Question about Brother DCP-7020 Black and White Copier
Toner yield doesn't meet standard copies
Our machine is Toshiba BD5560. Our problem is the number of copies yield of toner doesn't meet the standard yield. Like for example, the 500g toner reaches 2,000 copies only unlike our other unit that the 500g toner reaches 8,000 copies. And the other problem is that the copy is always LIGHT. Is there any adjustment or calibration?
  • 46 Answers
Don't use aftermarket or refilled toner. Make sure you buy OEM at full price from a reputable supplier.
Posted on Sep 04, 2009
    Problem Solver:
  • 7 Answers
THIS PROBLEM HAPPEND WHEN THE DEVOLOPER IS WEAK. TRY TO CHANGE DEVOLOPER ADJUST THE TONER SENSOR OUTPUT BY PROGRAM 05 -0 IF NOT TRY TO ADJUST TONER CONSUMPTION PROG 05-92 IF NO ACTION CHEK ANEARBY TOSHIBA AGENT TO CHECK IS ANY THING WRONG WITH THE MAIN CONTROLLER BOARED THANK YOU
Posted on Sep 27, 2007
Toshiba Model e studio 2303 A.Trouble showing Error Toner.Need a solution.
Technology Time: Toshiba Error codes
www.mytechtime.com/2011/04/toshiba-errors.html
Toshiba E-Studio machines do not display service code automatically. ... All codes, except fuser errors are reset by turning the machine off and back on again. ... holding down "0" and 8" keys, enter 251 to set PM limit, and 252 to see the number of copies that have been run since the last PM. ...Toner transport motor problem.
Mar 21, 2017 | Toshiba Office Equipment & Supplies
My machine minolta 4000 showing code c0700
DId you open close the front door. if that does not work then take the toner bottle out. turn of the machine then turn it back on with no toner bottle in the machine. let the machine do its thing the machine will then ask to replace the toner at that time install the toner if that does not wok you have a problem with the toner motor and associated circuitry.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 23, 2014 | Konica Minolta Copy Toner, 40000 Page...
Drops toner inside machine. I just changed yellow high yield toner cartridge two weeks ago and it just went out. Changed cartridge and their was yellow toner inside machine. HELP
It sounds as if the toner has leaked, maybe it was cracked or seated incorrectly. Toner is so fine that if you use a standard vacuum cleaner the toner may just fly out of the back.
It's still worth trying to vacuum out the spilt toner. Remove all other cartridges first
Inspect the Yellow cartridge for damage to determine if it was that or the printer at fault.
May 18, 2011 | Computers & Internet
Need specific HP P4014n printer cartridge ITEM No. for reordering purposes.
The toner number you need is CC364AX for high yield or CC364A for standard. The high yield has more toner so it will last much longer.
I hope this helps, if so please rate our solution.
BuddyMc
Feb 04, 2011 | HP LaserJet P4014n Printer
I need to know the number for the toner cartridge for a DCP 8045D all-in-one laser printer
The OEM number from Brother is TN540 for a standard cartridge and TN570 for a high yield cartridge (more toner)
Jan 04, 2011 | Brother DCP-8045D All-In-One Laser Printer
I have a Toshiba Dp85F Fax machine and need to replace the toner cartridge...I do not know what model number I need to replace it with. Please advise
Ink, Toner & Accessories for DP-85F Printers, Copiers & Faxes Select from the list below Compatible or Original ink and toner cartridges that work with your DP-85F.
TOSHIBA TK-18 Compatible Black Laser Cartridge, TK-18
  • - Condition: Compatible
  • - Page Yield: 6000
  • - Color: Black
  • - Printer Technology: Laser Cartridge
  • - Item Number: TK18-70
- OEM Part#: TK-18, TK18
Item #: TK18-70
MSRP: $114.99
Price: $38.99
Toshiba DK-18 DP-80/DP-85 Drum Unit
  • - Page Yield: 20000
  • - Color: Black item-color-black.gif
  • - Printer Technology: Drum Unit
  • - Item Number: DK18-70
- OEM Part#: DK18, DK-18
Item #: DK18-70
MSRP: $114.99
Price: $39.99
Toshiba DP85F Toner Cartridge, Black
Toshiba TK18 Toner Cartridge, Toshiba TK-18 Fax Toner
$73.59
Nov 29, 2010 | Toshiba DP-85F Fax
I use to get thousands of copies from one cart -
DELL has two types of toner cartridges for your printer:
- a 3000 Page Standard Yield Toner Cartridge (Manufacturer Part# : RP441 | Dell Part# : 310-8701)
- a 6,000 Page High Yield Toner
(Manufacturer Part# : GR332 | Dell Part# : 310-8700)
The Toner yield is based on printing pages with 5% page coverage in accordance with ISO/IEC 19752 testing methodology. Yields vary with usage and environmental conditions.
In practice, depending on what type of documents you print, one cartridge can print much less than the quantity of prints advertised.
You might perhaps bought before a high capacity (more expensive cartrige)?
Also, if you are using compatible (not original Dell cartridges) or reffils of the original cartriges , the yeld of the cartrige may vary.
Aug 18, 2009 | Dell 1720dn Laser Printer
Replacing Toner
How to tell on brother mfc-8440 or mfc-9440cn , the total copies printed so far
Sep 07, 2008 | Brother MFC-9440CN Laser Printer
NO PROBLAME JUST A QUESTION
That all depends on the amount of toner coverage on the copies you make? The companies gauge the number of copies per toner on only 6% coverage on each page. About one small paragraph, any more the less the yield. On average about 2k -2.5k per toner give or take.
Apr 29, 2008 | Sharp AR-5320 Black and White Copier
Brother DCP-7020 Black and White Copier Logo
136 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
