Question about Sewing Machines
Janome js1008 thread
My top thread keeps getting caught down where the bobbin is. It used to be apparent only after I prepared to snip the threads --now I can't sew at all before it jams. I have rewound bobbin, replaced thread and needle, checked tension on bobbin. Stumped.
  • Sewing Machines Master
  • 7,365 Answers
Check to make sure the top thread isn't coming off the thread take up lever
also make sure the bobbin is turned the right way in the bobbin case
make sure the needle is turned the correct way in the needle holder
also try a different bobbin
if none of these suggestions help, then it would be a good idea to have the machine checked for a timing problem
Posted on Oct 17, 2013
  • 29 Answers
SOURCE: a horrible tangle
This is a bit late, could the bobbin case not be seated properly? You need to put it into place and then turn it clockwise until it seats soundly in the opening. Also, check for burrs...the needle may have left a rough mark on the plastic or metal in the bobbin area. A piece of batting, or even an old knee hi should snag on any rough areas.
Posted on Jul 14, 2007
  • 6 Answers
SOURCE: Singer CG 550 Top thread keeps wraping around the bobbin and jam
Have you checked the top thread is correctly placed in the spring of the bobbin case?
Posted on Feb 21, 2009
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
  • 8 Answers
SOURCE: Top thread keeps breaking on my Janome 1600P.
I had a similar problem and then realized that the thread on the top had a **** on the spool it was catching on.
Posted on Sep 24, 2009
  • 980 Answers
SOURCE: Touch & Sew zig-zag model 758 - bobbin thread
email me for retiming instructions and remind me of your make, drivewithken@blueyonder.co.uk
Posted on Jan 09, 2010
I have a Janome magnolia 7318. when I lower feed dogs to quilt it will not sew circles or feathers well. It pulls bobbin thread up on top in loops.
I've found that when FMQing, I usually need to increase the bobbin tension to keep the bobbin thread down (for this reason, I have a separate bobbin case that has the tension adjusted that is used only for FMQ). You may even need to decrease the top tension if the top thread is "pulling" the bobbin thread up.
Jun 18, 2017 | Janome Sewing Machines
Why magnolia not picking up bobbin thread
Despite what the instruction book tells you, do not use the auto downup button to pick up the bobbin thread. Instead pull the wheel toward you and do it manually. Many times the bobbin thread gets caught and the machine halts if that auto down button is used.
Jun 19, 2014 | Janome Magnolia 7330 Sewing Machine
Have Janome DC3050. Bobbin thread is getting caught on the hook shaped guard to the right of the bobbin. Hook race? I know threads got caught in bobbin and believe it bent or moved this. Now makes a...
I don't know your model but my Janome 6500 has a bobbin case held in by magnet on the underside and it will dislodge and move if there is a jam up. This then prevents it from forming stitches correctly. You need to lift out the bobbin case and put it back into position. With mine, when it has moved, the needle then strikes part of the case when it comes down. This often results in a burr in the plastic which then causes the thread to catch again even when the case is back in correct position.
There should be two marks, one on the case and one on the outside to align it to.
9k=
this is my bobbin case, and the cut away part on lower part of the image is the bit that goes into the machine away from you.
Feb 07, 2014 | Janome DC3050 Computerized Sewing Machine
I am having a problem with my Janome Decor Excel 5018. It was working fine, until the bobbin thread won't gather with the top thread. And the top thread is binding up underneath the fabric. Kim
try a new needle
rethread the machine top & bobbin, that way you make sure the thread is not caught anywhere
make sure the bobbin is correctly inserted in the machine
clean under the needle plate & in the bobbin area for loose thread & lint
always keep a long thread tail of 3 to 5 inches long, & keep the tails pulled back behind the needle
before sewing
if none of these things help the problem,, then it may need to be serviced
Aug 10, 2011 | Janome D'cor Excel 5018
The top thread on my Janome 300E is getting caught in the bobbin. It starts bunching up on the back of the fabric that I am trying to embroider and it gets stuck. When I pull it off all the top thread is...
If your thread is getting caught underneath it's usually the UPPER thread is threaded wrong or not correctly through the tension discs. This can also happen if you're using Sticky Back stabilizer. Make sure you have a new needle in case there's a burr on the old one which can also cause this problem.
Aug 22, 2010 | Janome Memory Craft 3000
Bobbin thread tension issues
There might be a piece of thread or lint caught in the bobbin tension preventing it from functioning correctly.
Feb 24, 2010 | Janome L-344 Mechanical Sewing Machine
I can't find the manual to remember how to thread the janome 11706. Please help.
If you send picture i can map it out for you, it's so much easier like that
Nov 27, 2009 | Janome 11706
My Janome Memory Craft 4800 is skipping stitches. I've cleaned the bobbin race, replaced the needle and re-threaded both top and bobbin. Any suggestions? it also feels as if the thread is getting caught on...
Here are some things to check.
* Thread tension is too tight.
* Needle is bent or blunt.
* Needle is wrong size.
* Needle and thread does not match.
* Light pressure on presser foot.
* Incorrect setting of needle.
I hope this helps you.
Sep 18, 2009 | Janome Memory Craft 4800QC
Sewing Machines Logo
47 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
