Question about Refrigerators
Magic chef mcbr445b1
It keeps freezing every thing inside
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
Krazytech
  • 725 Answers
SOURCE: magic chef compact fridgerator model mcbr445b1
you may just have a bad relay. with the power removed ..(unpluged)
remove the relay cover ( on the side of the compressor)
remove overload and relay
check relay for 4-5 ohms
check overload (if open it is bad)
let me know
Posted on Dec 21, 2008
Todd_pdx
  • 22 Answers
SOURCE: Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Posted on Apr 06, 2009
  • 396 Answers
SOURCE: My Magic Chef mini fridge temperature trouble
That can be very difficult to do with a mini refrigerator. There is just not enough separation between the freezer and the refrigerator.
You will likely just have to find a compromise setting and accept the results.
Posted on Oct 20, 2009
TheMobilian
  • 8220 Answers
SOURCE: Magic Chef Compact Mini Fridge Model
Might just be the compressor relay. They had a bunch of them go bad in recent years. I have repair photos HERE
Posted on Jan 10, 2010
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Magic Chef Refrig Model MCBR445B1, the motor/fan/compressor is not running when plugged in.. It is approx. 5 years old. Is it worth repairing?
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 24, 2010 | Magic Chef MCBR440 Compact Refrigerator
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
I have a magic chef compact refrigerator model mcbr445b1 wont turn on dont remember how to reset it with red button on temperture dial
Sounds like defrost timer on back right corner has stopped in the defrost position. Located bottom left corner inside white plastic box if you are behind ref.
Feb 01, 2010 | Refrigerators
Magic Chef MCCF5W do not works. Fast freeze is working.
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 02, 2010 | Magic Chef Chest Freezer MCCF5WBX
What would cause the inside top of a Magic Chef refrigerator model RBK21K-2A to freeze up and not keep items in the refrigerator compartment cold (temp doesn't drop below high 40s)?
lack of sufficient air flow across the evaporator coils, clogged condensate drain, too much humid air (door open too much, bad seals, etc.), low refrigerant.
Aug 07, 2009 | Magic Chef Refrigerators
Magic chef compact fridgerator model mcbr445b1
let me know
Dec 21, 2008 | Refrigerators
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
