Samsung wa80v3 automatic washing machine
I need to Convert the machine to function where there is no automatic water supply
SOURCE: model no wa80b3 samsung washing mashine
My washing machine is Samsung Top loading Model WA80B3, the problem is that the water inlet valve is continuously working all the time during the washing cycle and it does not stop automatically, so I have to run additional drying cycle after washing cycle and after closing the water supply manually
Posted on Dec 03, 2009
  • 423 Answers
SOURCE: automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
Posted on May 21, 2010
beltronic205
  • 1474 Answers
SOURCE: I have purchased SAMSUNG -
sounds like the drain pipe is too low resulting in Syphoning of water lift pipe above 24 inch floor level, this should cure...
Posted on Feb 01, 2011
barkencoa
  • 3463 Answers
SOURCE: Samsung WA80v3 connected to cold
It will heat the water as normal, even though it is a cold fill only washer.
Just select prog as normal, washer will do rest.
Posted on May 18, 2011
  • 489 Answers
SOURCE: Sir, I would like to
It should be fine but I'm not sure how it will work with the 220v. Be sure that the power there is 110v red to white and 110v black to white. If the power is not, it probably won't work. Good luck
Posted on Jun 18, 2011
I have a 2009 Faema Smart S-2, 2 group semi automatic coffee machine. Is it possible to convert it to an automatic coffee machine?
First, I am NOT a Faema repairman, Though I've worked on some Faemas, and similar espresso machines.
** Your question is a bit vague so I will try to provide info.
The 'semi-automatic' means you don't have to watch the brewing of the coffee. The machine will 'Dose' out a per-determined amount of water through the portafilter. Manual machines require to operator to turn water on and off to dose. Full automatic will grind the beans, measure and pack the coffee, then brew the coffee with water. Some have the option to froth and dispense milk directly into the cup. The industry usually refers these machines as 'Super-Automatics' They are very expensive and are designed for untrained personnel (not a Barista) to make coffee. There are a number of Home use machines now that provide a similar function but can only produce a cup for personal use and not multiple cups.
** I have come across automatic milk steamer and frother. This can be a simple cappuccino attachment to your steam tip. More updated version have an auto-frother that replaces the steam wand and will do a fair job (IF THEY ARE KEPT CLEAN!). Some machines have modified steam wands with sensor probe that will measure the milk temperature and shut off the steam when heated to set point. You will find all these features handy at first as it gets a novice worker quickly up to speed to produce product. But once they get the proper Barista training, most will not use these features as it's generally faster to produce orders the standard way. (also a good Barista will always present a professional looking cup!)
** I've noted that repeat customers appreciate the effort that goes into a properly brewed cup of coffee. Otherwise we would all go to a coffee vending machine (with instant coffee, Yuk!)
Aloha! youtube; ukeboy57
Dec 21, 2017 | Faema Coffee Makers & Espresso Machines
Turned on electrolux washer while cold water was disconected. Now receive an E11 error. Have reconnected cold water machine will not reset
Make sure the cold tap is turned on properly - sometimes the handle moves, but the shaft does not turn - especially those blue plastic ones. E11 means no water supply. Turn the shaft on the tap with a small spanner if necessary - make sure water is flowing.May be blocked with limescale - or the filter in the tap bunged up. Or could be problem with cold fill valve on the machine I suppose - wire disconnected, or needs new valve. Can you hear the valve buzzing when you start the program and it should be filling? check water supply again. take hose off the machine, turn tap on and see if water flows, with pressure.
Sep 15, 2017 | Electrolux Washing Machines
My whirlpool Fully automatic washing machine is not functioning properly,what can I do to repair it?
Check to see if the machine has touched the on off tap at the back during spinning and cut off water supply.Or check the penny trap at the bottom of machine.if both are okay the it is likely to be down to faulty board or impeller motor which helps the flow of water into machine.
Nov 19, 2014 | Whirlpool Washing Machines
Whirlpool WW1206
WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
PLEASE KINDLY ADVISE
Jan 17, 2011 | Whirlpool Washing Machines
Water supply hose(cold) blocker dont work
i am sameer from india... i want whirlpool fully automatic washing machine pcb circuit diagram
Jul 28, 2010 | Samsung Washing Machines
'Ventilate' message with functional direct water supply
Hi You need to push the button with the drop under it. That will turn the water on. The dial is just for steam.
Jan 30, 2010 | Saeco Royal Professional Espresso Machine
Am unable to prime water pump
Water is not being drawn from reservoir into boiler. The valve at the base of the boiler seems to function properly. After repeated attempts, I am unable to prime pump and fill boiler with water.
Dec 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Limited water supply in summer (off mains) - water usage?
Your machine will not function till the right level of water is put into it automatically from your inlet source; it varies depending on the programme. The only thing you can do is to see that the mesh in your inlet pipe is not clogged; pressure should be good too at your wall faucet. You are welcome, also you can rate me good, thk u.
Jun 03, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Model no wa80b3 samsung washing mashine
May 02, 2009 | Washing Machines
Convert function
BAHTTEXT(number)
The above function will convert a number to text. If you are referring to "figure" as a number than this should work for you.
You may want to try the TEXT(value,format_text) fucntion too but you'll need to supply a number format.
Apr 22, 2009 | Microsoft Office Excel 2003 for PC
Washing Machines Logo
Top Washing Machines Experts
