Question about Konica Minolta Magicolor 3730dn 4750 4750dn 4750en Waste Toner Box A1au0y1
Reset code No error display but all print out is
Reset code No error display but all print out is blank even print test page
  • 108 Answers
Check the toner/drum cartridge. reboot the printer. This could've a high voltage power supply issue.
Posted on Oct 17, 2013
Why error 5C20
Error 5C20 means the logic boardis faulty - most likely because it can't move the rollers and carriage.
This is a serious problem and in casea power recycle reset procedure does not fix it you will need to get theprinterserviced. and to do a reset
1.On the operator panel, press the button. (The display will go blank.)
2. Unplug the power cordand plug it back in after 30 seconds to ensure that the device resets itself.
2.Then press the button.
3.Once the printerhas restarted, please try to print a test page....just one more thing make sure there isn't a paper jam and the ink cartridges are properly seated.... that code seems to be a common problem with cannon
Jul 08, 2015 | Office Equipment & Supplies
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
My HP M2727nfs prints blank pages. Even demo page / reports are blank. NO errors on display. Paper gets warm, so fuser works. New cartridge doesn't help. Neither cold reset. What can this be?
This is a problem with either the formatter board or the dc controller, try doing an nv ram ( turn off the printer and hold down the right arrow and the cancel button, turn the printer back on and continue holding until you see permanent storage init). If this doesn't work call hp tech support 1800 334 5144 and ask for a case number. This printer has a service note which will cover the formatter for 2 years.
Al
Sep 14, 2010 | HP Laserjet M2727nf Multifunction Printer
Only test page prints nothing else prints blank page then starts 2nd blank page and stops midway through
Does the printer display any errors on the printer screen? You could try performing a print cleaning, check this manual for more directions how to do that.
http://www.ims-ink.com/pdf_files/english/IMS%20Ink%20Manual.pdf
Jan 11, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Prints Blank page between each page.
Please read through and apply the instructions in this HP support article. Possibly also here.
Should you have further questions or encounter other errors with that printer, your HP home support page for the D7460 is here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 12, 2009 | HP Photosmart D7460 Printer
Hp 1320 prints blank pages
My HP 1320 printer is printing blank pages and it will not even print test pages etc
Nov 03, 2008 | HP LaserJet 1320 Printer
Printing blank pages
open the door and look for a unit that has some small hair like wires, are they intact or is one missing /broken???
Oct 30, 2008 | Canon imageCLASS MF6550 Monochrome Laser...
Hp 4si
Your post is correct that error 53 refers to bad memory board or at times defective SIMM only. Since you have replaced them and no change, you may want to try to do a Cold Reset of the printer. This is done by powering on the printer while holding down the GO or Online button. Additionally, you may want to check/reset your NVRAM settings which can be done manually through the Service Mode.
This page lists most of the HP Laser Printer error codes. This link displays most HP LaserJets - Cold Reset Instructions.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 16, 2007 | HP LaserJet 4si Printer
NO RESPONSE, PRINTER DISPLAY BLANK
sounds like you have a bad formatter....there is a way to circumvent the formatter and print whats called an engine test. this is used just to test the mechanics of the machine and leave the brain out of the equation...
Engine Test Button Location HP laserjet printer 5000 series
The engine test verifies that the print engine is functioning correctly.
The Formatter PCA is completely bypassed during an engine test.
This test is very useful for isolating printer problems. The engine test
prints a full page of lines across the entire printable area, and is also
useful for checking and adjusting registration.
laserjet-5000-engine-test.jpg Note Engine test will print from the last input tray used.
If the last input tray is empty or if the last input source was the duplexer,
then the Engine Test will print from Tray 2 (standard 250 CST).
If Tray 2 is empty (and the last input tray is empty or the last input source
was the duplexer), then the Engine Test will not function.
Printing an Engine Test HP laserjet printers 5000 series
To print an engine test, use a non-metallic object (such as a pencil) to
press the engine test button. A single test page with horizontal lines
will be printed. To print multiple test pages, hold down the engine test
button.
If the engine test prints ok then you have a formatter issue...if you have added memory or a network card try taking them out one at a time to see if the problem goes away. Otherwise the formatter will have to be replaced.
Inkworks
Sep 05, 2007 | HP LaserJet 5000 Printer
Konica Minolta Magicolor 3730dn 4750 4750dn 4750en Waste Toner Box A1au0y1 Logo
110 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
