Question about Philips FWC798 CD Shelf System
REMOTE NOT WORKING
ORIGINAL REMOTE STOPPED WORKING, UNIVERSAL REMOTES WILL NOT WORK. ICON ON SYSTEM FLASHES WHEN REMOTES ARE PRESSED AND AIMED, BUT NOTHING HAPPENS AT ALL. YES BATTERIES ARE BRAND NEW, AND USED 4 DIFFERENT UNIVERSAL REMOTES. BEFORE THIS HAPPENED, SYSTEM USE TO TURN ON BY ITSELF FOR NO REASON.
  • 8,596 Answers
Philips is out of the original - best bet for finding it is to acquire a cheap/damaged model on Ebay with a working remote
Posted on Apr 08, 2008
SOURCE:
I need instructions on how to use the sharper image jumbo universal remote to control asymphonic television!(there is no code search button on the remote)
You can easily copy all your IR remotes into one in seconds with 5 easy steps.
1. Press and hold the device button to program such as TV1 for your first TV. (Remote lights up)
2. Press the button on your original remote to copy while pointing it at the jumbo remote. (Remote light flashes)
3. Press the button on the jumbo remote to save the signal into. (Remote light flashes)
4. Repeat steps 2 and 3 to copy more buttons.
5. Press the device button you pressed in step 1 to stop learning and you're done!
Mar 09, 2018 | Universal Televison & Video
How to check my bose rc-9 remote whether its working or not?
Put batteries in it and point it at the electronics unit and press some buttons
Dec 27, 2014 | Bose New Original RC9 Remote Control
Program code for Directtv Universal remote.
You can see an easy step-by-step guide to programming your remote right on your TV screen:
sm_cl_blu__number1_icon.pngPress MENU on your remote control sm_cl_blu__number2_icon.pngSelect Settings & Help sm_cl_blu__number3_icon.pngSelect Settings sm_cl_blu__number4_icon.pngSelect Remote Control sm_cl_blu__number5_icon.pngSelect Program Remote and follow the on-screen prompts img_remote_control_tv_sol1.jpg You can also use the manual method below: sm_cl_blu__number1_icon.pngMake sure your TV and your receiver are both on. sm_cl_blu__number2_icon.pngUse this tool to look up the 5-digit code for your TV. There could be more than one code for your brand of TV. sm_cl_blu__number3_icon.pngSlide the MODE switch on your remote control to the TV position. sm_cl_blu__number4_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number5_icon.pngUsing the number buttons, enter the 5 digit code for your brand of TV. The green light under the TV should flash twice. sm_cl_blu__number6_icon.pngAim the remote at your TV and press the VOLUME UP button. If the volume doesn't increase, repeat Steps 3-5, trying a different 5-digit code for your TV. If your remote control fails to program using all available codes, try scanning for additional codes. If one of the codes worked, proceed to the next step. sm_cl_blu__number7_icon.pngPress and hold MUTE and SELECT buttons until the green light at the top of your remote control flashes twice. sm_cl_blu__number8_icon.pngEnter 9-6-0 using the keypad on the remote control. The green light should flash twice again. sm_cl_blu__number9_icon.pngSlide the MODE switch on your remote control to the DIRECTV position. img_remote_control_tv_sol2.jpg Follow these steps to scan for additional TV codes using your DIRECTV remote: sm_cl_blu__number1_icon.pngSlide the MODE switch on your remote control all the way to the right to the TV position. sm_cl_blu__number2_icon.pngPress and hold the MUTE and SELECT buttons at the same time until the green light at the top of your remote flashes twice, then release both buttons. sm_cl_blu__number3_icon.pngUsing the number buttons, enter 9-9-1. The green light on your remote should flash twice. sm_cl_blu__number4_icon.pngAim the remote at your TV and press CHAN/PAGE UP button. Tap the CHAN/PAGE UP button repeatedly until the TV powers off. sm_cl_blu__number5_icon.pngWhen the TV powers off, press and release the SELECT button. Note: If the green light flashes three times before your TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, but your TV may not be compatible with our remote control.
Jul 08, 2014 | GE JASRM24912 Remote Control
I need to know the code to program a jvc av-32432 tv to a direct tv remote
Hello
The code for JVC with Direct TV Universal remote is:
10053
Programming DIRECTV Remote
[1] Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
[2] Enter the 5-digit code for your DIRECTV Receiver
[3] Power on the DIRECTV Receiver
[4] Move the slide switch to DIRECTV icon
[5] Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
then release both keys.
[6] Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
[7] Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
each code for your brand until you find the correct
code.
OK.
Jul 06, 2011 | Televison & Video
I want to program my Magnavox tv with a RCA remote and all of the online tips are not working
062,004,006,130,134,183,008,019,068,069,075,076,077,088,131,132,133,219,235
press code search indicotor light on.
press tv botton light blink.
enter codes tries each one on top light go off each code.
aim remote at tv off/on work u have it.
Aug 14, 2009 | Universal Remote Control TV-B-Gone...
Input codes directv remote (rc64), lg 47LH30
2. Locate the 5-digit code for your TV (see pages 13-16).
3. Move the slide switch to TV.
4. Press and hold in the MUTE and SELECT keys at the same
time until the green light under the TV icon flashes twice
and then release both keys.
5. Using the number keys enter the 5-digit code for your
brand of TV. If performed correctly the green light
under TV will flash twice.
6. Aim the remote at your TV and press the power key
once. The DIRECTV Receiver should turn off. If it does
not turn off, repeat steps 3 and 4, trying each code for
your brand until you find the correct code.
10856 for Lg tv
Aug 12, 2009 | Universal Remote Control DIRECTV Universal...
Cant get two remotes working for the same garage
You have to program them both at the same time. you have to do this fairly quickly as the programming window is small.
Aug 03, 2009 | Locks & Locksmithing
Do not have original remote and universal won't respond
you can test remotes by aiming them at a video camera or a digital camera and the LED on the frount should flash quicklyif it works. Replace the batterys if it doesn't
Jun 05, 2009 | Emerson EWL3706 37 in. LCD Television
Emerson Video Cassette Recorder remote does not work..model # EWV404
Try pulling your original remote apart and clean with metho let dry for ten minutes then put it back together. As for universal remote what sort of remote Make and model of remote?
Jul 23, 2008 | Emerson EWV403 VHS VCR
Urc 11-2082 B00
For the remote URC2082 you can set a code manually by doing the following. Make sure the appliance is on, aim the total remote at it and hold setup untill red light flashes twice, type 9 9 1 and it should flash twice again. Press power and then press channel + until appliance switches of, as soon as this happens press setup and the light will flash twice again. This will store the code and can be used on everything I've tried so far.
Jan 07, 2008 | Universal Remote Control DIRECTV Universal...
Philips FWC798 CD Shelf System Logo
166 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
