Question about Haier Freezers
I have a Waves deep freezer which has a HUAYI compressor model HY69YG, my problem is that thee is very little frost on the freezer walls. I called a technician he checked compressor current it was drawing 0.6Amp at 220V 50Hz. He tried to load some more gas and current increased to 0.9Amp but icing started at compressor suction line. He released gas gradually till icing at suction line went away, and current again came down to around 0.7. My questions are: 1) Why no ice on the walls of the freezer? 2) What should be the running current of this compressor? 3) How to increase compressor current? 4) Is 0.6Amp ok or less? I'll be grateful if somebody can help me. I am a technical person but not a fDeep Freezer technician and I am trying to solve the problem myself as the manufacturer is of no great help. Regards, Wasif sadiw1@gmail.com
  • 1462 Answers
SOURCE: LG frost free fridge freezer GR-359sq
defrost drain is blocked - probably with ice. take the back panel off inside the freezer and melt the ice off with a hairdryer then follow up with hot water till it flows away freely. this takes some patience. if fault reoccurs then get back to me
Posted on Aug 28, 2008
SOURCE: Icing up in bottom of the freezer
I know how frustrating it is to get freezer ice build-up and unknown annoying noises but I have a solution that works great. I figured this out since I got tired of taking the freezer apart 10 times in 5 years and searching for a never ending noise:
  1. Pull out and unplug the refrigerator cord and take the lower back plate off (about a dozen screws) and you should see the plastic ½” drain tube hanging down and pointing at the plastic drain pan that is usually dry but stained. You will find out why it is that way as we go along. NO NEED TO TURN OFF THE WATER SUPPLY NOR DISCONNECT THE WATER LINE UNLESS YOU NEED THE EXTRA ROOM TO GET BACK THERE.
  2. Take the shelf, freezer floor, ice maker and light assembly out of the freezer (about a dozen more screws). Mark the wires if you have to disconnect them so you know where they go. Get as much ICE out as you can and mop up the water with some old towels. If you use a scraper you will hurt the plastic, unless you have a plastic scraper or just hitting it with the palm of your hand will break it up nicer. Get everything as dry as you can. Be careful to defrost the Styrofoam inserts slowly until they lift out of their square holes (a hair dryer works wonderful for this). This whole job gets lots easier after you do it a couple of times, BELIEVE ME.
  3. If you have a shopvac this part works better: Pull the end off of a shopvac hose (it will go back on later) and feed the plastic shopvac hose up over the plastic ½” drain tube in the back of the refrigerator. Don’t turn the shopvac on just yet.
  4. Plug in a hair dryer and prop it up on a small mountain dry towels inside the freezer pointing at the 1/2” drain hole in the back under the coils (the hole is metal lined and in the middle of the metal tray in back, you’ll see it).
  5. NOW, turn on the hair dryer and turn on the shopvac and wait about 10 minutes until the shopvac sucks the hot air down through the drain hole and melts the ice. Pour some water down there to clean it out a second time. You should feel the suction of the shopvac at the hole with your finger and it should be strong.
  6. The ice clog is about 6 inches down the tube below the opening so it takes a while to thaw out. NOW you know why the drain pan that sits in the bottom of the refrigerator is always empty and just stained.
  7. ANSWER: The heat from the freezer heater coil (during the defrost cycle) that is behind the cooling fins in the freezer can’t possibly heat up the drain tube so the water freezes solid. Then the heater coil melts the ice on the cooling coils and the water runs down through the openings in the square Styrofoam inserts (instead of down the drain) and right into the refrigerator where it puddles on the shelves.
  8. I usually run some extra water down there and let the shopvac **** it in to give a good rinse.
  9. Now put it all back together, BUT PUT THE STYROFOAM INSERTS BACK IN FIRST or you will be taking it back apart again to put them in. Pretty soon you will do the whole job of inside 1 hour on a weekend. The wires with the long piece of tape on them gets routed over the top of the cooling coils and tapes to the back wall above the fan, no biggy.
NOW FOR THE NOISE: Remember when you cleaned out the Condenser coils underneath years ago and thought you heard something? That was your vacuum extension wand hitting the fan. The blade is probably bent a little. With the power still off spin the blade with your finger and see if it wobbles and also check if there is anything on the blade or motor shaft that needs to be cleaned off, line string, pet hair or dust. You shouldn’t have to take anything apart to accomplish cleaning it, just unwind anything that got caught up in it. The blades can be bent back as long as you are careful.
THE OTHER THING I DID was screw in the front wheel levelers (behind the plastic vent cover under the refrigerator door) until the front was higher that the back. That way the water that accumulates in the freezer is sure to drain to the drain hole in the back and the 2 front doors close better on their own----AMAZING. Also the plastic drain pan sits up a little higher and doesn’t vibrate on the frame and make noise.
Posted on Nov 07, 2008
  • 56 Answers
SOURCE: compressor starts then stops after 5 seconds
yes you can order what they call a 3n1 it replaces the relay on your compressor but no guarantee it will work when installed as you could have locked rotor in compressor. part # rco-410 call for parts 877-262-1479 but is a non refundable part.
Posted on May 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Self defrosting deep freeze not defrosting
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Posted on Jul 13, 2009
heatman101
  • 43501 Answers
SOURCE: water is accumulating in the bottom of the freezer
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on May 27, 2010
Testimonial: "Will check out and see if it works. Next issue is how do I get to the drain line?"
My freezer works but not freezing
Could you please list a model number with your request for assistance? If I cannot answer your request just posting a model number moves customers to the top of the list for solutions. You refrigerator model number is most times found around the fresh food compartment door frame.
