The percolator now brews hot, strong coffee again!
Nov 05, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
598 people viewed this question
Top Regal Ware Coffee Makers & Espresso Machines Experts
Tom Chichester
ray gallant
Are you a Regal Ware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
