Question about Delta Woodworking Drills
How do you remove the drill chuck on a vintage delta 14 inch drill press model dp-220
    Genius:
  • 1,114 Answers
Thread Changing chuck on older Delta drill press This site speaks on the subject of changing chucks. It may be helpful. Also if you search;' how to remove a jacobs chuck from a delta drill press' , you should get several hits I hope this info is helpful....
Posted on Mar 30, 2014
rowdy45176
  • 2176 Answers
SOURCE: how to remove chuck from drill press
I just looked at a breakdown for this tool and it is not that clear. But to get an owners manual you can go to Searspartsdirect.com and type in your model number and look at the same schematici I did and also order a manual for about 7.50. Usually though on a drill press like that it would be a morse taper. Do you see a slot cut thru the spindle on both sides, if so there should be a tapered key that came with the unit. In that case what you would need to do it put the key in the slot and tap it with a hammer to remove the adaptor and chuck. Let me know if I can help further
Posted on Jan 03, 2009
  • 10865 Answers
SOURCE: Replace drill chuck on 23 year old Craftsman 8" drill press
Yes it does have a Morse taper and you can remove it by gently hitting it with a rubber or nylon mallet.
Posted on Feb 08, 2009
  • 10865 Answers
SOURCE: the chuck has come off my delta desktop drill
clean the spindle and the inside of the chuck with easy off oven cleaner. get it all very clean and then be sure to remove all of the debris. pound the chuck onto the spindle with either a rubber mallet or put a block of wood under the chuck and use a regular hammer. DO NOT hit the chuck directly with a steel hammer.
Posted on May 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: Craftsman 10" bench drill press chuck wobbles
If this is a new tool I would take it back and get it replaced. The only other way to eliminate this problem is to determine if it is the spindle or the chuck and replace the defective unit. Warranty works better.
Posted on Oct 08, 2009
al_kupchella
  • 843 Answers
SOURCE: i need a chuck wrench/tool for a duracraft drill press
Are you talking about the chuck key? That's the little wrench with a collar of gear teeth on it.
There are only a few standard sizes plus a couple of odd-balls. Last time I looked, Sears carried a good selection. If you have the old one, take it with you to the store. If you don't have the old one, find a way to measure or approximately measure what you need. Another chuck key that doesn't fit can be a useful reference. If you can find something (maybe a drill bit) that is a close fit into one of the three holes in the chuck, that can be useful too.
Posted on Jan 19, 2010
Vintage unlisted model Milwaukee drill with frozen chuck.
on the bench drill ( drill stand ) if you see a long slot in the shafts when you pull the drill down all the way , the you will need a tapered bit of metal that fits in that slot
Drive the metal through so that it forces the chuck assembly out of the morse taper
You can get replacement units from any good tool shop
Apr 01, 2018 | Milwaukee Drills
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p...
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... https://eastcoastpowertools.ca/chuck-drill-press-5-8-jt6-for-milling King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto www.princessauto.com/en/detail/5-8-in-keyed-drill-press-chuck/A-p... Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - Amazon.ca https://www.amazon.ca/Woodstock-D3455-Drill-Chuck-8-Inch/dp/B000HRXOLS This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by Amazon.ca. FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== www.ebay.com/bhp/5-8-drill-chuck Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... https://www.kmstools.com/5-8-drill-press-chuck-2990 KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    Does any know much about a Rockwell delta drill press model o-2140-a?
    Rockwell Manufacturing Co. - Photo Index ...
    vintagemachinery.org/mfgindex/detail.aspx?id=698&tab=4
    02/24/2015, Jointer, 6" Short Bed Jointer, Model No. on Motor: JB82B710CW · 6" ...12/30/2014, Drill Press, Delta Rockwell Homecraft Drill Press 11-120 · 11" ...
    Aug 27, 2015 | Delta Drills
    What size taper is on a delta DP220 drill press so I CAN BUY A 1/2" DRILL CHUCK TO PUT ON IT
    If its possible, pop along to a local machine shop and ask nicely if they could help with identifying the Morse Taper, if its a Morse. Go online for what tapers would have been used around that period. Drill chucks are usually 1/2 UNF mount even if its a late metric unit. You would need a Morse to 1/2 UNF or taper to taper if you buy a taper fit chuck.
    Dec 29, 2014 | Delta Woodworking Vintage Delta Dp 220 14"...
    My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
    Please look at this site:
    http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
    This site has pictures that might help:
    http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
    Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
    Alternative chuck key specifications
    Delta is always creat problem.
    If you want to find best drill press open the link Black Bull 16 Speed Drill Press Explained
    Jan 17, 2013 | Drills
    How do you remove the chuck from a Delta shopmaster 350 bench top drill press?
    there is a "drift pin" that came with the tool, you would need to insert it into the slot and tap on it.
    Sep 08, 2011 | Delta DP350 Shopmaster 1/3 Horsepower 12...
    I have an old Delta D-220 drill press. While the chuck spins true, even at high speed, a drill bit will have a slight wobble towards the end of the bit. I tried many bits so its not a bent bit. Solutions? ...
    You are right,but if the wobble is not too big to do drill jobs it can be used.Sometimes drill jobs need to be precise,so the you will need it just aligned.
    Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or go direct to this link.
    Good price and service.
    If you need more help come back.Post / thumbs / testimonial are welcome!
    Nov 15, 2010 | Delta Woodworking Vintage Delta Dp 220 14"...
    Where can I buy a new chuck for my 15-091 dp?
    You cn find MANY chucks on eBay. You need to verify the size and the mounting which is LIKELY a Morse taper. ONLY buy new ones. There are some for as low as $8.
    Prefered brand is "Jacob's".
    Jul 16, 2010 | Delta rockwell 15" Vs6 Drill Press...
    The chuck has come off my delta desktop drill press. nothing i can do will get it to stay on.
    Mar 31, 2009 | Delta 15IN Stroke Production Drill Press /...
    Drills Logo
    304 people viewed this question
    Top Delta Woodworking Drills Experts
    Are you a Delta Woodworking Drill Expert? Answer questions, earn points and help others
