Question about Irons
SGR Professional K 123 steam iron should be fixed in Hungary. I need spare parts as well. Is there any undertaking in Hungary dealing with srg household appliances
Heating is functioning, but there is no steam.
SOURCE: No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Posted on Feb 25, 2008
SOURCE: Iron No Longer Heats Up
Recommended solution, gently shake, did not work.
Considering the iron was at a minimum two years old, I decided to purchase another Rowenta. I found the recommended solution documented on a FAQ sheet enclosed with the new iron.
I actually own another Rowenta iron (I now have three) that has the same issue. I will send one iron, the one manufactured in Germany, to a Rowenta Service Center to see if can be repaired - it was the first Rowenta iron I purchased and it provided several good years of service.
Posted on Sep 21, 2008
ginko
  • 19396 Answers
SOURCE: tefal steam iron not heating up properly
That is probably because the contacts to the element at the base of the iron are broken.
To disassemble you have to remove the casing, then remove the steam pump at front top of iron and then undo the safety screw mounted on the front of the base plate.
Posted on Apr 22, 2009
bozcro
  • 867 Answers
SOURCE: Russell Hobbs Steamglide 2200.Iron and steam
is the water in your area heavy? it may have clogged your iron with stone. soak plate in something like clr .
Posted on Aug 10, 2009
jmgldsmth
  • 1906 Answers
SOURCE: How long should your iron last?
10 to 20 years
use distilled water
Posted on Sep 05, 2009
Testimonial: "I have, in the last 6/7 years had 2 Shark Irons, both did not last me 5 years. That is a far cry from 10 to 20 years. I was told to use tap water."
Spare parts for penquin steam irons
Fixya does not sell spare parts for Penquin steam irons.
Aug 15, 2017 | Irons
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Instruction manual
Try Retrevo Manuals.com
Nov 26, 2013 | Irons
Wet steam coming out of iron
You have to take part the iron by unscrewing the three bolts on the side handle with a small phillips driver. Then loose the allen screw on one side of the black thermostat wheel to unloosen it. Then take out the two bolt plastic protectors under the handle and unscrew the two allen bolts, carefully separate the top from the botton of the iron, carefully not to pry loose the cables from the top to the hot shoe.
On the back you will see a small white square box, that is the thermostat, which has a button on top, all you need to do is to push it in. This will make the iron heat up unless you have a thermostat failure (Black wheel with temperature indicators), which you will need to order the part and change it.
Mar 07, 2013 | Reliable i30/120V Professional Steam Iron...
Rust coming thru pores on sole plate?
You need to get a iron cleaning product to clean your machine. In the future, use ONLY distilled water in your Iron. Distilled water has been turned into steam (leaving all the minerals in the boiler) and that steam condensed back into water so it is absolutely free of minerals (that is what is coming out of your Iron).
Sum up: Clean it using a product designed to clean steam irons. Don't use tap or bottled water - ONLY distilled water.
Get the distilled water at your super market or auto parts store. Get the Iron cleaner where appliances are sold or at your local hardware store. You may have to ask for it.
Thanks for your question.
Jun 05, 2011 | Rowenta Professional DX8900 Iron
Seeking stopper for Tefal pro 2500 1875 steam iron/generator
I too was looking for one
http://www.partmaster.co.uk/cgi-bin/product.pl?PID=146230&query=tefal%20stopper
cost £20.99
Nov 01, 2009 | Tefal Irons
Yamata Steam iron 8800
Order Part Number 5 from Yamata at 305-418-4421
Yamata.com
Also see the parts diagram I just attached.
May 11, 2008 | Yamata Gravity Professional GSI-8800 Iron
Steam button wont push down
take down and clean the parts where the steam button is the spring could be dead and needs to e replaced.good luck
Sep 10, 2006 | Rowenta Professional DE880 Iron
Irons Logo
158 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
