Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
Fisher paykel dd603 - both drawer units just come on and won't turn off - turn off power several times at breaker - tried reset - turns off briefly then comes back on -
  • Fisher and P... Master
  • 3,247 Answers
There is water collected at the base of the dishwasher which is tripping flood switch. Will need to disconnect power and take the bottom drawer out and dry out the base. Need to find source of the leak. Most likely the lid seal or hoses.
Posted on Apr 03, 2014
  • 3 Answers
SOURCE: Fisher& Paykel
See also http://www.fixya.com/support/t346941-f1_error_1_draw_dishwasher
Posted on Nov 03, 2008
SOURCE: Fisher & Paykel single drawer dishwasher F1 flashing.
F1 indicates a problem with the Flood sensor. I cleaned all the filters etc. removed the drawer viewed under the drawer, it was dry. There is nothing further I can do, so called the Appliances repair person and booked an appointment for him to determine if an outlet hose is blocked or has a hole in it or whatever. Thanks for all the suggestions Blokes. I'm technically challenged. Happy New Year
Posted on Dec 29, 2008
  • 125 Answers
SOURCE: fisher and paykel leak
most likely the actuators are bad. with the unit off push and hold the lock and start buttons, lock first then start, after about 6 seconds the display will flash 188. press the power button, ho will be displayed. push the start button until Ld is displayed. open the drawer in question and push the lock button and watch the lid both sides should go down evenly, push the lock key to move it up and down as needed. push the power button to exit diagnostics. if you notice that the lid doesn't go down evenly or if one side stays up replace the actuators, they come as a pair. call a dealer/servicer to order actuators. make sure to specify top or bottom as there is a difference. hope this helps
Posted on Mar 03, 2009
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Posted on Nov 26, 2009
jyackle5
  • 8197 Answers
SOURCE: Fisher and Paykel dishwasher DD603 manual
You can get the manual below for free..
http://www.fisherpaykel.com/admin/pdfs/pdf_usecares/527971B_DD_user_guide_USw.pdf
Good Luck and please rate 4 thumbs for the free answer
Posted on May 15, 2010
The top dishwasher of my Fisher&paykel Paykel DDd603 &DS603 model ontinuallly beeps. I tried unplugging the power for several hours and it still beeps. Any recommendations ??
Assuming the bottom dishdrawer is working ok, it is likely the controller on the top drawer is either faulty or sensing some incorrect signal. If pressing any of the panel buttons makes no difference, then most likely the controller is faulty.
By the way I am unclear why you mention two models in your problem description. DD603 is a double drawer dishwasher and DS603 is a single drawer unit.
Apr 10, 2013 | Fisher and Paykel Dishwashers
Why won't my top drawer start
I am assuming you have a double drawer unit DD603. A drawer will not respond when you press Start button for several reasons. Assuming the panel lights are on, there could be a problem with the lid seal motor or the sensor that detects drawer is closed or blocked outlet hose or dirty panel. Take a damp clean cloth and wipe the inside of the drawer door panel. The dishwasher is very smart and checks for the condition of the dishwasher before starting. If turning off the mains power and turning it back on does not change the situation you will need a technician to attend to it.
Feb 07, 2013 | Fisher and Paykel Dishwashers
Fisher paykel dishwasher dd603 won"t turn on.
Is the problem with both the drawers or just one.
When you say - will not turn on - does it mean you get a blank display?
assuming mains power is turned on (no problem with circuit breaker), then it is likely the power board at the base of dishwasher (under the bottom drawer) is faulty and needs replacement. Make sure mains power cable is taken out when you work on the dishwasher.
Dec 11, 2012 | Fisher and Paykel 23 in. DD603H SS...
FISHER PAYKEL DD603 DISHWASHER AND TOP DRAWER HAS NO POWER
I know you did this but check your breaker. The other thing I would ask is has there been any storms dishwashers are the worst for power surges I see it all the time sucks but it normaly a 250 fix for a new control board
Apr 29, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher paykel dishwasher DD603 drawer is open but locked
i think you have to press the key/ lock button until the symbol disappears. You will find the exact button for your model in your owners manual.
Nov 25, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykel DD603 both drawers turn on and blink the code Fl. I turned it off at the breaker and cleaned it. let stand for 24 hrs and reconected still does same thing
It is not clear if the problem started suddenly or whether you have been doing some reconnection / renovation work and have reconnected the dishwashers.
F1 means the flood switch is activated, ie, the dishwasher is not able to control the inlet water.
This happening at the same time in both drawers is hard to understand. Have you tried shutting off and turning on the water supply? Is there any chance the water pressure has changed from the normal for your supply.- How to check what pressure your unit is set for is shown in the user guide - HP or LP. But I am not sure you can check that if the F1 display comes on.
You will need a technician to look at it if problem does not go away.
Nov 16, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
No power to top drawer so I cant even run a
If the controller is faulty then you will not see any life in the drawer unit. The controller is mounted on the front of the unit behind the door panel.
Oct 19, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Top drawer no power
This looks like an old question, but for the sake of refference I will respond to it..
On your dd603, the heater plate in the bottom of the drawer acts as a dropping resistor in the power supply circuit. The main computer is often replaced incorrectly when the the machine is "dead". The correct procedure is to check the heater plate first and there are several resistance tests that are done at the connector for the heater plate. Usually the overload on the plate itself is blown out. This will cause a dead machine.
Some of the other experts object when we say "You should get a service manual" but that advice is warranted here.
You can get one here:
http://fisherpaykelparts.net/index.php?categoryid=115&productid=18
Nov 20, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher Paykel DD603
The top drawer on our DD603 top lid doesn't seal allowing water to spray out and down the sides.
Aug 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
FISHER & PAYKEL DD-603
I have a DD603 bought used, put in the upgrade kit. But now it goes into pause several times during a load. It happens on both drawers very very anoying.
Oct 30, 2007 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
167 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
