Question about Dell Computers & Internet
Green horizontal lines on display
Hello everyone. I bought this new led monitor dell 2240l and whenever I start with a HDMI cable it shows green horizontal lines on the whole screen. I have sapphire radeon HD 7950 as gpu
    Problem Solver:
  • 10 Answers
First thing to try is another HDMI cable and see if this fixes the problem. Seen a bad cables way too many times...
Second: update your videocard to the latest drivers:
You can find the correct drivers @ AMD support. Click the link and choose the correct settings. Then click display results. Download & install.
Third thing you could try is another monitor. Even a new monitor can be broken. Not uncommon. If another monitor has a good image then return your new one and let them give you a good one
Posted on Oct 20, 2013
  • 41 Answers
SOURCE: Laptop dispalys to monitor but laptop panel cannot be activate
Thanks for all the details..
The issue seems to be with the video card drivers here...
Go to www.hp.com/suport and download the latest video card and the chipset drivers
before you download ...uninstall the nvidia chipset or any display software from program and features.
after you have installed the software.. go to the nvidia control panel > setup multiple monitors. and browse throughout the options >
It should be dual display and not extended display.
Also try with a new user profile...
Hope this helps..
Regards,
Anup
Posted on Apr 08, 2009
haayz
  • 197 Answers
SOURCE: Display problem - Dell D600
Try re-installing the ATI Redeon graphics driver (video driver). If problem persist, I suspected its your video card is having a problem. I believe it is built in on your machine. So you need to replace a system board.
If machine is under warranty, no need to pay for the repairs.
Posted on Jun 02, 2009
SOURCE: Dell Inspiron 6400 PC Notebook shows black screen after startup
I have a Inspiron 530 when I turn on it you can see that everything start ok but before I type my password everyting turn black an the only you can see is the litlle white arrow of the computer mouse
Posted on Jul 25, 2009
  • 3940 Answers
SOURCE: Laptop Screen White horizontal lines
Try reseating the LCD cable to the video card. If no change, then you will most likely need a replacement LCD (Roughly $150 on EBay)
Posted on Oct 01, 2009
  • 158 Answers
SOURCE: I have purchased a dell inspiron N1510 2 months
See if this happens outside of windows, when you first start up the computer, press f2 on the dell logo to get to setup. See if the green line happens here. Next, if possible, hook up an external monitor to the laptop and see if the green line is present on the external monitor. If the problem is present on the external monitor, you have a motherboard (or video card) issue. If the problem does not happen on an external monitor, but only on the LCD of the notebook, you have an LCD problem. You could probably get inside and try reseating the display cable. Here's the caveat, though. If your system is 2 months old, most likely it's under warranty. If you damage it by taking it apart, that is not covered by warranty. Your best bet is to try the few simple steps that I outlined and contact dell tech support, explain to them what you have done, and they should be able to set up a warrantied service call for the repair.
Posted on Feb 28, 2011
My led samsung tv has a horizontal line and the upper right corner shows a white vertical lines
Not good. You may have a tab failure. A repair shop may be able to diagnose and repair this, but most likely the lcd panel is broken. The panel is the most expensive part of flat tv's. A new panel will cost more than a used tv.
Feb 02, 2015 | Samsung Televison & Video
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
Oct 01, 2014 | Dell 1210S Projector
Horizontal lines LED hisense tv
If your LCD TV or monitor has stopped working, or is displaying one of the following
symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can
examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life
of your monitor or TV by several years.
Take it to a repair shop.
Apr 05, 2014 | Hisense Televison & Video
Display flashes horizontal lines
It's not unusual for a monitor to use different circuit paths based on the the display resolution chosen and so, one could have a resolution that is faulty, while another works just fine. Monitors normally just get dim, or power supplies fail, or other more common failures, blank or white dots... etc.; but, should a monitor live long enough without failing in those areas, usually one or more resolutions will fail. Doesn't leave you much of an option, other than a repair shop, if one could be found; but, as long as it works at that or another resolution, and I'd check the other settings and use it if you have something where it can be used. Sorry for the not so good news.
Jul 02, 2017 | AOC I2353PH New
E228WFP display disappears Posted by
disconnect all the cable from the monitor except the power cable .
see if you see any test screen and keep it on ,if the test screen blacks out you monitor is bad ,better buy a new one as usually repairs cud be expensive
Apr 17, 2010 | Dell E228WFP LCD Monitor
Green horizontal
I believe that you must reset the colors of the screen by the buttons on it or try to set colors by the software that the product came with it if any. There should be a setting to configure the 4 basic colours like red green black etc. Try to adjust green. If nothing helpes go the monitor back to test it by the store you bought it if there is warranty. Hope that helped!
Mar 23, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor
I would check the cable and connector pins first. Then I would suspect there's a problem with the video signal board inside the monitor. It could be the LCD panel controls, too. That would make the unit beyond economical repair unless you got a used one.
Jan 18, 2007 | Dell E171FPb 17" TFT LCD Flat Panel...
Computers & Internet Logo
52 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
