Question about Wolf Range CHR-10-229-FT11 Kitchen Range
I bought from a private party a used Wolf range Challenger Model CHR-4-29-HB11, oven worked fine. First I was baking and heard stove making a phfttt, phftt, noise. Then took food out and noticed oven cooler and pilot out. Relit. It came up to temp next batch in oven. checked ten min later. Pilot out. Relit. Stayed lit overnight. Set temp to 400. Fine. ten min later. Pilot out. Also notice right front burner makes that phftt phftt noise if I turn it all they way up.
    Scholar:
  • 97 Answers
Pilot lights go out because the Thermocoupler is either bad or not getting hot enough. It will be a copper tube that should touch the pilot light flame. these are replaceable and usually any appliance repair supplier can get you one. Some units reuire changing out the entire gas control
Posted on Oct 17, 2013
  • 3 Answers
SOURCE: Older 6 burner wolf commercial range ignition problem.
If it were the gas regulator, existing flames would go down as more burners are turned on.
There are set screws on the pilot fittings that come out of the manifold, you could try turning those Counter-clockwise to turn the pilots up. (Don't loosen them all the way, they will fall out!) If that doesn't work chances are the pilot stems will have to be replaced to get a higher pilot flame.
Posted on Mar 12, 2008
johnrodgers1
  • 80 Answers
SOURCE: I just got my (new to me) pre-1990 Wolf 36
the oven pilot has 2 setting first setting is for you to light small flame, should not be all yellow if it is it has a dirty orifice inside the pilot hood, you can remove this by disconnecting the pilot line from the hood and removing orifice for cleaning, just rub it with a cloth.once clean and replaced you light pilot and check it out. if its ok turn on oven and secondary pilot will ignite that why it got bigger!! this heats a flame sensor to allow 100% safty vavle to open to let gas into burner so yuo can cook.
Posted on Feb 05, 2010
  • 93 Answers
SOURCE: I have a model A-4-9K HB11-D Wolf gas stove. I
Call Wolf Manufacture.
Posted on Mar 02, 2010
SOURCE: I OWN A WOLF CHR
You should be able to blow out the pilot, after 30 seconds or so the fuel flow should be stopped by the oven safety (usually has the red button on it) If that does not work, the pilot is either fed from the gas manifold on the top (sometimes has a small needle valve to shut off, or it could be fed throught the safety valve. The valve will have an adjustment in it, usually under a cover screw. If the pilot fuel flow does not stop when there is not flame present, You should have the safety valve replaced. This can be a potentially hazardous scenario. Hope this information helps.
Posted on Jun 18, 2011
aquatom
  • 108 Answers
SOURCE: Wolf gourmet gas range/oven 36"--oven lights and
Check the temp sensor as this may be on the brink!
Posted on Oct 08, 2011
Heard a loud pop that tripped the stove breaker and main breaker. Now oven wont work on bake or broil but all other functions work fine
Mike - this is for a stove / range - not a washer - right??
I suspect that one of the heating coils melted and shorted, causing the breaker to trip. Given that the main also tripped, it may be even more involved. Please provide more details - including the make and model of the appliance when asking for more help.
Dec 02, 2014 | Washing Machines
I OWN A WOLF CHR 6-29 GAS STOVE AND WANT TO SHUT THE GAS OFF TO THE OVEN PILOT LIGHT. i AM NOT SURE WHERE THE PILOT VALVE SHUT OFF IS OR WHAT IT LOOKS LIKE.
May 04, 2011 | Wolf Range CHR-6-29-FT22 Gas Kitchen Range
Looking for manual and or parts breakdown for Wolf Range
We are Wolf factory parts and are able to provide any type of part, accessory or supplies that you need for this model.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service, with all your parts or appliances questions and we are happy to assist you.
Happy New Year to you ! Ella
Jan 03, 2010 | Kitchen Ranges
Wolf oven won't light after only 3 years since last repair.
You could try a new thermocouple and/or cleaning the pilot assembly. The thermocouple is the tube that screws into the pilot safety valve and runs to the actual pilot and is heated by the pilot flame. If you change this part be sure not to over tighten the thermocouple into the safety valve as it can break. You should go finger tight plus a quarter turn. Also you should check to see if the pilot is solid, not weak. Thermocouples can be purchased from your local equipment service company, sometimes Home Depot has them for water heaters, be sure you get on with proper length. Hope this helps.
Apr 29, 2009 | Wolf Range Challenger CHR-6-1829-FT22...
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Dec 17, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Wolf oven e1 code
Ar you sure it isn't an F1? Taht would mean an error in the latch
Dec 17, 2008 | Wolf Range CHR-0-18-FT22 Gas Kitchen Range
Problem codes for self-cleaning ranges
My experience (Kenmore Ultra-bake Model 665-72002102) was that E1 F5 meant an error with the oven lock switch. In our case, the latch was partly stuck from food or other debris. Just moving the latch back and forth loosened the scale that was making it stick, and it worked again.
Dec 05, 2007 | Kitchen Ranges
Wolf Range CHR-10-229-FT11 Kitchen Range Logo
204 people viewed this question
Top Wolf Range Kitchen Ranges Experts
Ismael Rodriguez...
John Rodgers
John Rodgers
Dan Webster
Dan Webster
Are you a Wolf Range Kitchen Range Expert? Answer questions, earn points and help others