The most likely reason the freezer is not freezing as well as befor are the defrost components. Can you see a layer of frost building on the rear wall of the freezer? An example of this is found HERE Signs Of Defrost Failure and if you have these signs the evaporator behind the rear wall of the freezer wil look like this=> Evaporator Covered in Frost Due to Defrost Failure Let me know if the fans in freezer and under the refrigerator are running. Also if you don't have these signs the compressor may be short cycling due to a defective start relay, run capacitor and overload. Let me know and I will be here to answer your questions, Thanks Sea Breeze
Nov 21, 2012 | Freezers
Freezer does not freez food at all. the compressor motor run but no cool air or freez! Please advise any solution
Since you say the compressor is running, you should check the evaporator coil inside the cabinet. Remove the back wall screws, and the back wall, to expose the evaporator. If its fully encased in frost, like a square block of snow, you have a defrost problem, heater, t- stat or defrost control. If frost only at the top, your fan is not running. If its bare of frost, all you see is the aluminum coil, you have a sealed system leak of refrigeratnt
Oct 12, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Frost on wall
Hi, The defrost heater may not be working properly (timer stuck, heating element burned out, bad defrost thermostat,etc.). The unit should go into defrost mode about every 6-8 hours typically and last about 30 minutes (depending on model of freezer). During defrost cycles the compressor and fan do not run (don't want to keep cooling while trying to defrost). Once defrost is over, the fan and compressor get power again.
Take care
Jul 17, 2010 | Woods Freezers
Temperature Alarm
Can you look behind the food and shelves at the back wall near the bottom, if there is a frost build up on the back wall we have an issue with the defrost system, this would cause poor air flow and loss of cooling. I do not have your model number but I am assuming since it is a frost free unit it has an internal fan. If so is the fan running inside, can you feel air out the vent in the top? If not your fan motor may have gone out. The next thing to check is feel the side walls of the freezer, they should be warm. If they are not the compressor may not be running. Let me know the results of these questions and we can go from there.
May 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
Jan 11, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Lost vacumn, door popped open alarm on
If is the type of freezer where the shelves are also the evaporator(shelves are very cold and is normal to frost), the fact that only one shelf is iced would indicate the system is low on freon due to a leak. This would also explain the hot walls and compressor. It requires a service man to check the freon level and locate leak and recharge.
Sep 08, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
1999 Frigidaire Refrigerator
Check rear wall of freezer by feel for frost. Heavy, even frost indicates likely problem in the defrost system. Unplug unit. Defrost heater (in freezer behind rear wall panel), defrost thermostat (same area-must be checked at freezer temperature) or Defrost timer-located lower back outside of unit. Near compressor. Do continuity test on heater and defrost thermostat and if they show continuity (good), replace defrost timer. If not, replace the one that tests bad.
Defrost coils fully. Reassemble.
Please let me know if I have helped with comments and rating.
Refrigerator will work about 7-10 days after being defrosted until thick frost builds up again cutting off air flow to both compartments
Sep 07, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Kenmore Frost Free Comm. Model #253-23425100 - will not stay cold
Two things:
Either the thermostat has inadvertently been turned up, (too warm) or the gas in the compressor tank is low. If it isn't #1, call a repair tech to replentish the has in your compressor. If that isn't it he will tell you what he thinks it is. Good luck!
Mar 15, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer not cold enough
IF THE FREEZER IS AUTO DEFROST, DO YOU SEE A FROST BUILDUP ON THE BACK WALL? IF SO, YOU NEED TO DIAGNOSE THE DEFROST FAILURE. THERE ARE THREE ITEMS TO THE DEFROST CIRCUIT. THE TIMER, HEATER, AND BI-METAL. FIND THE TIMER, USUALLY ON THE BACK OF THE FREEZER DOWN IN THE CORNER NEAR THE COMPRESSOR. IT WILL HAVE A CONNECTOR WITH FOUR WIRES ATTACHED TO IT. IT HAS A KNOB THAT CAN BE TURNED TO PUT IT INTO A DEFROST CYCLE. WITH THE FREEZER RUNNING, START TURNING THE KNOB UNTIL THE COMPRESSOR STOPS. THAT WILL BE THE DEFROST CYCLE. THEN WAIT 5 MINUTES AND LISTEN IN THE FREEZER FOR A SIZZLING NOISE AND LOOK FOR A GLOWING FROM THE BACK BOTTOM. IF THE HEATER IS ON, THE TIMER IS THE PROBLEM. IF THE HEATER IS NOT ON, THE HEATER OR BI-METAL IS AT FAULT.
IF THE FREEZER IS NOT AUTO DEFROSTING, CHECK TO SEE IF THE COMPRESSOR IS RUNNING. IF IT IS, ARE THE SHELVES ALL FROSTED? IF NOT, YOU HAVE A SYSTEM FAILURE. IT COULD BE A LEAK, RESTRICTION, OR FAILED COMPRESSOR.
Apr 02, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Ice build up in my frost free upright freezer
I looked at the BACK at the bottom underneath of my Sears Kenmore frost free upright freezer and what was causing the ice buildup was very simple. At the factory, the assembler looped the little hose too high and when the water went into the hose it could not get out due to being too high in one spot! An ice dam will form, blocking ALL water coming through
and freezing up any more water coming down giving you a HUGE wad of ice that is scary!!! I just removed the screw holding the loop that holds the hose and put a bit of warm water down the little hole on the INSIDE (Behind the grate) to melt the remaining ice in the tube.You need to take out 4 screws and remove the grate to see this. I could not believe that this was the problem! I haven't had any ice build up since.Now don't tear your freezer apart before you try this trying to fix the compressor, thermostat etc. It may be the only thing wrong with it!
Nov 11, 2006 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezers Logo
Top Haier Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
Charles T Nevin
Charles T Nevin
christian nielsen
Are you a Haier Freezer Expert? Answer questions, earn points and help others
