SOURCE: The projector is going into standby mode 30% of
check the settings. sometimes there is a shut off timer if it isn't used for a specific amount of time. you can turn that setting off in the menu (if it has it). otherwise, it may be overheating and needs to be cleaned out with canned air.
SOURCE: Why does the projector keep going to standby mode?
If the lamp usage time has passed 2 000 hours (when LAMP POWER has been set to NORMAL), the projector will switch to standby mode after approximately 10 minutes of operation. The resetting procedure should thus be completed within 10 minutes. 1. Insert the power cord plug into the wall outlet and then press the MAIN POWER switch. 2. Press the POWER button so that a picture is projected onto the screen. 3. Press the MENU button to display the menu screen, and then press the F or G button to select the OPTION menu. 4. Press the ENTER button, and then press the F or G button to select LAMP RUNTIME. 5. Press and hold the ENTER button for approximately 3 seconds. The confirmation screen, "LAMP RUNTIME RESET." is displayed and select OK. 6. Turn off the power. This will reset the cumulative usage time for the lamp
unit to zero.
SOURCE: my projector going to standby mode very frequently
Is it overheating? If it is check the filters are clean and there is plenty of air flow. If not which lights are on and are any flashing then look in your manual for fault conditions. That should give you a good idea on the area of the problem. It may be a lamp issue or ballast issue it may be a detection error and the unit switches off when it thinks there is no sync pulses even though there is a picture.
